Question about Dimplex DS4411 Electric Heater
I have 2 Dimplex DS4411 fireplace heaters. One has the fire display, but does not heat. The other has heat, but no fire display. How do I fix it?
  • 72 Answers
The fire display is a simple replacement of the light bulbs that produce the effect.
The heater issue could be a bad temp sensor, or a bad heater.
You can contact Dimplex support here:
Technical specialists:
1-888-346-7539
Monday - Friday
8:00 a.m. - 4:30 p.m. EST
Posted on Nov 30, 2012
5 Suggested Answers
  • 2461 Answers
SOURCE: remote control working with fireplace.
try www.dimplex.com go to customer sevices they should be able put you on to a local dealer in your area
hope this is of some help
Posted on Dec 13, 2008
buzzwood
  • 65 Answers
SOURCE: Dimplex Compact Electric Flame Stove Heater
call Dimples !-800-663-6663 ext 358 They will be able to help you out.
Posted on Jan 21, 2009
SOURCE: No Heat or fan on model DS4411 Or 6901050100
I had the same problem. One or more of the switches for the stove have melted and broken. You need to call Dimplex and request new switches. They should ship you out a 3 pack for free, and the pack will come with easy instructions for removing the bottom panel and replacing the switches.
Posted on Jan 25, 2009
  • 4736 Answers
SOURCE: How do you disassemble the
Good information. Thanks for sharing it.
Posted on Aug 23, 2011
What type of bulb is required for the mcn20 dimplex fire thank you
Steve, a 60 watt, small base, chandelier bulb is what is required. There are usually 3 to 4 of them in most electric fireplaces.
Hope this helped you. Please let me know. Thanks.
Jun 17, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
My heater motor stoped turning and blowing but the heat strip kept heating and melted the rotating fan . It is a 20406D7F 077 can I order a whole complete replacement unit
Yes, you probably can. Plus, Dimplex should be made aware of this. Contact Dimplex Technical Service 888-346-7539, Monday -Friday, 8a -4:30p ET. Have the model number, serial number and proof of purchase, handy when you call.
Hope this helps you get the parts you need.
Apr 26, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
I have got an electric fire Place that blows out hot air, well after about 5 mins it stops blowing out hot air and it blows out cold air, can any one help me fix it?
More than likely, the heater element is overheating and the overload switch is turning it off. It could just be a case that the heating element needs cleaning. As they do become clogged with dust and lint, because they take in cool air at floor level, heat it and send it back out. You didn't mention who the manufacturer of your electric fireplace is, but they all work just about the same way (badly, most of the time). Turn OFF the Master On/Off Switch, unplug the fireplace from the wall and leave unplugged for 12 to 15 minutes. Now, would be a good time to clean the interior, if you want to under take it. Plug the heater back in and turn the Master On/Off switch to the On position. Turn ON and set the heater control. If it returns to normal operation, the problem is solved. If the unit continues to have to be reset (if it's a Dimplex) turn the Master Switch Off, unplug the unit and contact Dimplex USA, Technical Service at 888-346-7539 for more information.
Hope this helps solve the problem.
Mar 17, 2011 | Heating & Cooling
Will someone fix my fireplace,it sparked and zapped then I shut it down
If it's still under the 1 year Manufacturer's Warranty, Dimplex will repair or replace at their option. If not within the warranty period, unfortunately, you're on your own.
You can contact Dimplex USA Technical Support at 888-346-7539, Monday - Friday,8:00 a.m. - 4:30 p.m. EST. They can help you trouble shoot the problem.
Mar 03, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
The fireplace blower does not work therefore there is no or very little heat from my dimplex elect fireplace---thanks
This is a constant problem for ALL electric fireplaces with heaters. Either the Owners Manual fails to the manufacturer not telling you that the heating elements need routine cleaning, because they are sucking in household air to heat it and send it back out, So whatever is float in your household air (dust, lint & pet hair) near the floor goes into it, clogs it up and causes the heating element to overheat and fail. Or customers who have purchased these units don't read the Owners Manual.
These units, no matter who the manufacturer is were not designed to heat for long periods of time. In fact the heater element doesn't produce much more heat that a blow drier on high heat.
The heater and the blower and are in the lower compartment of the firebox. If you can access it, you can clean it with a shop vac and a brush attachment on the end of the hose. Be sure to unplug the fireplace from the wall outlet before attempting this. If cleaning it doesn't help, the blower motor will have to be replaced. You can order one from Dimplex USA.
Feb 06, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
My dimplex fire place heater makes constant clicking noice, can you please help?
this is probably the spark igniter the button you push to light might be stuck
Jan 12, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
Dimplex manual
HI
you could try here at or even email/contact them these should be able to give you the manual
Dimplex Heating & Fireplaces
riz.
Feb 05, 2009 | Dimplex Compact Electric Flame Stove...
Motor in dimplex fire/heater not turning
Hello. It could be possible that a piece or some of the foil that gives the flame effect has fallen down on the motor, that creates the heat. This could be causing the noise. I would not think this is an electrics problem.
I would ensure the electric fire is disconnected from any power supply and either open the heater myself or get a electrical specialist to have a look. Then you will see exactly what is happening. A piece of foil may be visible which is catching the motor.
If you decide to tackle the problem yourself write down how to put the heater back together as you take each part out. These parts would be covers etc. It can easily get confusing. That is important.
Feb 02, 2009 | ACE Dimplex (r) Compact Electric Fireplace...
Dec 22, 2008 | Dimplex DS5598 Mid-Size Heater
Remote control working with fireplace.
Dec 13, 2008 | Dimplex DS5603 Heater
Dimplex DS4411 Electric Heater Logo
350 people viewed this question
Top Dimplex Heating & Cooling Experts
paulcarew
ashburton
Kory Ronning
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
