Question about Swisher T14560 T - 60" Trailmower with 14 - 1/2 - Horsepower Briggs & Stratton I/C12 Volt Starter
Swisher 60" pull behind mower with 14.5 briggs engine. good spark and the starter will crank just fine. If I prime the carb with a little gas it will start imediately but wont continue. Any ideas..
  • 608 Answers
Hi Andy, the carby will need to be removed and all jets cleaned out with compressed air. Basically its not getting enough fuel through the carby to keep running. Regards Phil.
Posted on Nov 29, 2012
  • Andy Hamilton Dec 01, 2012
    Thanks Phil for your suggestion....I have cleaned out the carb and beginning to reassemble. While its apart thought I would check the fuel shut off solenoid. When 12 v is applied to the leads should the movement of the plunger be fairly noticeable or more subtle. If plunger is weak could that add to the lack of fuel supplied to the Carb?
  • Phil Walker
    Phil Walker Dec 04, 2012
    Hi Andy, the movement should be swift and audible but travel is fairly small, say a couple of mm at most. If the plunger is not functioning this way it will definately lead to a lack of fuel. regards Phil.
4 Suggested Answers
  • 695 Answers
SOURCE: swisher 44" mower starts and runs but engine bogs
The engine in this machine seems to be powerful. If you can remove the belt from the pulley that drives the blade. Try turning the pulley buy hand. If it turns tight or not at all this is your problem. The unit that is the pulley to blade assembly is seized or ready to seize. Sometimes they are designed to be taken apart and repaired, and sometimes they are not. Did you check for a grease fitting within the pulley to blade unit?
I would like to hear how this works out for you. Best of luck.
Posted on Jun 14, 2011
SOURCE: Swisher Mower dying when cutting
I've had a 60" Swisher finish cut (13.5 hp) for about 7 years and have found that the valves have to be adjusted on a VERY regular basis. When they get out of adjustment you can hear the starter trying to spin the motor but can't. I'm almost positive this is your problem. Go to You Tube to see how to adjust the valves to .004. It's simple. Stan Wilhite
Posted on Apr 18, 2010
SOURCE: My swisher pull behind was working fine and I was
take the cover off above the ignition switch ckeck 4 loose wires if nothing is found wrong jump it at the selinoid if it starts go to the nearest perts store and buy a selinoid for an ole ford truck transfer wire exact and it should wrk fine
Posted on May 07, 2009
Do you have to prime a fuel pump after it has been rebuilt
when you put a new fuel pump on whatever type mower you are working on,yes its good to prime it a little so that your not cranking the juice out of your battery and easier on starter.when you prime it ,myself I put the new fuel pump on,and I pull the plug out and put a little fuel in cylinder head so when it fires it pump the fuel up faster to your carb! good luck!
Nov 12, 2014 | Briggs & Stratton Garden
What could keep it from cranking?
change solenoid. check for voltage just because it is new it might be bad
Jul 16, 2014 | Swisher T14560 T - 60" Trailmower with 14...
Help
sounds like engine may be HYDROLOCKED from excess fuel in the cylinder, remove sparkplug and see how it spins over. be sure to ground the sparkplug as to not cause a spark resulting in a fire, PLEASE be careful.
Jun 14, 2013 | Swisher T14560 T - 60" Trailmower with 14...
14.5 briggs no spark
To test for spark remove ground wire from ignition module and test for spark with a proper spark tester. If you have spark the module is good and the problem lies elsewhere. No spark and the module is bad and should be replaced
Nov 09, 2012 | Swisher T14560 T - 60" Trailmower with 14...
My swisher T 60 finish mower with a 14.5 hp Briggs motor just died on me in the middle of mowing the other evening, and I assumed that I'd run out of gas. But, it had about 1/2 a tank. It starts up and...
if an electric pto , the problem is the pto is taking all of the power and robbing the ignition system
indicates a failing charging system or voltage regulator
Feb 05, 2018 | Swisher T14560 T - 60" Trailmower with 14...
Smaller belt on my swisher pull behind mower keeps breaking
make sure it's not coming into contact with any sharp surfaces
Jun 26, 2010 | Swisher T14560 T - 60" Trailmower with 14...
Stops running after 2 minuets
Honda engines have an oil sensor that sometimes fails. It will cause this. If the sensor fails it is like not having enough oil and will kill the engine for protection. Just something to look into. Hope this helps
May 01, 2009 | Swisher T14560 T - 60" Trailmower with 14...
Swisher T14560 T - 60" Trailmower with 14 - 1/2 - Horsepower Briggs & Stratton I/C12 Volt Starter Logo
613 people viewed this question
Top Swisher Garden Experts
lnbn1975
Jim Parker
Jim Parker
Tim Whalen
Are you a Swisher Garden Expert? Answer questions, earn points and help others
