Question about Gateway Computers & Internet
Windows defender quit working on my laptop. DVD player does not work, so I can't reinstall from the back up disk. Anyway to fix this or do I need to get a new dvd drive to reinstall windows vista
  • Gateway Master
  • 7,627 Answers
Was the DVD damaged in so way? Does it show in Computer? Does it need driver? Which Gateway do you have? Windows Defender can be downloaded or fixed online.Do you have a Anti Virus that has turned off Windows Defender? Try MS Fix It: http://support.microsoft.com/kb/931849 OR http://support.microsoft.com/kb/931099
Posted on Nov 28, 2012
  • 324 Answers
SOURCE: CD / DVD player not listed as device on Windows Explorer
Try physically removing the player and fire up the laptop. Power down the laptop, replace the player and power back up. If that doesn't help, see if BIOS recognizes it.
If that doesn't work, get back to me.
Ron-
Posted on Nov 09, 2007
I also have the same problem. I've tried all the above plus some added info. The floppy still works when I swap it with the DVD. Occasionally it works for a short time right after a hard boot but soon after it appears to uninstall. I have searched the net for answers to this problem without success. I tried the registry correction without avail. There has been some online comments that the problem appeared after an auto update from uSoft. I believe the problem is software or firmware related.
Posted on Dec 28, 2007
  • 13433 Answers
SOURCE: Pioneer DVR-K17RS ATA ACER CODE=39
Try to remove the device from Device manager, and then reinstall or upgrade the driver. If the error continues to occur, it may be possible to edit the operating system Registry to resolve the issue.
Click the Start button, press run and type regedit.
  1. In the Registry Editor window, in the left pane, double-click the HKEY_LOCAL_MACHINE folder.
  2. In the HKEY_LOCAL_MACHINE folder, double-click the System folder.
  3. In the System folder, double-click the CurrentControlSet folder.
  4. In the CurrentControlSet folder, double-click the Control folder.
  5. In the Control folder, double-click the Class folder.
  6. In the Class folder, click to select the {4D36E965-E325-11CE-BFC1-08002BE10318} folder.
  7. In the right pane, click to select the UpperFilters registry value.
  8. Press Del / Delete to remove the registery entry.
  9. In the Confirm Value Delete dialog box, click the Yes button.
  10. In the right pane, click to select the LowerFilters registry value.
  11. Press Del / Delete to remove the registery entry.
  12. In the Confirm Value Delete dialog box, click the Yes button.
  13. close the regedit window.
  14. Restart the computer.
Posted on Feb 11, 2008
SOURCE: R40 Thinkpad CD drive
I also have an IBM R40 with a combo drive that showed the same symptoms. I switched the drive with two another two which I can assure that work 100% correctly, and the same problem happens. First the drive wasn't detected some of the times, or it got randomly "disconnected" while the laptop was on. Nowadays (about 1 year ago), the drive never gets detected, not by the BIOS or by the operating system (Linux, but also tried on Windows), even so, If I don't keep the drive disconnected, when the laptop boots the BIOS hangs for a long time like it was trying to detect the drive, but it doesn't. It turns out that is a system board problem. Hope this helps you on finding the solution. Regards
Posted on Aug 25, 2008
hardkiss69
  • 43 Answers
Hi, the error code that you have is a known issue from Microsoft that needs a registry tweaks. Error code means "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (code 39)" . You can click on this link for your reference http://support.microsoft.com/kb/929461/en-us
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:1. Click Start, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue.
2. Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters, and then click Delete.
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters, and then click Delete.
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer.
This will surely help you resolve your issue. Good Luck!!!
Thanks
Posted on Nov 16, 2008
I'm trying to restore my laptop back to factory settings It's windows 7 the cd disk don't recovery disc don't work IT is a acer
You can reset windows 7 password with Smartkey Windows Password Recovery Enterprise, just need 4 steps to reset lost Windows 7 password.
Step1: Download Windows Password Recovery Enterprise and install on any available PC.
Step2: Burn Windows 7 password reset CD/DVD or USB to reset lost Windows password.
Step3. Set your locked pc BIOS to boot from CD/DVD-ROM or USB Flash Drive.
Step4. Reset lost Windows 7 password to Re123456 together with the burned CD/DVD or USB Flash Drive.
May 20, 2012 | Acer Computers & Internet
MASICDISK CAN'T OPEN DRIVER(MCDBUS)
You are getting this error because either you still have Microsoft Defender enabled or your antivirus program is stopping the install of the unsigned driver in 64bit windows. Turn off automatic scan for Windows Defender and disable all options under the 'options'. Uninstall MagicDisc. Now reinstall as administrator. What comes up is a RED box that warns about installing the driver for the virtual disc. If you get this, and click ok, your install will succeed. If you never see this then maybe you did not fully turn off windows defender or your antivirus realtime protection, whatever that is. Good Luck!
Jan 10, 2012 | MagicISO MagicDisc
My netbook n150 plus is displaying "no operating system detected" HELP!
Hello!!
1. To repair it put your Windows 7 DVD to dvd tray (any windows 7 DVD will work oem/retail)
2. boot from it
3. when you reached to the Installation Screen, At bottom You'll find Repair Windows Option.
4. Hit that option and let it do start up repair automatically and let it reboot..
5. on reboot after repair please remove your DVD to let the Netbook boot from HDD rather than DVD.
If the above mentioned solution fails then, you should reinstall the OS.
Jun 05, 2011 | Samsung N150 (36725723009) Netbook
Our computer crashed so we tried to reinstall the operating system back up that we mad when we bought the computer. There are a total f 12 disk which need to be installed. When we got to disk #9 it will...
Looks like a problem occured during backup. Best off to boot straight from windows cd perform a full format and reinstall. After installing windows you will need quite a few drivers. Hopefully a driver cd came with the laptop or you will have to use another pc to download all needed drivers from HP website and copy them to a cd. Hope this helps
Nov 24, 2009 | HP Compaq Presario C304NR Notebook
My burner isn't recognised. We could burn cd's and now all of a sudden when we click burn it says ''connect to a burner and restart player''
Try updating your windows media player and windows update, some of the updates have made the cd and DVD roms to quit working.
Nov 21, 2009 | Computers & Internet
Norton trial has virus.
you should ring acer and send it back to get it repaired.
Jan 10, 2009 | Acer Aspire 5720 Notebook
My dvd drive in my computer won't play dvds
1. Completely remove any dvd/cd player/burner softwares (i.e. Nero, Power DVD, etc.).
2. Go to device manager and remove your DVD/CD device from the device list
3. Restart you laptop
4. Windows will then try to reinstall the device drivers again for the DVD drive.
5. After another restart, then reinstall your dvd softwares again.
Nov 15, 2008 | Toshiba Satellite A135-S4527 Notebook
Problem Installing Printer Driver for Canon MP460
1) relax
2) prove to install nod32 from this site www.nod32.com is a powerful antivirus work very well.
after you have make, please reinstall the driver from this site.
3) http://software.canon-europe.com/products/0010394.asp
Thanks
Sergio
Mar 01, 2008 | Computers & Internet
If you can't restored the driver, you should reload the operating system using Alt+F10 or using disks (not from windows, boot from disks)
In your case, it's look like you can't access the dvd in windows, i hope you can access in dos mode.
Jan 20, 2008 | Acer Aspire 3680 Laptop
Ron-
Nov 09, 2007 | Computers & Internet
Computers & Internet Logo
69 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
