Question about Sony UP-CX1 Thermal Photo Printer
I can't open the paper box of my up-cx1 sony printer
The blue button does not open the paper box. it goes down without opening the paper box. apparently there's no way to open the chassis and solve the problem.
4 Suggested Answers
  • 9 Answers
SOURCE: I have a 2001 sony kp 65wv700 with a DA-4X
Yes
Posted on Oct 30, 2011
gopakumarg43
  • 74377 Answers
SOURCE: Sony MHC-GZR888D : Error C 31 00 & tray not opening
Either its disc loading motor, or the loading belt has the fault. Visit this site for more details. Type in the site name "Electro-help" either Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as Service help to electronic home entertainement equipments.
Pull up older posts. You can get all details.
Site is listed in Google, and you can locate it either at the bottom part of first search page, or at the top of second page.
Click on associated ads too. Sometimes, it might help you.
Sometimes, the disc loading mechanism might need replacement. If so, contact the nearest authorised service center for Sony. The Sony disc loading mechanism can't be bought from open electronic spare part market.
Posted on Jun 01, 2012
  • 3 Answers
SOURCE: I can't open the disc tray on my sony BDP-S580, I keep getting a message that says "TLK ON"
Very late to post, but mayby someone will need this: just hold down the play button for at least 10 to 15 seconds to activate or deactivate the built-in child lock on this model.
Posted on Oct 07, 2012
When I put the paper in, and push the refill button, the paper goes down in the printer crookid, I need help does anyone know what I could possibly do?
Leading cause of paper jams or misfeeds is debris / foreign objects that accidentally fell into the paper feed area. Please try this approach to fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
  3. If you're willing and physically able, you may also carefully turn the printer over. Any debris should just freely roll out from the feeder.
  4. If feeder is clear, place the printer on the table. Open the printer cover and remove the cartridges.
  5. Check the cartridge area for any obstructions in the paper path.
  6. Close the printer cover.
  7. Re-brick your printer by pulling out the power supply - the black box where the power cord is plugged into. Re-plug after 30 seconds.
  8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again to verify that the problem is fixed.
Oct 07, 2011 | Lexmark X2500 All-In-One Printer
Dell 1350cnw printer paper jam error and no paper visible.
Not sure if this will help, but I resolved mine in the end by opening the toner compartment and removing all of them then popping them back in. I also 'scrubbed' some sensors via a blue pullout bar in the toner area.
When I started up the printer, I then held down the Red X button until it said 'ready to print'. It's working fine now.
HTH,
Tony
Aug 03, 2011 | Dell Office Equipment & Supplies
Canon printer mx328 is when i scan it display ''the paper output tray'' what mean and how to clean it. Please help.
Hi
If the Paper Output Tray is closed, open it. The machine resumes scanning.If opening the Paper Output Tray does not resolve the problem, or if the tray was open to begin with, the paper may be jammed. Remove the jammed paper, reload paper properly in the printer, then press the Black or Color button.
Cheer
Jul 12, 2011 | Canon PIXMA MX310 All-In-One Printer
How to reset the pixma mp140?
hi
This is the solution for the problem you have asked for
Just do the following:
  • Disconnect the power supply to the printer by removing the power lead from the back
  • Press and hold the Power Button whilst plugging the power lead back in, then whilst continuing to hold the button down press the Reset Button (the one with the red triangle inside the circle) twice
  • Release the Power Button and after around 10 seconds the display will show '0'
  • Press the + Button to change the value from '0' to '1'
  • Press the Colour Button; you'll notice that both the A4 Plain Paper and A4 Photo Paper LEDs will now be on
  • Make sure that there is some paper in the paper feeder
  • Press the Power Button twice; the printer will now print some random information which you can discard
  • Now open the printer cover (not the scanner cover) and remove the cartridges. With the printer still open, remove the power lead from the back of the printer once again
  • Close the printer cover
  • Replace the power lead and press the Power Button to turn the printer back on
  • Now replace the cartridges and the ink level monitor will be reset
DO Rate my solution
Jun 30, 2011 | Computers & Internet
Blicking light canon d480
try this
Turn off the printer.
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Also open the back cover of the printer if this model has one.
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 18, 2011 | Canon imageCLASS MF3240 All-In-One Laser...
Print carriage access door is open or ink cartridge cover is open. getting this message but nothing is open!! It says to hold down ok button for 5 seconds but nothing is happening. I turned off but it...
Turn off your printer
Open the cover
1 move the cartridge carrrier manually to the center manually with your hands from left torgiht ( 5x )
2 .Remove the cartridges used a clean paper make sure its dry wipe the area where the ink goes out make sure its clean .CLean also the area where you return your cartridges make sure its clean OK .
3 >return it properly close the carrier properly make sure there's a snap sound produced .Move again the cartridge carrier manually from left to right 5x
close thecover
try to turn it back on
in case nothing happens
remove all the parts cartridge ,black box paper power supply
lift the printer up turn it up side down make sure the cover is open when you lift it up and turned it upsidedown
so any foreign material will come out
Shake it for 5x
\return all the parts
try to power it on
Hope it help thanks
May 26, 2011 | HP Officejet Pro L7680 All-In-One Printer
I lost my installation cd for my x2470 printer. I do not have money,is there a way to install it witout a cd
    • Step 1 Open your web browser and go to Lexmark's "Drivers and Downloads" page (see Resources section below). Locate the search box labeled "Search by Model" and enter X2470. Press return. Select your operating system from the pop-up menu. Wait for the download page to load, then click the "Download Now" button. Save the installer file to an easily accessible location.
    • Step 2 Rotate the printer so that the rear section is in view. Connect the power cord to the power cord connector located on the right. Plug the remaining end of the power cord into an electrical wall socket. Connect one end of the USB cable into the USB port located on the left. Rotate the printer back into place.
  • Step 3 Turn on your printer. Extend the paper guides and insert paper into the tray. Readjust the paper guides so that they are flush with the paper.
  • Step 4 Lift the scanner unit and wait for the print cartridge holder to move into view. Push down on the light blue lever to raise the cartridge holder lid. Install the ink cartridge into the print cartridge holder. Close the cartridge holder lid and lower the scanner unit.
  • Step 5 Connect the remaining end of the USB cable into any available USB port on your computer. If any "Add New Hardware" screens appear on your computer, click "Cancel."
  • Step 6 Open the previously saved installer file and follow the onscreen instructions.
  • Step 7 Locate the button on your Lexmark X2470 that looks like an open scanner pointing to a computer monitor. Press and hold this button for three seconds. Follow the instructions that appear on your computer. Once this is complete, your printer is ready for use.
May 23, 2011 | Lexmark X2470 All-In-One InkJet Printer
Out of paper error
The paper settings in the print driver must match what is loaded in the product. NOTE: These changes do not change the default print settings. The print settings return to default the next time the program opens.
  1. Open the document that you were trying to print when the issue occurred.
  2. Click File , and then click Print . The Print dialog box opens.
  3. Click the button that opens the Properties dialog box. Depending on the software program, the button might be Properties , Options , Printer Setup , Printer , or Preferences .
  4. Click the tab that provides paper type and size settings. The tab might be Features or Paper/Quality .
  5. From the Size is drop-down menu, select the paper size that matches the paper in the tray.
  6. From the Type is drop-down menu, select the paper type that matches the paper in the tray.
  7. Click OK , and then click OK again to print the document.
Nov 23, 2010 | HP Photosmart 8250 InkJet Printer
Cover door open Now paper wont pull down or jams
Sounds like something stuck in paper path, check paper feed area for any obstructions.
Dec 29, 2007 | Lexmark X3470 All-In-One InkJet Printer
Sony UP-CX1 Thermal Photo Printer Logo
23 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
