Question about Plantronics CALISTO P540M - Usb Deskphone Moc 82783-11
Using a P540M with MS Lync, can a call be transferred to another # from the handset or only from lync the dialogue box?
In either case, would the number have to be in the contacts list or can it be manually entered?
  • David Hechter Nov 30, 2012
    When using MS Lync for voip on the computer, a dialogue box opens with each incoming or outgoing call; one of the functions in the box is a transfer call button which will send the call to someone else on Lync and in contact list; when using the P540 handset, is it possible to transfer the call using the handset instead of having to use the dialogue box on the computer.The handset instructions only mention call waiting and hold.
Why does system seem to reboot on its own?
check that you allocate a fix IP in the router. At times it could be re-allocated to a dynamic IP and this cause the failure to maintain the connection.
Oct 24, 2014 | Polycom HDX 7002 XLP HI DEF-VIDCONF Video...
Best IT Training institute in Noida
I suggest you see the career adviser at the IT Institute and ask them what choices are available.
Feb 18, 2013 | Computers & Internet
Wrror message C13:01. Keep saying insert memory
First you have to find out if the problem is caused by the camera or by the MS. Replace the MS. In case of wrong MS you may restore photos in some card reader using some freeware restoring SW. In case of wrong camera check pins for MS in the slot.
Oct 18, 2009 | Sony Cyber-shot DSC-W100 Digital Camera
Download contacts and pics to computer
we would like to inform you that please try following steps to transfer Contacts from Phone to PC.
Using Motorola Phone Tool Software
• Select Data Connection i.e. Main Menu > Setting > Connection > USB Setting > Data Connection
• Connect your handset with PC through USB Data Cable.
• Run Motorola Phone Tools > Phone Picture will appear on your PC.
• Click on Phonebook icon which will be available on the right side of your Phone Picture
• Click on that and transfer all contacts on left side in MS outlook or outlook express
• After transfering data clsoe MPT disconnect the handset and connect the another handset and follow the same process but in this case you have to transfer data from MS outlook or Outlook express to phone means Left to right.
Thanks
Mridul.......
May 18, 2009 | Motorola Mobility SLVR L7 Cellular Phone
Trust web cam want driver
First off,.. Yahoo messeger is evil . It really is bad for a computer,.. but if you insist,,,
if you need a driver tell me what kind of camera it is,....or any numbers etc that are on it.
You can choose one from the following lync if ya like,...
http://www.usb-drivers.com/
Jan 15, 2009 | Computers & Internet
Plantronics CALISTO P540M - Usb Deskphone Moc 82783-11 Logo
32 people viewed this question
Top Plantronics Lands Phones Experts
Andrew Taylor
Andrew Taylor
Are you a Plantronics Lands Phone Expert? Answer questions, earn points and help others
