Question about Mintek DTV-373-D 37 in. LCD HDTV
My dvd is stuck I can't change back to Tv mode
Can't change mode remote is not changing nor is the tv buttons. sound will not go up or down dvd is stuck can't switch to tv, stop or adjust nothing.
  • 1,074 Answers
Take out the plug and try it again if that does not work take it to a tech the chip is faulty.good luck.
Posted on Jun 07, 2007
How to switch back to TV mode from DVD
Use the remote controls' TV/AV button, or input select button; to select the inputs.
Sep 17, 2014 | Proscan Televison & Video
ORION STV2555 No Remote. How to change TV to DVD mode?
You must ahve its remote control to select input.
Apr 18, 2012 | Orion Televison & Video
My remoute control joust change the volume and anyother keys doesn't work.
The remote's volume keys are "punch-thru" keys, meaning they'll work for the TV for which the
remote is programmed no matter what mode the remote is in. It seems your remote is not
in "TV mode," but the punch-thru keys (volume UP/DOWN) are working.
The Solution: change the remote from "AUX mode" or "DVD Mode" back to "TV mode", by
pressing the "TV" button at the top of the remote.
Either that, or your remote keypad has failed with the exception of the Volume UP/DOWN keys....
Also, your batteries may be failing, since it takes a tiny amount of energy to light
the IR (infra-red) LEDs at the front of the remote to change the volume.
Is your remote a "multi-function" remote?
Could help more if you could post your Samsung remote model number, since lists 37 pages of TV remotes (at 10 models per page).
Jul 02, 2011 | Samsung TV Remote Control
While watching a dvd on the Q2035a I was using a seperate dvd player and I use a universal remote for both the dvd player and Q2035a. I began to adjust settings for the dvd player using the univ. remote....
Hello, It sounds like when you pressed the remote you inadvertently changed the scan on the ctv. This can cause the ctv ( colour tv ) to change from say ntsc to pal or similar. Even a reset button wouldnt help as it sounds like it is within the setup menu. You could try, as I have done this myself with a similar problem, disconnecting your dvd and putting it aside. Then, pressing the remote when in tv mode and watch for any change in screen flicker etc. If you have the original remote for ctv use that. If as you say, the tv goes to standby mode, you may have damaged the power supply, as the power supply will shut down to standby at any sign of a short.
Mar 23, 2011 | Televison & Video
Toshiba television will change from tv/video mode to
I would check to see if the Input button is stuck on the front panel of TV. If it is not stuck then it is probably still bad. Tactile switches are notorious for failing in this manor. The only real fix if it is not stuck down is replacing the switch.
I hope this helps,
Jun 22, 2009 | Toshiba 36A43 36" TV
DVD does not work with TV - invalid format error
Make sure that there are no discs in the player.
1. Turn it on
2. Press "Setup" on the remote
3. Press the down button twice on the remote
4. Press the right button once on the remote
5. Press the up button once on the remote
6. Press "Ok" on the remote
You should now be back into interlace mode.
Apr 13, 2009 | Televison & Video
Picture is split -- says P-SCAN. It's stuck
that means it is stuck on progressive scan.  If your tv is not able to handle progressive scan, you need to change it back or reset the player.
The DVD player may be set to Progressive Scan Mode. You will need to change it to Video Mode by using the remote control. Point the remote control directly at the DVD player, and then press the PSCAN button 2-3 times. If you are still encountering problems with the DVD player, reset the unit back to the default setting.
To Reset,
Make sure you do not have a disk in the tray. Using the DVD player remote control: 1) Press the “Setup” button. 2) On the “Down” arrow, press it three times. 3) On the “Right’ arrow, press it once. 4) On the “Down” arrow, press it three times. 5) On the “Right” arrow, press it once, then press “Enter”. 6) Press the Setup button. *The default setting will take affect as soon as you press the setup button (step 6).
Hope it helps..please rate!
Mar 07, 2009 | Coby DVD-224 DVD Player
Can't Change Inputs on TV
make sure that your remote is on the tv cotrle mode rather than the dvd control mode
Nov 10, 2007 | Mintek DTV-323-D TV
Black screen
It really sounds like the child lock has been activated. This uaually blocks the keys on the TV, but the remote should work. If your remote doesn't work either, make sure the batteries work. If your remote for the TV can operate other apliances such as a VCR or DVD player, make sure it is in TV mode. If there are any buttons marked TV, VCR, DVD you could try pressing the TV button to set it in TV mode. If the To has a text-tv function there might be more than one button marked TV; one for setting TV mode as posed to DVD operating mode, and one for getting TV picture back when viewing text pages. -Chris
Feb 27, 2007 | Apex Digital AT2008 20" TV
Mintek DTV-373-D 37 in. LCD HDTV Logo
204 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Jason Morris
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
