Question about Canon PC-735 Copier
Canon PC745 - only 1/4 image being copied- when hand fed if I hold the paper back awhile then the image is alright, how to correct the travel?
5 Suggested Answers
SOURCE: image print on paper slanting
Does it only happen when you copy through the auto feeder or from the contact glass too? If it's just from the feeder, then the rollers in the feeder are slipping and not feeding the paper straight, and need to be cleaned/replaced. If it happens from the contact glass, then it is most likely the rollers that move the paper through the machine that need cleaning - primarily the registration roller, but really all rollers from the paper tray to the exit should probably be serviced, and/or replaced where necessary.
Posted on Jun 06, 2009
wrinaldo
  • 185 Answers
SOURCE: My Canon ImageRUNNER 3225 does not print correctly
Is it ok when you just put the document on the glass? If so, the Document feeder needs a whole set of rollers.
Otherwise the document scanner may be bad. This needs to be changed out by a technician.
Whit
Item, Inc
Posted on Sep 17, 2010
  • 51 Answers
SOURCE: My canon ir 2018 is asking me to load correct
Check the proper orientation of the paper. For example, if you are loading A4 size. In your tray you can find 2 A4 size. Select A4R in you want to position your paper Landscape or A4 if portrait.
To verify also the correct paper size, put your paper on the platen glass. Markings on the two sides of the platen glass shows the correct paper size.
Posted on Oct 05, 2010
badfrankie
  • 92 Answers
SOURCE: paper is not being fed from paper holding drawer.
It sounds like the feed tire is dirty, OR the feed clutch has sprung. Remove the paper tray On the right side of the copier where you feed the single sheet, you pull down the door. This exposes a fat gray or black feed roller. Take a clean dry towel and dampen it with wd 40. Gently wipe the roller with the cloth turning the roller toward the paper exit direction. Let the WD 40 soak in for ten minutes, replace the paper tray and try to make a copy. If it does, you need a feed roller which will rquire a service cal/take it in. If still no feed the 'clicking' may be a sprung clutch, service call required.
If this helps, please let me know with a vote, thanx
Posted on Jan 31, 2011
Photo paper doesn't feed correctly
What about the normal 80g office paper? If also bends and jams in the printer, I think it is a mechanical problem. Check the paper path for foreign objects. It is very easy for common office objects to fall there. Also they are not vizible when fallen in the printer. Try to turn the printer upside down to let the object to fall out. Help it with some flat scredriver to release the paper pressure shafts which springs may hold the object inside
Apr 08, 2012 | Canon Pixma MG5220 InkJet Printer
Paper is not being fed from paper holding drawer. sometimes makes clicking sound. Copier does work when single piece of paper is fed through right hand side of machine
Jan 30, 2011 | Canon PC-980 Color Copier
Canon mp160 paper always feeds skew, can the paper be fed from the bottom instead of the top thanks Peter
Solution obtained on cannon website-paper can only be fed from top(back).This is a common question as the paper tends to feed skew.
Feb 08, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Hp Deskjet F4480 continually reads out of paper even though its not and will not print. This problem occured only after I refilled the cartridges and put them back in.
Ok, I had this problem too and it started after I replaced the ink cartrtidges. The printer had a flashing light and the software read "out of paper". I can't be exactly sure what fixed it but here's what I did: I unplugged the printer while it was still on and left it unplugged for several hours (several minutes should have the same effect of clearing the device's memory, I just had to go to a meeting). I then plugged it back in and the printer fed the paper, but was feeding it sideways. I removed that paper and put a single piece of 4x6 photo paper in it and it fed that paper sideways also, crinkling it up. I tried a few more times by hitting the 'Cancel' button which would cause it to try to refeed the paper. I then checked the back of the printer and discovered the back panel had come loose at some point. I replaced it and the printer then fed a sheet correctly and printed the alignment page. I think the thing that fixed the issue was leaving the machine unplugged for awhile.
Feb 07, 2010 | HP Office Equipment & Supplies
Won't photocopy / warning light flashing /
The paper feed system is worn (rollers, and separation pad). What is happening, is extra sheets are being fed into the machine primarily because the separation unit is not doing it's job properly. So rather than just one page at a time being fed, it is allowing an extra sheet to "creep" in intermittently, causing the jam. And the indicator you are seeing is the "jam" indicator.
Jul 16, 2009 | Canon PC170 Copier
Canon pc 420 paper feeds only part way
I had the same problem. I found a parts diagram here http://techno-parts.org/canon/220/320_220.php which showed that the springs hold the bar down. On mine, on each side, one of the spring tabs was broken.
I made a metal pin for one side and insert a screw on the other. Be sure and wrap the spring over the nylon bushing.
May 26, 2009 | Canon PC-420 Copier
Paper is repeatedly jamming, won't print
Dear friends,
This problem caused by any other material (such as broken paper) are present in paper path blocking paper from being fed and reaches paper sensor. Please check paper source area carefully. I have met this problem so many times. Remove the material. Printer will normally work if paper sensor not broken.
Dec 03, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Cannot reduce size from 11x17 to letter
The NP6551 is an analogue copier, using only mirrors and lenses. It has no way of rotating the image. If you want to reduce a 11x17 to a 8.5x11 both peices of paper need to be fed in the same direction, ie short edge first. Change one of your trays to LTR-R ('R' for Reduction) or feed the LTR paper in thru the bypass in the long direction. If you use te bypass you must specify the paper size as LTR-R, you cannot use FREE.
Jul 26, 2008 | Canon NP 6551 Black and White Copier
Bad print with repeated text on fax or copies
Make a copy and shut the power off or open a door when the paper is 1/2 way into the machine. You are just basically going to have to try to time it. When you hear paper being fed into your machine (the blank paper from the tray) count about 3-5 seconds and then open a door on the machine or shut the power off. IF you have timed it correctly, the paper should be 1/4 - 1/2 way through the machine. Remove the jammed paper **** But be careful..... The toner is NOT FUSED at this point so it will rub off if you brush it up against your clothes or hands. If the image is doubled at this point.. then its the drum unit. If the image is good at this point, then it is probably your fuser.
Hope this helps.
Good luck.
Mac =)
Apr 02, 2008 | Brother IntelliFAX 2800 Laser Fax
Not print or copy
posible a small piece of paper jam in the senzor. check please the entire paper path
Oct 17, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Canon PC-735 Copier Logo
37 people viewed this question
old marine
old marine
