Hi I have an goodman model capf036a2a furnace and I have replaced the capacitor and blower motor. When I turn on the heat the furnance lights and runs but the blower motor doesent start which trips its off and says roll out limit switch. What do I need to do
  • Robert Nov 28, 2012
    You csn try to use the hum or EAC terminal on the board as a temporary fix, these terminals provide 120 volts.
    Genius:
  • 1,033 Answers
Verify if you have 120 volts from the control board. Easy way to check is to bypass the board, you can do this by using a small wire and jump the L1 wire with the low speed motor wire, if the motor starts up the board is bad and will need to be replaced. You can also use a meter and check voltage between the low speed motor wire and the Common wire which is typically white in color. If you do not have voltage the board is bad.
Posted on Nov 28, 2012
  • 5 more comments
  • roderrick roberts Nov 28, 2012
    Where is the L1 wire?
    It is the wire coming from the door switch on the Furnace to the control board terminal labeled line or L1
    I tryed that and it didn't work
    Did you make sure the dorr switch was pressed in?
    Yea it just turned on the furance the blower fan didn't turn
    It should not turn on the furnace at all, all we are doing is providing power directly to the motor, so either the motor starts or nothing turns on.
    If you tske the L1 wire off the board and jump it with the motor wire there is no power to turn the Furnace onon
4 Suggested Answers
  • 96 Answers
SOURCE: I have a Goodman furnace
limit switch is on the heat exchanger black plastic about 1and1/2 in. by 2 in. with 2 wires going to it , it has 2 screws holding it in take it out and check it with an ohm meter and you should not have a reading if it is good
Posted on Feb 01, 2009
machtcl1
  • 61 Answers
SOURCE: Goodman furnace GMPN080-4 Getting 4 RED blinks/Open Limit Swtch
You have a limit switch located in the furnace (a little bigger than a dime and located near the center of the front panel, sometimes the switch is mounted to a small fiberglass board) . There will be two wires going to it. They sometimes trip so often that they fail to automatically reset(due to dirty filters or undersized ductwork). You can SHUT OFF POWER TO THE FURNACE, then remove the two screws holding the switch in the furnace, pull the switch out of the furnace and tap on it and wipe it off.
The switch may work a few more times but should be replaced with the same size and type. You will see some rating printed on the switch somewhere. Write down all the numbers and get a replacemet from a furnace/AC supply house. If you have a meter and know how to use it you could check the switch for continuity.
Sometimes just a tap on the switch will get it going. There will also be a couple of rollout switches that could be tripped. They have little buttons on them to reset them. If they trip it may have other issues to be solved.
Hope this helps!
Matt
  • 1033 Answers
SOURCE: hi i have an goodman capf036a2a furnace and when i cut on the heat the burner light but the blower motor doesnt turn its makes a humming noise and the code it reads is #33 roller blowout. do i need t
Since the motor is humming we know it is recieving voltage, try spinning the blower wheel by hand and see if the motor starts up, if it does the capacitor needs to be replaced, if not the blower motor needs to be replaced.
The is gas is going off and every 5 min. i put new thermostat. model # capf036a2a, brand name goodman
Check the thermostat set up ..some has to be switched either by set switch on back or through the initial set up program of gas furnances. It appears as though it is set on a short cycle by default. Follow the instructions to the T. Make sure you have the proper thermostat for your type unit. some are for gas, some are for heat pumps, some are for oil, others are switchable with settings.
Dec 20, 2016 | Goodman Heating & Cooling
Trouble locating the air filter in the Goodman heating unit. CAPF036A2A
it will behind return air grille either in the room, ceiling, & i have seen them in attic in return plenum.
Feb 10, 2015 | Goodman Heating & Cooling
How to fix goodman furnance A30-15 the blower wont turn on ?
Check capacitor, cheap replacement and easy to do, also spin blower wheel by hand to see if it moves freely. If so could be Cap. U can also try canding blower speeds to see if one of the speeds burnt out. Warranty??
Jun 09, 2014 | Goodman Heating & Cooling
Need the year of my furnance, have the model and serial number
manufacture can tell you year. what brand is it? goodman? my guess is 97 dec.
Feb 26, 2014 | Emerson Lennox Ducane Armstrong Furnace...
Blower motor makes noise, but does not work goodman
its either a bad motor or bad capacitor if you try to spin the wheel by hand and it starts then its the capacitor
Dec 26, 2012 | Goodman Heating & Cooling
Hi i have an goodman capf036a2a furnace and when i cut on the heat the burner light but the blower motor doesnt turn its makes a humming noise and the code it reads is #33 roller blowout. do i need to...
Nov 28, 2012 | Heating & Cooling
I have a Johnson aire ease ultra 90 gas furnance. I also have a outdoor wood furnance that has its own thermostat. On the original thermostat I turn the blower in the on position. I then set the outdoor...
I would first eliminate one furnace from the equation, the exterior wood furnace... turn its tstat down. Will the gas furnace then operate normally? Can you run the blower manually, as in summer mode? Make sure your filters are clean also... that can sometimes overload the blower.
Apr 12, 2017 | Heating & Cooling
Where is the reset switch on my Goodman CAPF036A2A?
You can reset the controls by cycling the power off and then on again...
There also is a reset by the burner and one by the blower...push in the little red button in the center on the limit switch...
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
Mar 06, 2011 | Goodman GMS90703BXA Heater
I have a Goodman furnace GMPN080-4 REV B. I had the blower motor take a dive, so I replaced it with another equivalent 115 VAC 60 Hz 1/2 HP motor. I replaced the 10.0 MFD +10% -5% capacitor with a 7.5 MFD...
Feb 01, 2009 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
97 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
