Question about Danze Plumbing
Replace cartridges in water ridge bathroom sink faucet
  • 68 Answers
SOURCE: Rohl 3810 kitchen pullout faucet leaks under the sink
ouch sadly im sure it was pricy to have him out  so my suggestion would be to call him back and have him take off the price of what he charged you or have him fix it for no charge could be just need some plumbers putty around the faucet to stop a little water that may seep threw under the faucet good luck
Posted on Apr 12, 2009
  • 6 Answers
SOURCE: can't remove moen bathroom faucet assembly to
If you are dealing with the type of Moen faucet I think you are, what you need to do is remove the pop-up rod. do this by loosening the locking bolt on the linkage under the sink and pulling the rod out from the top. Once the rod is out you will need to find the correct size allen wrench which goes into the center hole. there is a mounting bolt in there that needs to be unscrewed. Easy when you know how.
Posted on Jun 17, 2009
snap101
  • 117 Answers
SOURCE: I just installed a new cartridge in a moen single
try and pull the cartridge out and look in there with a flash light and make sure there isn't any think lodged in the hot water side of the faucet, you might even want to leave the cartridge out and turn the water back on to try and flush it out. alot of times rubber from the old cartridge gets stuck in there as you are pulling the old one out especially if it's stuck in there good
Posted on Jul 29, 2009
  • 3 Answers
SOURCE: I have a Moen Monticello bathroom faucet. I am
Moving left to right: I am not an expert, but I have installed a fair number of faucets. Seems like a basic issue of just getting under the sink and tightening up. Make sure someone is topside to assure the faucet stays straight and does not move as you tighten up below. It is never easy to get a wrench and your hands in the proper position to tighten up the nut, but don't give up try a smaller Channel lock wrench if necessary.
Sink Stopper: http://www.lowes.com/lowes/lkn?action=howTo&p=Improve/PopUpStop.html
Posted on Jan 03, 2010
jyackle5
  • 8197 Answers
SOURCE: Kohler Fairfax single control kitchen sink faucet
Remove the air-irater at the end of the faucet where the water comes out. That is where 99% of clog are on faucets. If that does not do it then you need to replace the cartridge.
Good Luck and please rate 4 thumbs up for the free answer.
Posted on Mar 19, 2010
My pfister shower cold water faucet handle broke off. The stem is stuck so I can't replace the faucet handle. How do I remove this stuck portion of the old handle?
the model is needed for a step by step but. if your faucet is for a sink and not a shower then the handles may be connected to the pour spout or separate depending on model and in either case there is a nut screwed under the fixture that hold it in place. do not unscrew any of the faucet until you have turned of the water running to it.
here are links to the different types
Price Pfister Bathroom Sink Faucet Repair
Moen 4570 Handle Fell Off But Then Fixed It Here How
How to remove kitchen faucet
and just in case it is a bathroom fixture
Maintenance How to Remove Replace Cartridge on Single Handle Tub Shower
Sep 03, 2017 | Plumbing
My bathroom faucet leaks a drop of water every 30 seconds
If you live in a hard water area, you probably have some buildup on the seals. You might be able to clear it by just running water through it, but most of the time, you might have to take the faucet off and soak in vinegar or replace the seals/cartridge.
Sep 26, 2011 | Moen Bathroom Sink Faucet - 4-inch...
My cold handle on a montecello faucet turns freely, however, nothing happins I have no cold water. What do I do?
First check that the handle is tight. If yes take the handle off and turn on the water buy turning the stem without the handle if you still do not have water remove the stem and cartridge and see if you have water if yes clean or just replace the cartridge. If the faucet in old replace both.
Mar 15, 2011 | Moen Bathroom Sink Faucet - 4-inch...
My classmate
Moen Monticello 4-inch centerset bath faucets can be repair easily with only a screwdriver and adjustable wrench. Turn the water off to the both sides of the faucets under the sink. Open both the hot and cold-water valves to alleviate any remaining pressure. Remove the handles by grasping the base of the handle and turning it counterclockwise.( This works for both lever and cross handles). Loosen the Moen faucet cartridge bonnet nut with an adjustable wrench by turning it counterclockwise to the left. Pull the stem from the faucet by hand and replace. Reinstall the bonnet nuts and handles. Turn the water back on and test the faucet for leaks. The Moen Monticello faucet comes with a limited lifetime warranty. Try calling Moen to get your replacement parts free.
Dec 09, 2010 | Moen Bathroom Sink Faucet - 4-inch...
How to disassemble the delta single handle bathroom faucet
Before taking it apart, you need to turn off the cold and hot water valves under the sink. Once you have done that, open the faucet and let the remaining water run out into the sink. Since I am not sure what the age of your faucet is. I will be using instructions for a common Delta faucet.
1. There is a hole towards the bottom of the handle in the front. It may have a plastic button there. If so, pry the button off with a very small flat head screwdriver. Try not to damage it.
2. If your going to replace the seals, it is best to by the rebuild kit that comes with a special tool. It includes the allen wrench and spanner wrench in one. And all necessary parts to rebuild it.
3. Once you get the handle off, you will see a dome shaped part with two notches in it. It may have ridges on the side of it. That is the special fitting that holds all the parts down.
4. Remove the dome shaped part with the tool provided with the parts kit.
5. Replace all parts that match yours.
6. Install everything in reverse order and you should be good to go.
Don't forget to vote
Everyone have a great Thanksgiving
Nov 23, 2010 | Delta Home
When hot water is turned on the pipes make this vibrating sound. i have two sinks in my bathroom. When I turn the hot water on on sink 2 the pipes vibrate. Sink 1 is fine.
There is a loose washer in the faucet...this flaps as the water goes through it and makes the vibration...
You either need to replace the faucet or the cartridge (washer) in the faucet that valves the water...
This will stop that vibration and hammering sound
heatman101
Aug 22, 2010 | Kohler Plumbing
Water leaks around the hot water handle when I turn on the water.
what valve do you have. most likely you will need to replace the cartridges
Jul 28, 2010 | Kohler Forte Two Handle Centerset Lavatory...
How do I get to the valve cartridge to replace it?
how to replace moen cartridge for two handle kitchen faucet ... cartridge for two handle kitchen faucet exporters,how to replace moen cartridge for two handle kitchen faucet suppliers,how to replace moen cartridge ...cn-faucet.com/ kp-how-to-replace-moen-cartridge-for-two-handle...
Mar 17, 2010 | Moen Bathroom Sink Faucet - 4-inch...
Very low pressure when turn on the hot water faucet in sink
Shut off the water supply and open your faucets, and apply air pressure (min. 30psi) to dislodge any blockage in the pipes.
Oct 23, 2009 | Plumbing
Plumbing Logo
118 people viewed this question
Top Danze Plumbing Experts
David Wiebe
Level 1 Expert
Donni Steen
john h
Are you a Danze Plumbing Expert? Answer questions, earn points and help others
