Question about Samsung Refrigerators
Spring is not working on the ice maker lever on the outside door
When you push your glass for ice the lever sticks and doesnt return it jams with ice ????
  • Anonymous Mar 22, 2014
    I have the replacement part for the ice chute door and spring but do not know how to replace it. How do I access the area and replace?
    Top Expert:
  • Samsung Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 28, 2012
HVACRH20
  • 237 Answers
SOURCE: Ice maker
Can you open the door by hand or is it stuck shut? Check this site for a diagram of the area to help you see inside the door mechanism. http://www.partselect.com/MultiModels.aspx?ModelNum=MSD2756G&searchTerm=img_A58-10&RefineSearch=0&imgMfg=Maytag&Page=2
Posted on Nov 27, 2006
  • 183 Answers
SOURCE: IC6 ice maker
No, completly deforst the freezer for 24hrs this will resolve the problem, i know its frost free, but still try to defrost this usaully resolves this fault Regards Advisor
Posted on Aug 21, 2007
watugot
  • 290 Answers
SOURCE: GE Icemaker flap door won't open causes ice jam in chute
There is an electric solenoid that opens the door. If you look up inside the dispenser you can see the solenoid. Either the solenoid is bad or the dispenser module that puts power to it is out. You will need to remove dispenser front and check for voltage to solenoid. If you have power from module, replace solenoid, if no power, replace both parts. It is common for solenoid to short out and damage the module so that both must be replaced. If solenoid is shorted and you replace module, new part will fry.
Posted on Oct 02, 2007
SOURCE: Ice Maker does not open rubber flap in door to let ice out........
I have a Frigidaire Gallerie side by side with Ice and water through the door. I am getting no water to the ice maker or water dispenser. I have checked and water is getting to the bottom of the fridge through the copper line but is not going through the lines to the Ice maker or door.
Posted on Sep 10, 2008
SOURCE: ge profile refrigerator ice maker
I have a GE Profile PSW26P Stainless Steel Side by Side refrigerator that makes plenty of ice but will not dipense when the lever is pushed. The dispenser makes not sound when engaged. What do you think the problem is.
Posted on Nov 09, 2008
Why does ice dispenser stick?
I dont know what brand you have. But there is a springlever to return the lever to closed posision. Eather the return spring/mechanism is broken. Or has become loose from the fastnerclips holding it in place. I have also seen that ice is the reason for this. Iceing around the very top of the lever.
Feb 17, 2016 | Refrigerators
Ice maker makes ice and dispenses to ice bucket but will not dispense from the door
Check that the motor is connecting to the drive and isn't broken. Also. Check to make sure no frozen chunks are jamming the auger
Oct 07, 2015 | Refrigerators
The ice dispenser keeps going after I remove a glass.
does the ice auger still move(motor) or does the ice just fall out for a few moments after you release the drinking glass trigger ?
reason I ask is: there is a mechanical clock spring motor inside that controls a door to shut off the freezer from the outside(kitchen) , and ive seen rust/time ruin many of them (sticks open) there not too expensive and not too hard to change , usually just two Phillips head screws
this is not well for a few reasons , 1 it allows ice to continue to fall out of freezer and 2 it never shuts the freezer off from the kitchen so appliance runs more to freeze the freezer , also it makes for some drips on floor as well from melting ice
Oct 01, 2015 | Frigidaire Refrigerators
Diagnose GE Ice maker works makes ice! continues to eject ice when glass is pulled away in door
The switch is probably sticking. It may be the lever is sticking.
Oct 12, 2014 | Refrigerators
I have a problem with my Kenmore side by side refrigerator model # 106.56926600. The icemaker when pressing the dispenser lever from the outside of the door.I hear the ice coming from the ice maker to the...
Your question is worded in a way that I might not be interpreting it correctly. I am guessing that it is making ice but not dispensing,or going into your glass when you push the lever, right?
So when you push the ice dispenser lever do you hear a "click" like you do when you push the water lever? Push them slowly and listen.
If no "click" is heard then it is most likely the bracket that holds the dispenser switches. It is made of plastic and very prone to breaking over time especially if children are using it. Part# is WP2180226 and be aware that this is under live voltage so if you are not mechanical then do not attempt yourself and please call a pro to fix.
If you hear a "click" then can you hear the motor turning inside? If yes then it could be something as simple as a block of ice stuck in the bucket preventing the ice from coming out. The owners manual recommends to dump the ice to avoid this roughly every two weeks but most people never do.
Jan 27, 2018 | Kenmore Refrigerators
Ice maker not working just changed the filter water works but ice maker not working
Check the plastic lever on the door. It usually moves closed when the door is shut to turn ice maker on. The lever can freeze and stop the ice maker.
Sep 23, 2013 | Whirlpool Gold GI6FARXXF 25.5 cu. ft....
GE Side by Side only dispenses crushed ice
remove the ice cube tray assy, remove all the ice, save the cubes, wash the assy with warm water dry the assy, be sure the lever in the rear of this ice cube assy is moving and spring loaded, move the lever and it should snap back and return if so you know the unit is ok(the cube assy), now with the assy still out of the freezer close the freezer door and select crushed ice and push the pad where the glass normally hit to activate the ice cubes,if the operates and you here a thump and snap and hum most likely your ok,if not you could have a defective auger motor assy,but if you here all the sounds as decribed oped the freezer door and select cubed ice push actuator on despensor door with the freezer door closed, reopen and install the ice cube assy tray bucket assy,push it in firmley, and try it with some ice in the bucket you should be fine,if not replace auger motor assy..
nbcrca:)
Apr 11, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE profile refrg. with ice maker
Too much ice, maybe the ice maker didn't connect right, the gears moves but the spring inside the ice maker won't move.
Jul 08, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker dispenser door
you need an ice duct door spring and selenoid call ge at 800-851-6200 about 40 dollars for parts they go in the freezer door despenser area
May 07, 2008 | Hotpoint FFU00 Side by Side Refrigerator
Ice maker does not make ice and the in-door water is not working properly - it keeps running.
the water in the door problem after you fill up your cup with water it keeps running all over the floor.. it sounds like its a stuck contact on a micro switch inside the door compartment. that lever you are pushing your glass onto is atached to a little switch and if the contacts stay closed (like when a glass is pushing on it) the machine thinks "hey he still wants water". next time it does that try pushing on the spot you put the glass onto a couple of time to see if it stops the water. if so it most likely is the switch. to confirm that is the case you will have to open the plastic moulding from the fridge door to gain access to the switch.( always unplug any electricall device before openning to ensure your hair doesnt end up standing striaght up like a punk rocker) you will know which switch is the one you want to check by depressing the water lever on the front. Ohm check the switch for continuity to see if it gives you proper readings or it is in fact a bunk switch. it also could be a mechanical problem as the lever once unpressed is not opening the switch back up once the glass is removed but that is not as likely unless you are ramming the glass into the water dispensor
hope it helps
VeeDubb
Apr 23, 2008 | Refrigerators
Refrigerators Logo
63 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
