Question about Refrigerators
Full tray light will not go out although tray is clean
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 28, 2012
Softener tray won't fill with water; although it fills the bleach side tray just fine. No error codes, just an empty bleach tray but full softener tray.
I suggest there may be hard water mineral deposits in the hose or orifice to the tray. Try soaking it with some Coke (yes I mean the soft drink) overnight and see if the flow improves. Either that or you can try some CLR but Coke should be enough to gently remove any deposits there are in the tray, hose or line.
Dec 02, 2014 | Maytag Neptune MAH5500B Front Load Washer
Foodsaver vacuum sealer tray full light
Clean the two little contacts on the tray. Make absolutely sure there isn't anything across the two wires that run the length of the tray. It doesn't take much to trigger the light.
Jun 03, 2014 | FoodSaver V3880 Vacuum Sealer - The Master...
How do i get a service manual?
The bin sensor eyes need to be cleaned or replaced. First remove the front cover then remove the white plastic ice deflector shield. Now you should be looking at the evaporator plate look down you will see the water sump tray full of water in that tray is a black plastic grate that when the ice is harvested it drops and hits the tray keeping it from falling in sump tray PULL it OUT. now just behind the sump where the ice falls through opening on the left and right sides is where the ice full bin eyes are you can pull them out side ways there is plenty of wire so you can pull them up to where you can clean them with a soft cotton cloth with scotsman cleaner. Now for a manual goggle scotsman service manuals you can get a PDF file.
Apr 28, 2014 | Scotsman Ice Maker 600LB CM3 30inW...
V3835 tray full light won't go out after both trays have been emptied and cleaned.
Hair dryer. Remove both tray inserts and dry thoroughly, paying special attention to the sensor area in the center of the upper tray.
Sep 26, 2013 | FoodSaver V3835 Vacuum Food Sealer with...
Tray full light won't go off & the tray is empty
Have the same problem. I'm looking for a solution too. The tray is dry and clean as a whistle. I cleaned all elect. connections and even dryed it all around with a hair dryer.
Sep 23, 2013 | FoodSaver Food Saver V3835 Vacuum Sealer...
I have a Foodsaver 3420 and the Tray Full light stays on. I have cleaned the moisture tray several times and it it very clean. I even cleaned the contacts. With the Tray Full light on the sealer will not...
Place a small piece of electrical tape over the contacts on the fluid tray. This will allow the machine to operate but you'll have to manually check the tray for liquids/cleaning.
Jun 24, 2011 | Microwave Ovens
The tray full light stays on even though the tray is empty.this prevent the foodsaver from operating.I have tried unplugging,recleaning the tray but nothing works
I had the save problem with my 3400 series.
The first time i was able to let it dry and it worked alright (48 hours).
The second time even this did not work.
If you remove the screws on the bottom of the unit. There are about 10 and pull it down, you will see the sealer assembly and a small circuit board in the middle.
Trace the wires from the drip tray, there are three of them, red white and brown, to the small white plastic JST connector on the small circuit board. Pull said connector gently to disconnect it.
The unit will function perfectly now, although it will no longer have a drip tray sensor of any sort it will function every time all the time.
All in all this took me about 10 minutes.
Thanks!
Sep 09, 2010 | Vacuums
The icemaker of our Samsung side by side refigerator gets full and clogged up frequently and although we can hear the machine churning inside, ice is not dispensed. We have put in a new water filter after...
Either the icemaker support is broken, DA61-01801A or the ice tray is damaged or has lime buildup. The ice tray is supposed to twist when it flips: an off-center stud on the tray catches the support, while the tray is still turning. If it does twist but does not release ice - replace or clean the ice tray, part number DA63-02284B
Good luck,
Vlad
First Choice Appliance
Aug 17, 2010 | Samsung RS2630SH Side by Side Refrigerator
Hp 4000N 41.3 unexpected paper size
Clean the sep. rollers one in the paper tray and one inside the paper tray port. Then clean the feed roller. Its behind the sep roller in the paper tray port. You must look close with a flash light. It has 4 D feed rollers. It will rotate down to clean them do not knock the spring off. Use only water on a cloth no alcohol. Steven 818-888-0006
Mar 11, 2010 | HP Office Equipment & Supplies
The softener container doesn't empty, remains full after the run
Not familiar with that model but usually the cause is the dispensor is clogged up. Remove and clean.
www.appliancehelponline.com
Feb 26, 2010 | AEG Washing Machines
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
