Question about Samsung RS2534 Side by Side Refrigerator
Icemaker spring not working sticking - Samsung RS2534 Side by Side Refrigerator
    Top Expert:
  • Samsung Master
  • 9,472 Answers
Here is the parts list for that unit.
Posted on Nov 28, 2012
Does it take 24 hours for a new ice maker to start working
Thats what manuals say but in all honesty no it does not. The icemaker itself has a sensor in it that prevents the icemaker from turning on until the sensor reads 10 degrees F for a period of time. This is a failsafe to prevent the icemaker to fill with water with already standing unfrozen water in it causing an overflow. If your handy enough, remove the icemaker cover, the white square one, and get you a jumper wire and stick it into the holes marked n and m and leave the wire there until you hear a click. Dont shock yourself either. That will bypass the initial setup and the icemaker will start working normally cycling about every 45 miunutes.
Apr 25, 2012 | GALAXY Microsystems 25.4 cu. ft....
Ice maker is not making ice through the door water is working
first thing to do is check to see that water is getting to the icemaker simply stick your finger inside the ice maker and check that there is water in there usually icemaker can be removed by three screws 1/4" against the wall if you have water and can feel ice on the inside remove the icemaker and flush with hot water then reattach the ice maker and wait 24 hrs to see if you get ice if it still does not work then your in need of a new icemaker which uyu can get from marcone appliance parts they willship the unit directly to your door and you wont have to pay a technicain installation charge hope this helps
Jun 26, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire FRS24ZRHW0 Icemaker/Water Dispenser problem
See if your water solenoid might be the problem. Your water supply line from the house will connect into a solenoid. I just recently solved a problem for someone on this site who had a solenoid that was sticking. Try tapping the solenoid gently to get it to activate or take it apart and depending on what type it is, manually move the spring loaded plunger a few times.
Hope this helps
Feb 25, 2010 | Refrigerators
Not making ice
Pour about 2/3 cup of water into icemaker . If it dumps , replace the water valve . If it doesn't , replace the icemaker . Your icemaker may have the white flap arm with a spring attached between the arm and bottom of the icemaker . Check that spring , to make sure both ends are seated . Ocassionally , the top of the spring (fitting into the bottom of the icemaker ) comes out , and has to be pushed back into the hole .
Sep 07, 2009 | GE GSS23SGSSS Stainless Steel Side by Side...
Water Flow out of freezer compartment
take wires off inlet valve if it stops replace ice maker
Aug 31, 2009 | Whirlpool GS6SHAXLQ 25.5 Cubic Foot Side...
My icemaker was working at one time but now is not working .. I can feel the ice inside the icemaker unit.
Often these icemakers just get jammed because the ice cubes stick together. Carefully dislodge all of the existing ice and it should be ok
Jul 31, 2009 | Frigidaire FRT17G4B Top Freezer...
Ice maker no longer making ice
Remove the ice bin and check the spring on the white cut off arm . When arm is pushed back , it should spring back foreward .Ocassionally , the top portion of the spring pops out of the hole which will be visibly evident . If so , use a small screwdriver to push back in place . If looks ok , then pour about 1/2 cup of water into icemaker and wait to see if it dumps . If dumps , then water valve is bad . If doesn't dump , icemaker is bad .
Jul 19, 2009 | GE GSS25LGM Side by Side Refrigerator
Water but no ice. ice in tray
If you have a "paddle" switch just below the icemaker make sure there is tension on it, i.e. the tension spring might be loose. Make sure the tension spring end is inserted into a tiny hole. Mine wasn't, I did it and ice maker works fine now.
Jul 17, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
WR30X10093 Icemaker problems
Remove the white plastic cover. Upper right screw sideways with + and - on the head. This is the fill adjustment.
May 10, 2009 | GE Profile PSI23SGR Arctica¿...
Samsung RS2534 Side by Side Refrigerator Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
