Ac blows cold air for a while suddenly blows hot air why?
SOURCE: Heating and AC problem.
I had the same thing on the same model car. Sounded like I had a gerbil living (running around in a little wheel) in my dashboard. I think the replacement part is called an accuator (it is relatively inexpensive) but the whole dashboard has to be removed to put it in. It controls the opening and closing of the vents. Apparently even taking the dashboard off is not as difficult as dealers often indicate - but they bill for a lot of time - so the job is an expensive one unless you do it yourself. I ended up having a friend do it for me.
SOURCE: 1992 Lexus SC300 Air Condtioner blowing cool/warm
the system is low on charge, it has a leak, repair the leak and recharge
SOURCE: My ac is not cold in my lexus but light comes on
A/C systems are a bit complex and dangerous with regards to the high pressure refrigerants they use. Furthermore, the equiptment needed to service is expensive. If you have a shop manual it will tell you how to do the electrical checks on the system. However the system will not work if there is no refrigerant in the system and some of the electrical tests can not be conducted. Take to a certified A/C Tech. It will be worth every penny you spend.
SOURCE: AC Not Cooling on Passenger side
is300 has dual zone climate control
passenger side blend door actuater has probably failed
NO HEAT ON FLOOR VENTS
As
per your problem mentioned. There are few solved help links to
troubleshoot these problems. Go through the list and Click the link below:----
http://whatisbyme.blogspot.in/2012/05/2000-toyota-avalon-no-heat-on-passenger.html
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
http://technoanswers.blogspot.in/2012/02/no-heatblower-blows-only-cold.html
http://whoisbyme.blogspot.in/2012/06/2009-mercury-grand-marquis-ac-blows.html
http://schematicsdiagram.blogspot.in/2012/04/ac-not-blowing-through-vents-on-2007.html
http://schematicsdiagram.blogspot.in/2012/04/passenger-side-temperature-is-warm-air.html
These
will help.
Thanks.
As
These will help.
Thanks.
