Question about Korg X50 Synthesizer
How to delete the save write combi to korg x50 synth
2 Suggested Answers
  • 1138 Answers
SOURCE: when I play the sound come out distorted, like it
The manual is at:http://www.korguksupport.co.uk/upload/X50_OpGuide_E1.pdf if you don't have one. Try saving everything you want to save first if you know how to do that. Then initialize the keyboard. Follow the instructions on page 111 carefully. It sounds like you created an undesirable effect and accidently assigned the Pitch Bend Lock function to the effect. This parameter is explained on page 41 under Pitch Wheel Mod Wheel. Hope this helps.
Posted on Aug 20, 2009
GM VOICE NOT PLAYING
Your best bet is to contact Korg. Here is their link-
http://www.korg.com/us/support/contact
Jan 01, 2016 | Korg X50 X-50 Keyboard
Help please my korg X50 still not functioning, my Friend said maybe IC is the problem,we used my board in long distance traveling gig, just asking sir if may cause problem in my board?
There are a number of IC's in your synth. Traveling with it in and of itself wouldn't cause a problem, but rough handleing during travel may be. Always use a road case on your gear.
That said, you'd be best to take it to a repair shop to get it sorted out correctly.
Aug 28, 2015 | Korg X50 Synthesizer
My synth wont load when I power it on. can anyone help?
I suggest a hard reboot / initialize. Istructions are in your manual or on the Korg website
Jun 09, 2015 | Korg Pa800 Synthesizer
Korg m50 freezes, read in other forums that the problem may be to replace 2 capacitors, do anybody knows wich ones? or have a solution?
Hello, I own a Korg M50 myself and I had the same issue, its a quality control issue at their factory but, I may have a solution for you I found at a Korg forum. the issue is with these teeny cables inside the synth. you open the rear panel and firmly press each teeny cable into the terminals again and re attach and secure them firmly just finger push them all into their teeny sockets. this should stop the freezing I tried it the synth played all night with out freezing . I hope this helps other wise the solution with the capacitors is simple you order a new mainboard but they run about 400 plus. but try my solution it may work for yours this answer comes from a korg tech, he stated 90% of this freezing issue he has encountered has been these loose teeny cabling adapters, hope this helps, Have a great day..
Jan 27, 2014 | Korg M50 61-Key Music Workstation Keyboard...
Korg x50 starting system hang
5VDC is absent. The 0 Ohm safe resistor is dead. Backlight is off in this case too.
Jul 30, 2012 | Korg X50 X-50 Keyboard
When I play the sound come out distorted, like it untunes. any idea what is causing the problem? this is a for a Korg X50 and is only 2 yrs old. not korg Ma30
Aug 19, 2009 | Korg Ma30
I am trying to load the new OS for the triton studio. My studio says i need sysyem 1 disk. I don,t have it. Solutions?
They need to be downloaded from korg.com. You need to have a floppy disk drive to load them unfortunately.
Jul 14, 2009 | Korg Music
Problem using Kaoss Pad for synths.
Okay, maybe this is rude, but TOTALLY ignore Musicaldude's solution, if you haven't already found out the ugly way. Boosting the signal that goes into the KP will just make the input LED light up red and you'll hear digital clipping [gross] and eventually hit a ceiling of all-crappy-staticy-noise and no real guitar left. Having it in the FX loop, and the Headphone-out workaround are smart moves already, except the Headphone out adds noticeable noise/hum vs the usual outs. But to help close the gap between your guitar's volume and the miniKP's internal synths (and program 63 and 65's feedback noizes, which build up even louder than the synths) unplug one of the RCA plugs from the KP's OUTput, pick one, left or right, whichever. You'll notice this gives you a guitar volume boost. BUT its still not enough...the synths and 63 and 65's feedback are still speaker-blowingly loud. Check the manual, it says you can adjust the wet/dry volume by holding down Tempo and Preset A together, then turning the knob and picking 1 thru 99. Make sure you're on the synth setting you want to use already. Do this thing. Play the synth with your finger, while you lower the number with that knob. Stay around 50 if you've got the one RCA plug dangling, around 20 if both are in. Whatever you think matches your usual playing volume. When its where you like it, hold the A or B button (wherever you want to save this) down and click Hold, this will save it onto that preset button. Now from now on, NEVER use 63, 65, or the synths if you're on whatever preset you DIDN'T just save. i.e. If you chose preset B, from now on you can just tap preset B and it remembers your volume adjustment from before, voila, normal-volume touchpad synth. But go back to preset A for every other effect, or you'll barely be able to hear the FX. KORG should've given us more preset buttons to save onto. Godspeed. I've never seen this site before, but I have this pedal, and experienced the same b.s. myself. Now I'm down to one preset button and quick knob-turning. Whee.
Aug 07, 2008 | Korg Mini Kp Kaoss Pad
Korg X50 Synthesizer Logo
Top Korg Music Experts
Michial Gueffroy
Are you a Korg Music Expert? Answer questions, earn points and help others
