Question about Sony Bdps390 Bluray Player
Tray is open or disc is being read. Cannot perform this operation
The tray is being operated or a disc is being read
Using flash USB drive to play video on Sony Blu Ray DVD player
"The tray is being operated or disc is being read. Cannot perform this operation"
you need to change the default settings on your Sony Blu Ray player.
navigate to
Settings
System Settings
Switch fast startup mode off
this will change the startup time back to "normal" from "fast"
This gives the Blu ray player more time to read your USB flash drive, esp. larger flash drives,
which need more time to register in the memory of the Sony's processor.
Dec 26, 2013 | Sony Bdps390 Bluray Player
I put a disk in and there was already one in now it wont eject
The disc tray does not eject when the OPEN/CLOSE button is pressed. Solution
sp.gif sp.gif Follow the steps below to troubleshoot this issue.
    IMPORTANT: The disc tray will not open while a disc is loading; this is normal operation. If this is the case, wait until the disc is finished loading before pressing the OPEN/CLOSE button to open the disc tray.
  1. Make sure the disc tray is not locked; if necessary,
  2. Perform a power reset.
    1. Press and hold the POWER button for 10 seconds until the BD player turns off.
    2. After the BD player turns off, press the POWER button again to turn it back on.
  3. Attempt to open the disc tray by pressing the OPEN/CLOSE button on the front of the BD player.
  4. If the disc tray still does not open and a disc is stuck inside, follow the steps below to force the disc tray to eject:
    1. Turn off the BD player.
    2. Turn the BD player back on.
    3. Immediately after POWER ON is displayed, press the STOP button on the front of the player. IMPORTANT: Only use the STOP button on the front of the BD player. The remote control cannot be used for this operation.
      NOTES:
      • The disc tray should eject and the BD player will turn off. If it does not eject, repeat steps A-C.
      • It may be necessary to press the STOP button in step C two or three times.
If the issue is still unresolved, service may be required
Sep 15, 2011 | Sony BDP-S300 Blu-Ray Disc Player
Dvd tray will not open or play
The reason your player keeps reading a disc and do not play is because the the disc tray is not sitting the disc properly on the lens.
The disc tray is faulty, the mechanism that controls the opening and closing of the tray is damaged and needs repair.
To fix this, you have to get the appropriate screwdriver, open the cover of the player.
You will see a mechanism by the opening of the tray that controls the disc tray.
Get a replacement mechanism and change it. Mostly the rubber slacks and does not control the tray properly.
Changing the mechanism will solve the problem.
Take care
Jun 15, 2010 | RCA DRC8295 DVD Recorder/VCR Combo
Philips CDR775 2-Disc CD Recorder tray won't read/open
this depends on what make of disc mostly the philips machines only work with their own brand of disc try placing an original disc if thats ok then its the blank cd that you are useing got to be philips brand
Mar 30, 2010 | Philips CDR775 2-Disc CD Recorder
Will not read any discs
mine does it too, keep opening and closing tray until it loads, if it says "Reading" its operational, just a little buggy
Feb 06, 2010 | Microsoft Xbox 360 Console
Open/Close tray message
This means that you need your DVD drive replaced. If you are under your 1 year warranty from MS go to www.xbox.com/support and fill out a repair request. If you are out of warranty make sure that you only let an experienced professional perform this repair. If you do the repair on your own, or have someone that doesn't know what they are doing do it then it's very likely your Xbox will never play games again. There is vital information on the old DVD drive that must be extracted and put into the replacement in order for your 360 to allow it to play games. I can do this repair for you if you'd like. Email me at Jordan@jordanselectronics.com for more info.
Dec 28, 2009 | Microsoft Xbox 360 Console
LG DVD REcorder disc tray will not open
Most likely the tension band that is attached to the mechanical parts of motor and the tray detached. you'll need to disconnect the power and unscrew the cover open and put the band back in place.
May 21, 2009 | LG DR787T DVD Recorder
I put disc in the disc tray and says its reading then it just says: open tray?
wel then theres a problem wit either the game or the reader under the disc tray
Apr 14, 2009 | Microsoft Premium System for Xbox 360
Disc tray
My console does the same thing just take the faceplate off and when you press the open button grab the disc tray and gently assist your console in pushing out the tray. Taking the faceplate off does not terminate your warranty.
Jan 12, 2008 | Microsoft Xbox 360 Console
Sony Bdps390 Bluray Player Logo
223 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
