Question about Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub Washer
Amana washer commercial quality, super cap plus, 3.3 cu, 12 cycles, support
  • 57 Answers
SOURCE: Amana washer leaking.
Have your husband disconnect the power and water lines, pull the washer out and tip it back so he can check the hose connections to the water drain pump in the bottom of the washer. That pump should have two hose connections. In older machines, it is entirely possible that a hose has either come loose or cracked. If the hoses appear fine, check the pump itself for possible cracks. If all looks well, check the hose clamps for tightness.
Posted on Feb 23, 2008
aborcass
  • 2651 Answers
SOURCE: Hi, I have a 5yr
sounds like a drain pump issue, not able to remove water quick enough before the centrifical force of tub spinning throws it over the top, remove the pump hoses and look for blockages
Posted on Nov 07, 2008
SOURCE: AMANA DISTINCTIONS FABRIC CONDITIONER RELEASE
MOdle NAH6800 I beleive its either 2 or 3 years old. I have water in the outer tub. I can hear it when I turn the tub is this normal
Posted on Mar 21, 2009
jumptrout51
  • 3361 Answers
SOURCE: Amana top load clothes washer dial malfunction
Bad timer. Replace it.
Posted on Jun 08, 2009
  • 351 Answers
SOURCE: I have an Amana Commercial
could be timer or someting in pump
Posted on Sep 30, 2010
Fix rinse cycle
That sounds like a failed mechanical timer. Replacing that should solve your problem.
Dec 13, 2014 | Frigidaire Washing Machines
3.1 Amana super Cap Top Load washer NTW4880YQ water levels
You need to check the water pressure hose between the tub and console for blockage. Be sure to blow it out good. If this does not clear up the problem, replace the pressure sensor. Here is the part to order.
Nov 05, 2012 | Amana 3.2 cu. ft. Top-Load Washer
How to remove aggitator from center of machine to clean inside of it, there seems to be little bits of whatever coming from there its a whirlpool super capacity plus 8255e commercial quality
Pry the top lid off the agitator.
Remove the plastic shield inside.
Use a 7/16 socket and extension to remove the bolt.
Pull the agitator off the shaft.
Mar 04, 2011 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Have a Whirlpool Super Capacity washer in which the drum will tilt during the wash cycle and spill water. If held to center, there is no leak, and the cycle completes without difficulty.
Could you tell me what the life expectancy for this washer might be and does it have a good track record. (Mom gave me one) Whirlpool Super Capacity Plus 7-Cycle 2-speed. 3.2 cu. ft
Mar 02, 2011 | Whirlpool 3.2 cu. ft. Plus Washer
Whirlpool super capacity commercial washing machine
Sounde like a bad lid switch . With no model number , can't help you further .
Sep 06, 2009 | Whirlpool 3.2 cu. ft. Plus Washer
Leaking at drum where drive shaft enters
hi thanks for the question .your problem is major save yourself a lot of aggravations purchase new a nice washer is called roper built by whirlpool but cheaper same quality thanks the appliance doc
Sep 28, 2008 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Hello Daddy 2,
Welcome to fixya
I'm Huuum and happy to assist you,
What is the model number and the year of the washer?
Front load or top?
A waiting your response!
Huuum
Dec 10, 2007 | Amana 3.2 cu. ft. Top-Load Washer
Amana commercial washer
set up right for at leat 24 hrs before trying to operate the unit
Nov 07, 2007 | Washing Machines
Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub Washer Logo
24 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
