Question about Toshiba Televison & Video
How to correct shaky tv picture - Toshiba Televison & Video
  • 1 more comment
  • lionel603
    lionel603 Nov 30, 2012
    In the old days, one could twiddle the knobs on the back of one's TV set - things like 'Line Hold' or 'Frame Hold' - for it to improve. But nowadays there are no such knobs! It may just be worn out, so I am prepared to resign myself to this possibility.
  • lionel603
    lionel603 Dec 02, 2012
    I think the problem was one concerning the digibox, and is now solved. THANKS for posting this and for all those who have commented.
  • lionel603
    lionel603 Dec 24, 2012
    I've no more to add, but thanks v much for all comments received!
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
Glad you found this issue.
Posted on Dec 22, 2012
Rolling, Shaky picture
My best guess would be the video adapter switch you have to use to hook up the game console to the TV. If I remember correctly you have to slide a switch to either TV or game depending on whether you are watching TV or playing a game. Over time switches like that need the internal contacts cleaned. You can probably get a can of contact cleaning spray at Radio Shack. Just follow the directions on the can of contact clearer and you will probably fix your problem.
Feb 15, 2014 | Atari 2600 Console
Toshiba VCR. It records OK but playback is black, white shaky
What do you mean by "records OK"? It sounds to me like you are not getting a signal to record. I had this problem before, as well. There are two things I recommend you try. The first is that (if you are trying to record over-the-air tv, you will need a digital television converter box connected directly to the vcr. If you already have one and are sure that it is connected correctly, you may also try an RF modulator. When I got my new vcr, it wouldn't work at first. I eventually found out that I would need an RF modulator in order for it to work on my tv. I hope these suggestions help. Good luck! Sincerely, Der Strom
Apr 26, 2010 | Aiwa HV-MX100 VHS VCR
Dusted the bulb box. then when i turnd tv on, picture is unstable
Make sure you put everyting back correctly. It can be that you forgot to tighten the allen bolt and the cage is moving.
Jun 01, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Blurry shaky pic
It sound like you have a leaky capacitor in your power supply, or video circuit, that is causing noise in the picture. I would have to refer you to a television technician in your area. This would seem like a simple repair. Leaky capacitors can become stable after they warm up.
I hope that I have provided the correct information that will assist you in the resolution of this issue. If you have any questions, please post back with a comment to this thread.
If I have helped you with your question and/or solved the problem, please take just a moment to rate this post. Thank you!
May 01, 2009 | Toshiba 50H81 50" Rear Projection...
Shaky picture AKAI PDP4298ED1
THERE MAY BE SOME CONDENCER LEKAGE SOMEWHERE IN THE HORIZONTAL SECTION
Mar 23, 2009 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Shaky/Unstable Picture
This is power supply issue, one or more of your filter capacitors either bursted and/Or over heats (this is why it becomes better when system cools down after turning it off for 1/2 hour..You have two choices.1. buy a replacement power supply may set you back a couple hundred dollars but it will be plug and play. 2nd you can replace these filter capacitors make sure the can handle 105 deg celsius not the 85 deg. celsius, if you know how to trace the bad ones and desolder and solder new ones on the power supply board, or hire a techinician to replace them for you. Good Luck...
Dec 14, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Shaky Picture only during Advertisement or... Mitsubishi SC 27403
If you have cable then put the cable wire directly in the TV, bypassing the cable box. If the pix is Ok it proves that the problem is the cable box. If the problem is still there then it proves the the TV needs parts inside.
Mar 24, 2008 | Televison & Video
65 Inch Samsung Projection TV- Shaky Picture
have a tech look at your tv it needs to be repair checks can be made in the power supply.video circuit,or the IF CIRCUIT.good luck.
Apr 01, 2007 | Samsung HCN653W 65" Rear Projection...
Televison & Video Logo
199 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
