Question about HP D220MT PC Desktop
Can't boot from dvd drive
    Problem Solver:
  • 18 Answers
You need to put the DVD drive in the boot sequence. While booting your system up hit either F2 (function key) or delete (depends on the type of PC you have) go into your bios and select your DVD drive in the list of boot devices. You should also check and see if you have autorun turned off in control panel.
Posted on Nov 28, 2012
  • 2 more comments
  • Bobbybee Nov 29, 2012
    Hi Jim...I've tried those things before I posted. See my comments below to JD Merrill to see more details about my situation. Thanks for your sugestions.
  • Jim Cadman Nov 30, 2012
    Did you run the windows 7 compatability wizard on the machines to make sure all your hardware will run ok first? That has come around to bite me in the past.
  • Bobbybee Dec 02, 2012
    Hi Jim...I ran the compatibility wizard....nothing major was reported. So...I tried to install 7 again after rebooting in XP mode. Again...It failed and said that there was a file missing...So...I used the Original 7 DVD that Microsoft sent me. This time...it worked. It loaded 7 when installing in the "custom" mode. But..again...neither DVD's would boot when the system was initially turned on. I then used a standard CD to create a Repair CD. (non DVD). It failed to boot. I installed a different CD R/W drive and repeated the build of a repair CD (700MB)....it wouldn't boot either!
    So....it looks like I'll have to install XP first and then Install 7 with any DVD CD disk. I've been working on systems for a number of years...I've never seen anything like this before. Thank you for your assistance and offers of support. I think that anyone that happens to get one of these HP d220 mt system might be saved a lot of time and effort if they run across these comments. Thanks again.. Bob Barnes
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 25 Answers
When you boot your PC, a brief display should appear that gives you options for booting. On my computer, this is done by pressing and holding the F12 key, although your PC may be different. If you've already tried this and it simply will not read the disk in the drive, then you have a problem with your DVD drive. In that case, it could be the hardware (drive) itself, a loose connection within the PC housing, or it could be something as simple as a software driver. Check to make sure your drivers are up to date first. But, also make sure you are following the necessary steps (for your computer) in the boot process to tell it to boot from the CD/DVD.
  • 1 more comment
    Thanks for your ideas. I had already tried using a different DVD drive. (Internal).
    I also went through the setup program and made sure that the USB port was able to see a CD drive unit. So...in either case, A regular CD (Windows XP Pro Installation Disk) works when the system is rebooted. I also used my original Windows 7 DVD in place of a working copy. Same thing happened. Neither DVD drive configuration will boot using the Windows 7 DVD.
    There must be something in the BIOS that sets the initial read operation to sync up to a DVD. Again...when the system is started normally using XP...Once the desktop settles down....I can read any DVD disk. The problem that I have after that is that Windows 7 won't "upgrade" windows XP...Windows 7 then fails and won't try to install. So....I have several of these HP D220 mt systems that were donated to my program that I really need help with.
Cannot boot from cd rom
check out cd/dvd-writer.if any dust partikels clean with caned air.
Apr 22, 2013 | HP Compaq Evo D310 PC Desktop
Why won't my Gateway PC DVD drive close?
Are all the Windows and Gateway updates and Hotfixes in? Look for a DVD rom fix on the Gateway website support. If there is no disk in the drive and it opens, you may want to replace it. You can try a work-around, I have no idea if it will solve the problem, but at boot open the BIOS, go to Boot sequence, Change HDD to boot first. DVD/CDrom 2nd or 3rd.
Dec 26, 2012 | Gateway Computers & Internet
Comp will not boot after installing a SATA DVD-RW
Perhaps your bios is set to boot from the 1st device it 'sees'.
When you add the dvd drive, maybe the device order gets shuffled up, making the dvd drive 1st. So, you need to check this by looking at the boot settings on the bios screen and change the boot order if necessary.
Sep 24, 2012 | MSI Ms-7529 V1.6 Motherboard Intel Lga775
My emachine T2958 would not boot. the fans run but no bois nothing. i realise on the mother board alight is on by the letter F.Is it the motherboard ? help please
A good way to tell is disconnect your hard drive's, & CD/DVD ROM's power & data cable. Try to boot.
If you get the same results then you can try & remove any PCI cards from the board, remove your ram stick. Try to boot. If you get an error beep because you are missing ram than this is good.
Replace 1 ram stick back into your motherboard & try again. If it boots then you know the other stick is bad.
If removing all the non-essentials from your motherboard doesn't work then all you have left are the motherboard & power supply. A simply power supply tester or spare power supply will tell you if it is your board or not.
Jul 16, 2012 | eMachines T Computers & Internet
Formatting new sata drive with xp disc but cd dvd roms are not showing in bios
first your cd dvd drives
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
then you should be able to load xp
hope it helps
May 10, 2012 | Intel D865PERL Motherboard
My acer computer will not boot up it keeps asking for the boot up disk . This is new since it was working fine prior to this
CHECK THE BIOS NB POWER ON AFTER PRESS F2 KEY & ENTER BOOT OPTION & SEE THE HARD DRIVE ,FIRST BOOT DRIVE DVD-RW SECOND BOOT ORDER HDD OPEN DRIVE & INSTALL CD & DVD PRESS F10 NB RESTSRT WILL BE AFTER BOOT ,,,PLEASE TRY.
Mar 02, 2012 | Acer Aspire 5732Z-4855 Notebook
Dell Inspiron 600m: No Boot Device. I'm a computer
Have you tried resetting the BIOS defaults? In doing so, it will force IDE re-detection and often resolve vague boot issues.
Sep 11, 2011 | Dell Inspiron 600M Notebook
My lenovo thinkcentre desktop computer never shows "press any key" while I try to format. Unable format my C drive and recently 500 GB HDD was installed in my computer. pl.advise how to format...
Hi! Welcome to www.fixya.com.
Removed your power cable and drain power without any power. restart and keep on hitting f12 to get to the boot menu choose ODD then put the OS CD then press enter until its say press any key. If it did not work your other option is reboot and hit f1 or f2 to change the boot sequence on boot option. Restart pc then hit f2 go to boot option and choose DVD/CD to be your first boot option then press f10 restart and it should load automatically.
Hope this resolution fix the problem on your computer. Thanks for contacting Fixya. Bye for now.
Jul 20, 2011 | Computers & Internet
Hp presario f700/f750us, cd/dvd player, won't boot from start up but is listed first in boot order, not recognized by windows either, won't read, write or play. tray opens and light blinks. tom...
Check the jumper settings in the back of the drive, by the power cable. Make sure your cd/dvd drive is set to SLAVE, with your primary harddrive as MASTER. Check BIOS settings, specifically your boot order, choose which drive you want to load first (usually HD 0), save and exit.
That's just the basics, though.
Another possibility is that you might just have a paperweight ;)
If so, try another drive.
Hope that helps
Cheers from NZ
May 17, 2011 | Compaq Presario 700 Series DVD-Rom Drive...
Msi 848p neo v motherboard problems.
Once you reset the bios everything goes to manufactures default settings. You will need to make some changes within the bios. You'll need the help of the manual. See page 3-20.
If your operating system is loaded on to the ATA IDE drive make sure you set bios settings as follows:
Connect the ATA IDE to MB primary master IDE port.
Connect the ATA SATA drive to the MB's first SATA port.
ATA Configuration
Set as, [P-ATA+S-ATA]
S-ATA Keep [Enabled] Set to [Yes] This enables the SATA controller.
P-ATA Keep [Enabled] Set to [Yes] This enables the IDE controller.
On-chip IDE configuration, "ATA Configuration = [P-ATA+S-ATA]".
Next go to Boot menu. Make sure the ATA IDE drive is chosen as boot device three.
First boot device [Floppy] (If you have a floppy disk drive connected.)
Second boot device would be [DVD/CD-ROM] drive. This should be connected to the MB's secondary IDE port & the DVD/CD-ROM drives Master/Slave jumper, set to Master.
Third boot device [ATA IDE drive]
If your boot drive is the SATA drive than set: third boot device to the SATA drive.
(Hard disk drive with operating system loaded on it).
Save your changes & exit the bios.
Keep in mind all ATA SATA drives are seen as Master drives. SATA drives are seen by the SATA controller & in order by their connection to the SATA port number.
Save & exit the bios. The system will auto restart. Windows should start.
Jul 25, 2009 | MSI Computers & Internet
HP D220MT  PC Desktop Logo
29 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
