Boss Therm BPS242RF for central heating. Cannot understand this Boss Therm at all. Temperature does not reach the one I set. 22.5. It stays between 1900 and 20. Room is cold. Any help would be appreciated.
  • thomasbigm May 11, 2010
    Dear Sirs,
    I have a plumber coming to fix and explain the above. I have not had a manual and therefore could not find how to use this.
    Thank you for your email.
    Kind regards,
    I. Thomas
burty681
  • 56 Answers
SOURCE: Hiya i have a programmable room
take of the wall and there is a reset button
Posted on Jan 20, 2011
Setting start temperature on central heating thermostat
It sounds like your heating system has to little capacity to heat the home properly. 21 degrees is a reasonable temperature to expect but if the unit is running all the time and can't reach 21 degrees the heater is too small.
As far as setting the thermostat here is a link to the instructions.
http://www.salus-controls.pl/data/product/attach/rt300rf_-_eng.pdf
Nov 22, 2013 | Heating & Cooling
Adjust thermostat
A thermostat only cuts the heating off when the temperature it is set to is reached while the heating is on. If the heating is set to off then the thermostat will do nothing.
Generally you want to think about when you want your heating to come one and off by using the timer and then the thermostat is just used to ensure that you don't waste energy by exceeding the maximum comfortable temperature.
Hope this helps a little.
Nov 22, 2013 | Ovens
Boss therm bps242rf
Use your fingers and pop it off, no screws there.
Duo-Therm ac when the temerture is reached the fan will shut off but the compressor stays running
Sounds like you hit it on the head--compressor should turn off when unit reaches the preset temperature.
Jun 10, 2012 | Dometic Rooftop RV Air Conditioner
ER3 no hot water
Er3 means that the water is being heated for more than 1 hour without reaching the set temperature.
Need new aquastat.
Sep 28, 2009 | Amtrol ST-120V-C THERM-X-TROL ASME...
Get message of fuser low therm 1F
One of the two small thermostats, that are called "snap-action disc thermostats" and control the electricity flow to the fuser lamps, has likely gone bad. If you are feeling generous to the money pit governed by Konica-Minolta, you'll need to replace the fuser unit. Otherwise, you'll probably need to locate and replace the bad thermostat. If you are not electronics saavy, I recommend taking the fuser unit to an electronics shop and asking them to check for and replace any bad thermostats.
As an explanation, these thermostats work just like the thermostat for a typical home central heating system. While in use, they keep the fuser temperature between 130 and 150 degrees by turning the fuser lamps (the parts that heat up the fuser) on and off. They do this by allowing electricity to flow to the fuser lamps until the temperature of either thermostat reaches 150 degrees. Once that happens, the thermostat will turn off electricity to the fuser lamps, allowing the temperature to cool back down to about 130 degrees. Once the temperature returns to 130 degrees, it allows the electricity to flow again to repeat the process.
Jun 08, 2009 | Minolta magicolor 2200 DeskLaser Printer
Magicolor 2200 error Service Call 1f fuser low therm
There are two small thermsstats, called "snap-action disc thermostats" that control the electricity flow to the fuser lamps. One of these has likely gone bad.
As an explanation, these thermostats work just like the thermostat for a typical home central heating system. They keep the fuser temperature between 130 and 150 degrees by turning the fuser lamps (the parts that heat up the fuser) on and off. They do this by allowing electricity to flow to the fuser lamps until the temperature of either thermostat reaches 150 degrees. At 150 degrees, either thermostat will turn off electricity to the fuser lamps, allowing the temperature to cool back down to about 130 degrees. Once the temperature returns to 130 degrees, it allows the electricity to flow again to repeat the process.
Mar 21, 2009 | Minolta magicolor 2200 DeskLaser Printer
Ruud air to air heatpump intertherm propane furnace honeywell th5220d non programable thermostate.fan on furnace will not turn off in aux.mode even though the furnace heat kicks on and off. thank you for...
Make sure fan relay is wired correctly (G) wire. Ensure the fan on therm is not on, it should be on Auto or off.
If your furnace is short cycling because it has to keep heating your home, the delay in the control board may be staying on to compensate for the exchangers getting hot. If it heats normally, then put your attention to your thermostat.
Set the heating system on aux heat only. Fan should not be on, if it does stay on after a heating cycle, see if the furnace is heating normally, and reaching temp as desired before the heat comes off. Then check the therm wiring, pull the face of the therm, disconnect green wire (fan) and try the heating again.
Dec 06, 2008 | Intertherm Heating & Cooling
Heating & Cooling Logo
1,413 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
