Question about Microtek SCANMAKER 4850 Flatbed Scanner
Horizontal Banding When I use the preview screen for scanning an image it is filled with horizontal banding which then, in turn, shows on the image when opened in Photoshop. Any idea what the cause and fix is? Thanks.
  • Anonymous Nov 20, 2007
    I had the banding problem and my power supply was bad that plugged into the wall. A diode had gone bad in the supply. Once the supply was repaired, the banding went away.... Now I have upgraded to Vista and can't find an updated driver for my 4850.....
  • 196 Answers
From the Microtek KB: www.microtek.com Scans that produce lines, fading, and discoloration generally result from a corrupt scanner driver installation or a burned out lamp. To determine if your problem is caused by a burned out lamp, simply open the scanner lid and check the color of the lamp. If the color is a shade of red, pink, or green, then the lamp is burned out. Perform a scanner preview to get a clear view of the lamp. If the lamp is a bright white and the problem still exists, please contact technical support.
Posted on Jun 11, 2007
Screen ghosting
Hi !
How old is your iMac ?
SOunds to me like it has been left on too long for too many years..
THese screen eventually burn in and then it's the end...
Sorry.
Mar 04, 2013 | Apple iMac 24" Desktop
My scanner copies have a vertical yellow streak covering half the page. What can I do to solve the problem ?
Lines or Banding Within the Image
If the scanner is generating lines or banding within the image during preview and/or scan, below is a list of possible solutions.
Horizontal Lines: If the lines run horizontally throughout the image, it is almost definitely interference of some kind. First thing to try is reverse the cable (Astra series only, except for 2400S), trying with and without termination as well. It could also be the SCSI card itself that is causing the interference. Try reseating it in a different slot, away from other cards. Try moving the scanner itself to another location, farther away from computer components such as monitors and CPUs. If none of that works, search for the file ?prescan.dib? on the hard disk and delete it, then try the scan again. If that still doesn?t work, follow the clean uninstall and safe mode install of our software. If these troubleshooting steps do not work, it could be a physical defect within the cable that?s generating extra interference, and the cable should be replaced. If the cable has been replaced already, it may be the UDS-IS11 itself generating the interference from being defective. Replace it.
Vertical Lines: If the lines run vertically throughout the image, it is probably a hardware problem, most likely with the scanner itself. However, follow the cable-reversing instructions above, remove the ?prescan.dib? file, and try the scan again. Often, if they are thin lines they are from dust within the optics. Open the case and blow out the dust with compressed air.
Nov 25, 2010 | Umax Astra 2100U Flatbed Scanner
A yellow vertical line on the copy, which now takes half the page.
What causes the lines in an image?
I am trying to scan a document and it is not working, I have a hp photosmart c4280 printer. How do I install a usb cord
hi
Place the document or image into the scanner for scanning. A scanner with a paper feeder will only receive flat papers and photographs, but a flatbed scanner opens to accommodate books, fabrics and leaves along with flat papers. There is even a attachment for feeding photo slides into flatbed scanners.
  • Step 2 Start the scanning softwaremag-glass_10x10.gif. If the scanner does not engage the software automatically, press the "start" or "scan" button, or click the scanner icon on the computer screen to initialize the software.
  • Step 3 Activate the scan. Click the "file" menu and select "acquire," "import," or another practical choice that applies.
  • Step 4 Preview the item to be scanned. Most scanners have a preview option. This will show the scan area inside dotted lines. The lines can be moved with the mouse to relocate, enlarge or crop the scanning area.
  • Step 5 Set the resolution for images by number of dots per inch (dpi). For computer screen viewing, 100 dpi should suffice. Use 200 to 300 dpi for items to be printed.
  • Step 6 Use the appropriate setting for scanning black and white text. If the scanner does not show a preset for text, use "line art" or "black and white" at 300 dpi. Then use the optical character recognition (OCR) program to convert the image of the text into a file for word processi
  • Jun 09, 2010 | HP Photosmart C4280 Aio Printer
    When scanning old photo, scanner stretches the image. how do i get it to scan image to same proportion as original?
    Open Epson Scan and select Professional mode. Turn off the Auto Thumbnail option. Leave the target size As Original and then do a preview. Once the preveiw is complete in the preview windows draw a marquee around the area you want to scan and select scan.
    Dec 24, 2009 | Epson Perfection 4490 Film / Flatbed...
    How do i flip an image to print on fabric transfer? I am using a mac and a Lexmark x5470
    To flip an image open the image in Preview. In most cases, you just need to double-click the image unless you have installed another image editing software.
    In that case, right click on the image and choose Open With > Preview.
    This will open the image in Preview.
    Go to Tools > Flip Horizontal.
    The image has now been mirrored for printing.
    You can print directly from Preview if you like, or choose File > Save and open the image up in your preferred printing application.
    Dec 09, 2009 | Apple MacBook Mac Notebook
    How to scan with mac
      1. Connect a compatible scanner to your computer. A list of compatible scanners is available in technical document 107203 "Mac OS X 10.2: Scanners Compatible With Image Capture "
      2. Install any necessary software drivers that came with the scanner.
      Note: Not all scanners require the installation of additional software drivers.
      3. Turn on the scanner.
      4. Press the scan button on the scanner. See the documentation that came with the scanner for specific instructions. Image Capture opens automatically and a preview scan appears.
      5. Select the area of the image you want to scan.
      Figure 1 Preview image with area to be scanned selected
      6. Click Options in the toolbar to adjust settings specific to your scanner.
      Figure 2 Options icon
      7. Adjust any settings in the drawer that appears.
      8. Click Scan.
    The scanned image is saved in your Pictures folder in your home directory and opened in Preview.
    Note: These are the default options. They can be changed in the Image Capture toolbar.
    Jul 16, 2009 | HP Photosmart C6280 Printer
    Help
    Scanning
    The following steps show you how to scan and save images.
    1 Open the top cover of the All-In-One.
    2 Place the item you want to scan facedown on the glass. Make sure the
    upper left corner of the front of the item aligns with the arrow
    3 Close the top cover.
    4 Open the Lexmark All-In-One Center
    The All-In-One Main Page appears.
    5 Click Preview Now located in the upper right corner of the All-In-One Main
    Page.
    An image of the scanned item appears in the preview section.
    6 Click and drag to select a specific area of the preview image to scan.
    7 Click See More Scan Settings to review and change the scan settings.
    8 Select your scan settings.
    From the “Send scanned image to” drop-down menu, select a program to
    send the scanned image to, or click the Creative Tasks section to display a
    list of projects.
    Oct 13, 2008 | Lexmark X1240 All-In-One InkJet Printer
    I am trying to scan pictures onto my computer using lexmark 2600 series
    How to Scan on Imac using the Lexmark 2600:
    1. From the Imac Desktop select the Magnifying glass in the upper right corner of the screen.
    2. Search for Preview
    3. Open Preview App
    4. Put item to scan on Lexmark Glass Face down and close the lid.
    5. Select File (In Preview from Top tabs on desktop), then Choose 'Import
    Image'
    6. Lexmark 2600 Series Window opens
    7. Change Scan to Folder, Name and Format to your choices
    8. Use cursor to highlight area of image to scan in the 2600 Series Window.
    9. Hit Scan from the 2600 Series WIndow.
    10. Save the file using the File tab in Preview, and choosing Save
    Aug 27, 2008 | Office Equipment & Supplies
    Microtek SCANMAKER 4850 Flatbed Scanner Logo
    555 people viewed this question
    Top Microtek Office Equipment & Supplies Experts
    Alun Cox
    Tony
    Are you a Microtek Office Equipment and Supply Expert? Answer questions, earn points and help others
