Question about Insignia IS-PDVD10 Portable DVD Player
Upo insertion of dvd disk, the screen begins rolling. How to stop
In trying to correct the screen size, the screen began rolling. I am unable to stop the roll. TV is o.k., so I might have inadvertantly pressed the wrong button on the remote. How do I get back a stable screen? Many thanks..MS
    Genius:
  • 1,239 Answers
Hi
first leave the tv 5hr sleep and try a hard reset.it would definitely works it is the common solution..
if not MAIN BOARD IS MALFUNCTIONING...THERE ARE TWO MAIN BOARDS FOR THIS TV...IF S/N STARTS WITH W2702..USE P/N 5600110351...IF S/N STARTS WITH W2751..USE P/N 5600110493...PART SHOULD BE WARRANTIED FOR AT LEAST I YEAR...LOOK AT YOUR RECEIPT..
Posted on Jan 10, 2009
  • 10,594 Answers
Check for auto color system in menu of TV while playing dvd.
    Genius:
  • 1,550 Answers
Check the screen switch on the right top side where the door closes there is a little circle and the release switch.
    Sergeant:
  • 431 Answers
There will be an option named "vhold" in your TV or remote..Try adjusting it..
  • nematics
    nematics Jan 10, 2009
    Set the "hold" value to zero...this feature is generaly needed when a frequency of a particular input signal varies..If you put a DVD to play with, which may be a different frequesncy for the TV. During such circumstances the TV adjusts this "hold" automatically. WHen it doesnt the screen experiences a instablity in the display thereby rolling of the picture display..
What size dvd 's are used to burn a movie from my Acer aspire 5517? I tried to burn a dvd and cd once and was unable.
The process is rather simple once you get the hang of it. Many people use various conversion software programs to convert their movie file to prepare them for a DVD. Although in the beginning it is complicated but after a couple of stabs at it. You will be burning movies.
The size normally would be 4.7 Gig standard DVD-R you can use RW if you plan to rewrite over the movie later. It will hold a single movie or approx: 4-5 depending on size if the files are not converted. You can convert the movie files using Winavi this is what I use. or you can try to find any free burning software program out there. Winavi for me was the simplest to process it is a approx: 3 step process.
You will be burning the Video from the file once converted. The audio is included during the burning process. All you need is one DVD-R place in the burner. Then open the conversion software and open the video file and convert and burn that is about it. For higher graphics quality it will take more of the disk space for less or normal it will take approx half the disk that way you can fit two movies on one disk basically. So the process is converting the movie to be prepared for the DVD to work on standard players.
Check out Winavi this is what I would suggest maybe someone else knows a free software conversion program you can use. John
May 10, 2012 | Acer Computers & Internet
DVD drive on Asus a9rp not being recognised. Selected in the bios set up. Just stopped working. Yellow activity light comes on for a while when a disk is inserted but disk not recognised on the screen
Your CD drive unable to read the CD inserted in the drive.So please checkout the lense or check the data cable which connected to cd drive is working properly or any fault is there.
Aug 19, 2010 | ASUS A9RP Notebook
Incert dvd read out sats NO
Hello
This usually happens when the DVD or laser lens pick-up has become dirty.All you need to do is
1. Check the disk for scratches.
2. Make sure the disk you are using fit the correct format specified by your DVD player.
3. Clean the laser lens with a DVD laser cleaning disk.
4. Insert a correctly formatted undamaged disk into your player,listen to see if it begins to read the disk,if it continues to make no sound.
5. Open the DVD player carefully and clean the lens with isopropyl alcohol and cotton swab.
6. If none of these solutions works out then a professional repair technician will be able to tell you if fixing your DVD player is worth the money.
BEST OF LUCK
Jul 13, 2010 | Toshiba SD-K760 DVD Player
Feeder grabing the paper crooked causing jams and paper unable to go through the feeder smoothly. it stops once the feeder grabs the paper.
set the paper tray size to the size of the paper...if this is ok...clean the pick upo roller with damp cloth and soap water...if this doesnt help ...change the pick up roller..
keep me posted
May 04, 2009 | Computers & Internet
Memorex DVD problem -- rollig screen on TV
How is the dvd player connected to the tv?
Mar 21, 2009 | Memorex MVD2050-BLK DVD Player
Samsung bd-p1400 will not play certain disks
My dark Knight DVD was only playing the first 4 screens and I burned the firmware upgrade to a CD. It took about 20 minutes from the time I inserted it for it to be complete, then it stopped at 4 again but took about 30 seconds and it began to play perfect.
Dec 25, 2008 | Samsung BD-P1400 Blu-Ray Player
Dell Inspiron-1520 unable to read RW DVD's.
you have a faulty disk inserted in the drive. Restart the computer and continuously press eject while the pc is booting, it should eject then.
Oct 11, 2008 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
Cyberhome 402 DVD "rolls"
I think I had switched to the PAL format by mistake. Fixed the problem by buying a new DVD player, was cheaper than the factory fix.
Jul 30, 2008 | Cyberhome CH-DVD 300 DVD Player
How to reset dvd recorder to ntsc from pal
After checking today to see no one offered any suggestions - I solved the problem the hard way - I went into settings and although the screen rolled, I was finally able to click onto the ntsc setting after about a half hour of tries and once I clicked it, my screen returned to normal -- i was then able to enter the code that made the player an all region player and was happily able to play a pal dvd I received recently. The procedure was simple -- offered by a European Cyberhome user -- the company is in bankruptcy so you cannot gt help from them. Note - my Cyberhome dvr is 1500- not 1600 as you listed it.
Feb 11, 2008 | Cyberhome DVD Recorder - DVR1600
DVD not playing
here is the link to the user manual, troubleshooting and venturer support contact details; http://www.1800customersupport.com/products.aspx?view=93&p=43&sc=5&sn=Portable%20DVD%20Players&pn=DVD%20Players%20and%20Recorders Hope this helps, please post again if not :)
Jan 30, 2007 | Venturer PVS177W Portable DVD Player
Insignia IS-PDVD10 Portable DVD Player Logo
57 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
