Question about Orion HCCA-25001 - Mono Block 2500W RMS HCCA Series Competition Car
Orion hcca 25001 two alp typ r's 15" dual 4 coils think i over powered them turned up volume too much lol need a faster way to reset this amp manual says to unhook power & remote for 30 second
I raised the subs to 4 ohms they are not blown. i have reset it before just takes too much time if i run a dvm to 12v+ the volts drop slowly is there a faster way? any input would be helpful thanks
Orion hcca-25001 amp blue and yellow light stays on and still plays
i have a hcca25001 amp need to know if the blue light and the yellow light suposed to stay on when amp on
Jul 04, 2012 | Orion HCCA-25001 - Mono Amplifier
I have a 10.2 Orion Hcca subwoofer 4 ohm and wanted to know if I can put each coil to each channel its a Brutus 1200 watt 2 channel amp model 1210d is it safe for my woofer and how much rms wattage I'm...
You would need to know what power your amplifier supplies at 4 ohms. In reality, you would be better off bridging the amplifer and wiring your sub in parallel to a 2 ohm load. This would allow you to pull the most power out of the amplifier. It would be safe to do a voice coil to each channel on a 2 channel amp. However, if you happen to have a 4 voice coil sub and attempted to put two 2 channel amps to it, you would have to make sure your amps are leveled. No easy feat. The variance you could have with that could damage the voice coils. But luckily, that's not your case.
Sep 09, 2011 | Orion HCCA 10.2 Car Subwoofer
Specs for orion 12" hcca
* Sensitivity: 84 dB
* RMS Power Range : 2000 Watts
* Peak Power Handling: 4000 Watts
* Impedance: 2 Ohm
* Diameter: 12 Inch
Features
* 4" Copper Wound Voice Coil on an Aluminum Former, High temperature PAARC (Polyester Amide, Amide Resin Coated)
* Continuous power handling will be 1500W (under rated)
* Burp power in excess of 5000W
* X-Max estimated at 30mm (total travel 4" peak to peak)
* Field Replaceable Cone / Voice coil / Spider Assembly
* Dual Flat Conex Spiders with Loop/Stitched Tinsel Leads
* Tall, wide, balanced, Foam (high density expanded polyester foam) surround for linear controlled long excursion using a Tri-Radius symmetrical edge design optimized on non-linear FEA
* Enhanced voice coil cooling system (forced convection ? aluminum heat sinking ? shorting rings to reduce inductive heating)
* Dimensions (in) 11.9 x 10.7
Jan 04, 2011 | Orion HCCA 12D Car Speaker
My Orion d-5000 amp which is wired to an Orion hcca 12.2 sub cuts out at high volumes , it's wired with 0 guage wires
Your speaker is a dual 2ohm sub. If you have both voice coils wired Parallel that will drop the ohm load to 1, which the amp can not handle. You need to wire the voice coils in series. Treat each voice coil as a speaker.
Jun 30, 2009 | Orion HCCA-D5000 Car Audio Amplifier
My orion d5000 cuts out at high voloume for a few seconds then comes back on ????? why
Hello m3_sam,
You did not say what you have the amp wired to and what impedance. Since the amp produces more power at a lower impedance, it does make a difference.
At 4 ohms, the HCCA-D5000 delivers 1000 watts RMS. The higher the volume, the more the amp needs to draw from the battery.
Assuming everything is installed according to specifications, especially the dual 4AWG power and ground connections, it's likely that your vehicle battery/alternator is simpy not able to keep up with the current demand of the amp at high volume. You should probably consider upgrading your vehicle alternator and/or battery. In addition, consider a "Big Three" upgrade. This involves replacing or supplementing the battery positive, vehicle negative, and alternator cables to ones of larger gauge that will allow more current flow. Installation of a capacitor could possible solve the problem, but with the current demands of your amp, I wouldn't count on it.
Hope this helps.
Apr 22, 2009 | Orion HCCA-D5000 Car Audio Amplifier
Orion hcca 250 digital reference & orion XTR 12" 500w dual subs
If you have one sub dual voice coil, just paralel the sub and conect to brigde amp. Simple...
Mar 02, 2009 | Orion HCCA-D5000 Car Audio Amplifier
Orion hcca 250
i can make this relatively simple.
2 stages:
Stage (1) wiring the Sub inside the box;
Unscrew the SUB from the Box, (& undo the wires)
Connect both +Positive terminals on the SUB to the +Positive terminal on the inside of your BOX.
Connect both -Negative terminals on the SUB to the -Negative terminal on the inside of your Box,
Then screw the SUB back into the Box.
u Have just wired yr sub in parallel. any Amplifier will see it as 1woofer with 1OHMs resistance.
Stage (2) bridging your amp
(please check Amplifier instructions on which terminals to use)
generally you use "LEFT -Negative" and
"Right +Positive"
and connect to the corresponding terminals on the Sub Box.
Hope that helps someone.
Feb 25, 2009 | Orion HCCA-D5000 Car Audio Amplifier
Orion HCCA-25001 - Mono Block 2500W RMS HCCA Series Competition Car Logo
21 people viewed this question
Top Orion Car Audio & Video Experts
Tygh Duval
Tygh Duval
Steve Sweetleaf
Steve Sweetleaf
Are you an Orion Car Audio and Video Expert? Answer questions, earn points and help others
