Question about Magtek Mag-Tek 30050202
How do I fix a cardswipe that reads "OFFILNE Code K01"
I plugged in my brand new card swipe ipad and after a screen says initializing it simply says "OFFLINE" Code K01. How can I fix this? I have plugged it into 2 different computers with the same message.
My nitflix on my Apple iPad is lock up just red screen with nitflix world showing
Here are the things I would try.
1.Close the Netflix app. Double click the home button on the iPad and swipe the Netflix app to end it.
2. Restart the iPad. Hold the power button and swipe the screen to turn off the iPad
3. Delete the Netflix app. Tap and hold the Netflix app's icon and choose the x in the corner to remove the app.
4. Re-add the Netflix app to the iPad from the app store.
Dec 30, 2014 | Apple Cell Phones
2 ipad problems
By replacing the screen you have to connect 3 ribbon cables.One of them is the digitiser (touch panel) and most likely this connection isn't good. Usually i check this while the iPad is still open.
Sep 23, 2017 | Apple iPad 2 tablet 16GB 3G
How remove item iPad reading list?
Swipe from right to left.
If that doesn't work, close Safari and reboot your iPad.
Double tap tap the home button and then swipe up on the Safari preview screen that you see right above the Safari icon. Swiping up on that screen will close the app.
Hold down on the sleep and home buttons at the same time until the Apple Logo appears on the screen. After the iPad starts up, try again.
Jul 24, 2014 | Apple iPad (16 GB) WiFi Tablet PC
Upside down screen on ipad
The Auto-rotation setting must be disabled. Enable it on the settings menu. Or if your tablet is running iOS 7, then enable auto-rotation on the Control Center. Simply swipe up from the bottom of the screen to launch control center. (It is like the opposite of pulling out Status Bar or Notifications Bar above.)
Apr 22, 2014 | Apple iPad 2 Wifi 16GB
Ipad mini screen replacement
i bought a ipad mini screen replacement replaced the magnets then attached the screen and LCD but when i go to scroll /swipe if wont swipe is this a faulty screen because the ribbon connectors are in place also did a soft reset no joy i think this is a faulty screen can anyone help with this issue please
Jan 07, 2014 | Apple iPad Tablets & eReaders
How to unfreeze candy crush game
Double click the home button to bring up all the open apps on your iPad. They will list in a line across the bottom of the screen. If you are on iOS7 or later you simply swipe the screen shot of the app upwards to close the app completely. Then go back to your home screen and open the app as you normally do. This should force the app to reboot and work as intended.
Apr 26, 2013 | Apple iPad 2
Overdrive media console is frozen on my iPad 2
Double tap your home button (middle bottom). When you see your open apps press and hold on the overdrive app until it wiggles. Tap the red X to close it. Then, tap on the overdrive app icon again to reopen the app. You'll be at your bookshelf but, tapping on the book you were reading will return you to that page.
Mar 26, 2012 | Apple iPad 32 GB 3G Tablet PC
Any thoughts on 'Darts' app for the iphone?
This app is not another scorekeeper app but lets you PLAY darts on your iPhone or iPod touch!
Throwing a dart in the game is as simple as swiping your finger from the bottom of the screen upwards. To throw towards the left side of the board, simply move your finger left as you swipe upwards. The speed of the upward swipe controls the initial speed of the dart. The distance your finger strays from the center of the screen controls its initial direction. Be careful to get the speed right otherwise you might miss the board entirely!
Note that it does take some practice to get used to the controls but once you learn them, you will be able to hit any spot on the board at will!
Sep 07, 2010 | iPhone Apps
Screen reading memory card not initialized
help me i also have the same problem please email me how you fixed the problem? cdcdcmiura@hawaii.rr.com
mahalo's
Feb 17, 2009 | Fuji Finepix Z20fd Digital Camera
Magtek Mag-Tek 30050202 Logo
111 people viewed this question
Top Magtek Computers & Internet Experts
David Payne
David Payne
Are you a Magtek Computer and Internet Expert? Answer questions, earn points and help others
