Question about Hamat 3-3141ST Country Classic Bar Faucet with Lever Handle Stainless Steel...
How do i remove the Lever. I removed the cap and the lever is exposed, do i just pull it off? I have a Hamat 3-3141 Country Classic
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 27 Answers
Not familiar with that model, but if you look near the base, you should see a tiny ,tiny hole,use proper size allan wrench to remove set screw, handle will lift off
Posted on Dec 21, 2012
2 Suggested Answers
SOURCE: I have a Hamat faucet that has low water pressure all of a sudden
I have the exact same faucet from Hamat and I just took it apart ...every last bit....the tabs on each part are notched so when you put it all back again...its pretty easy....I had every single part layed across the table.
(Below is the red neck way....without the special tool to take off the top key part which requires a special T tool)
now for the desembly.... under the handle is the red/blue button...unscrew carefully not to ruin the color...if it does not come out ...pry it out...mine was not so friendly....then take a small hex and stick it in the hole and unscrew a small screw....whalllaaa ...the top is off....now for the only hard part of this whole project....without their special tool your going to have to take a vice grip layed over a cotton cloth and clamp it on the top back side perpedicular....on the actual crome/stainless steel....this part will not be seen from the front.... I did scratch mine a bit ...but dont see it after the fix...remember it under the handle on the backside....then take another vice grip and cloth to the part you stick in the counter....(not the threads of course...just above) then with hulk like procedures your going to give it all.....hold with the left the base vice grip....and with the top ...crank it counter clockwise....again with the vice grip perpendicular ...on the back edge...I had to use a small screwdriver or rod to stick it across the vice grip for leverage.....erggggg....got it.
after that take note of how the part fall out.....eventuallly you might need to take out the cylinder.....remove the hose (did it at begininng) then wiggle....and pull out the cylinder...dont unscrew....back and forth in 10 degree turns as you pull out.....this is not screwed in.....Only One big screw already taken care off... the hoses connected in the interior are tough and for some wierd reason need a 10mm wrench.
Ok good luck....and by the way MINE DID NOT HAVE HOT WIRE...a part of rubber washer came loose from my plumbing under the counter and found its way to block hot water...inside the very core of the faucet....oh well ALLL DONE.... hot water for dishes...for my wife...just kidding.
Posted on Aug 09, 2009
Handle is stiff to operate
remove trim to expose valve, apply stem-grease to valve with fingers and re-assemble. turn valve on and off several times. like new
Dec 12, 2012 | Hamat 3-2810PC Everest Pull-Out Kitchen...
How to take out aerator for cleaning
doesnt the bottom of the tap end unscrew as the the jet thing is behind this
Dec 21, 2011 | Hamat 3-2861ST Everest Pull-Out Kitchen...
Where can I get a replacement hose 1.5 meter long?
Contact Hamat
Techincal Support or Warranty
Parts
Call 1-866-52-HAMAT - option 6 or extension 1242
Hours: Monday - Friday - 8:30 AM to 5:30 PM est.
email: support@hamatusa.com
Mar 24, 2011 | Hamat 3-2865PC Everest Pull-Out Kitchen...
Trying to remove the stick shift from a 1992 toyota pickup to replace the clutch
REMOVE TRANSMISSION SHIFT LEVER FROM INSIDE OF VEHICLE
    • Remove the four screws and remove the shift lever boot retainer.
    • Pull up the shift lever boot.
    • Cover the shift lever cap with cloth.
    • Then, pressing down on the shift lever cap, rotate it counterclockwise to remove.
    • Remove the shift lever.
62409690
Jan 22, 2011 | 1992 Toyota Pickup
My cartridge leaks inside the faucet. Is it possible to replace the cartridge or must I buy a new faucet?
You can find the replacement cartridge online, as Hamat is out of business...
I am ordering mine today too, www.plumbingsupply.com
about $60
Nov 21, 2010 | Hamat 3-2861ST Everest Pull-Out Kitchen...
How can I remove this faucet to allow me to replace this fixture?
there is abacking nut & plate securing tap to sink, most are 1/2 inch use long socket to make it easier, also you must disconnect pullout hose from tap (connection also under sink) & remove hose weight located usally at the bottom of pull out hose. Make sure you isolate all water first!
hope this helps
Nov 07, 2009 | Hamat 3-2861ST Everest Pull-Out Kitchen...
Hi The gearstick has completely come adrift
Hmmm, that would have been disturbing... Fixing it depends on where it has come apart, the main lever is connected to the stub lever via a rubber bush and crimp, the stub lever is retained with a push and twist cap. either way, you will need to remove the console via 4 screws, 2 each side. push the rubber boots for the gear lever and transfer case through the console to remove it. remove the 4 lower gear lever boot bolts and lift it up to expose the gearbox, there is a metal clip retaining a rubber cover and under that is the push and twist cap. push it and rotate anticlockwise. if it won't come off, removing the 2 bolts either side of the housing will also release the gear lever. The whole lot should then come away and you should be able to see what part has let go...
Jun 30, 2009 | 1999 Suzuki Vitara
Removing and replacing passenger side mirror 2002 town and country van
there should be a triangle shaped plastic section on the interior of the door behind the mirror, check it for a little plastic screw cover to remove it or you may just have to lever it gently to remove it.
once it is off it exposes the mirror retaining bolts which you undo to remove the mirror, I presume it has electric mirrors and if that is the case you will have to find the electrical wire plug for the mirror and pull it apart, replace mirror in reverse order of removing
May 12, 2009 | 2002 Chrysler Town & Country
I need to find a replacement Hamat part
Simply go to hamatusa.com and look for a dealer near you. Very good european brand by the way.
Feb 14, 2009 | Hamat 3-2861ST Everest Pull-Out Kitchen...
Hamat 3-3141ST Country Classic Bar Faucet with Lever Handle Stainless Steel... Logo
199 people viewed this question
Top Hamat Plumbing Experts
Colin Stickland
Colin Stickland
ray gallant
Daryl Gleaton
Are you a Hamat Plumbing Expert? Answer questions, earn points and help others
