Question about LG WD-14124RD Front Load Washer / Dryer
Hotpoint wd645 flashing f-08
My hotpoint washer/dryer wd645 has just stop and is now flashing f-08 please can anyone tell me what part this is and is there any way i can fix it...It still makes a sound like its trying to do somthihng.
    President:
  • 373 Answers
The manual says F08 - Heater relay cannot be activated.The dryer might be having difficulty with this.It is not something that can be fixed.Heater Relay equipment might be damaged.Might have to call a repairman to set this right.Good luck.Do post comments for more help.
Posted on Jan 10, 2009
My aquarius washer/dryer wd645 is flashing f-07
dont warry it will be for few time then it will be ok
Mar 30, 2015 | Hotpoint -Ariston Aquarius WD645 Front...
I NEED A MANUAL FOR HOTPOINT AQUARIUS WDL520G
You should be able to download the user manual from the following site: hotpointservice.co.uk/pages/manual
Or directly download from this link: Hotpoint/Laundry/WDL520 (pdf)
Hope helps.
Sep 25, 2011 | Hotpoint -Ariston Aquarius WD645 Front...
I have a code on the display f-08
hotpoint washing machine WT740 1400 code erroe F-08 flashing machine stops working after 20 minutes please help
Jan 19, 2011 | Hotpoint Aquarius WD640 Front Load...
Clean Filter?
There is a filter at the rear of the washer.
Remove lower rear panel.
Remove large black hose from bottom of drum.
Remove and clean filter in inside hose.
Remove hose onto pump and check for blockage oe obstruction here as well.
Please rate my solution.
Thankyou.
Jan 27, 2010 | Hotpoint -Ariston Aquarius WD645 Front...
Hi ,, my machine has no power ,, when i push the start button there is nothing at all ,, no lights nothing ,, i have tried the plug and fuse ,,the machine is the hotpoint wd645 ,,, many thanks
Try the plug in another socket that you know is o/k, if still no go ,then you need to remove top cover and rear panel, and check all connectins to control module/s.
Make sure the door is fully catch is fully engaged, as sometimes the spring can give out in the door handle.
Jan 16, 2010 | Hotpoint -Ariston Aquarius WD645 Front...
Wd645 has no power to on/off switch. changed plug
Could be mains choke. Mains power comes into mahine via wall socket /worth checking this then onto mains filter/Choke..then to switch..So if no power here check this..wish you well
Oct 07, 2009 | Hotpoint Aquarius WD640 Front Load...
Tumble dryer isn't woking
You may need to replace the thermostat or the heating element.
Apr 13, 2009 | Hotpoint -Ariston Aquarius WD645 Front...
Hotpoint Aquarius Wf740 F-08 just before rinse and spin.
Hi my Hotpoint WF740 keeps flashin H20. Does anyone know why please?
Jan 15, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint ultima wf 860
Taken from another post - just happened to me 5 mins agao so not fixed yet!......now showing F-01 (motor triac short circuit).....
F-08 heater relay stuck check pressure switch, heater and module connections poss pressure switch fault
Good luck and let me know if/when it's sorted as may give me an indication of costs etc
Sep 18, 2008 | Hotpoint Ultima WF860 Front Load Washer
'test' displayed on washing machine
After pressing different buttons and waiting 10 to 15 seconds after turning the power off, I have finally found the solution.
When you have pressed the "Start/Cancel" button to start your wash programme the LCD shows "test".
You must then press the "Start/Cancel" button which will give you the normal temperature and washing time and then importantly you must depress both the "Start/Cancel" button with the "On/Off" button which will give you a different LCD message and then it will automatically resets itself.
ALL THE BEST!
Jul 31, 2008 | Hotpoint Aquarius WD640 Front Load...
LG WD-14124RD Front Load Washer / Dryer Logo
330 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
