Question about IBM 8224 Ethernet Stackable Hub 73g9764 8224-002 16 Port
Which port to place network in put
I can't get a connection. Which port does the net input go? This is 16 port hub with expansion in and out ports. I really need help. Thanks
  • IBM Master
  • 2,072 Answers
If it is a hub then you can plug any device into any port. It doesn't matter which. All a hub does is broadcast data received on anymore out all the other ports at half duplex speeds. I'd recommend getting a switch instead. Same price and they don't suffer from all weaknesses a hub has.
Posted on Dec 02, 2012
2 Suggested Answers
jadiazq
  • 2878 Answers
SOURCE: No, Really. I have 16 ports. And two labeled expansion in/out. Really where does the net in cable go?
The Expansion IN port. The OUT port is for adding another hub. The key word being stackable, in case you need more than 16 ports. Hope this clears thing up.
Posted on Nov 28, 2012
Nov 28, 2012 | IBM 8224 Ethernet Stackable Hub 73g9764...
How to connect IBM 8224 002 Hub
Connect the ISP modem to main IN uplink port. Then connect pc to any other port. Done!
How to fix netgear Prosafe 16 port Model #FS116
Unplug, power off, wait a couple of minutes. If they don't come back toss it and replace.
Mar 26, 2012 | NetGear FS116 16-Port Ethernet Switch
I use a Dynex USB 2.0 4-Port hub in a mailing machine. I keep getting brand new hubs that quit and won't power up. Leaving all the same cables and plugging in a new hub and it powers up. I am also...
You are probably putting too much current through the hub. 1 USB port is good for 500mA, and since this splits 1 into 4, you're working with 125mA per device if you have 4 things connected. Find a powered hub instead.
May 06, 2011 | Dynex 4-Port 10 Mbps Ethernet Hub
How do i connect 2 d-link switches
i found that there is a MDI uplink port for cascading
Dlink DES-1016D 16-port 10/100 Switch
Product Features
  • 16 10/100Mbps ports
  • Full/half duplex support for each port
  • MDI uplink port for easy expansion Expansion is easy through a MDI uplink port. You cascade several switches together through this port to get more ports.
  • Auto-learning of network configuration
  • Flow control in full duplex mode for protection against data loss
  • Back pressure in half duplex mode
  • RAM buffer dynamically allocated for each port
What's Included?
  • DES-1016D Network Switch
  • Quick Installation Guide
  • CD ROM
Aug 27, 2010 | D-Link DES 1016D (DES-1016D) 16x10/100...
Reconecting the cables to the hub does not make a network
Not necessarily! As long as a lan cable is connected on the wan port of your hub and the other end goes directly to the modem, the connection is correct. The remaining port will be left for the lan cables of the computers. No orders needed. Just make sure that lan cables was properly seated on the port. The LED blinking in the hub will tell you if its working or communicating with your computer. Find it, when the LED is not lit or blinking, the lan cable is not connected properly on the hub (or the other end of the lan cable is disconnected from the lan card of the computers).
If all cables are connected properly and still cannot connect to the network, you may need to refresh the name of the workgroup on the computers that cannot connect on the network,
How? Right click on My Computer.
Select Computer Name
Click Change to change the name of the workgroup that is being use by other computer. Delete the old name if the same and retype.
Restart the computer and try to connect using network neighborhood.
Jul 07, 2010 | D-Link DSH 16 (DSH-16) Networking Hub
WAN's not working - OnQ 6 Port Telecom Expansion w/WAN's
It looks like the telecom module won't work for what we're trying to use it for. Take a look at this thread, which describes the reasons why.
http://www.dslreports.com/forum/r23454500-Help-With-Ethernet-Wired-Home-Network
Feb 07, 2010 | Legrand OnQ 364733-01 - 8-Port 10/100...
My two computers cannot pass through my broadband provider (through the switching hub) at the same time.
that is not possible for an single isp connection you can only connect one computer at a time and hub is basically a repeater that is it simply repeats the packets it receives from one input out the others.
May 18, 2009 | Encore ENH905-NWY (ENH905NWY)
Hub and switch difrance
Switches are smarter than hubs.
Lets say you have a switch with 16 ports, your computer is connected to port 2 and you are browsing the internet. You make a page request and when the reply comes back it hits the switch and the switch forwards the information to port 2.
This does not happen with a hub, the hub does not know you are on port 2, it sends the information to every port, in this case all 16 ports. In a low traffic environment a hub can be ok but it can cause a lot of unnecessary traffic on your network and slow it down.
If you have a choice pick a switch over a hub, there is not that much of a price difference these days.
Sep 26, 2008 | Foundry Networks EdgeIron (EIF48GS)...
SMC ethernz problem
Typically you will connect your router to port 1 of the switch. Unless you have a port that is labeled WAN or Uplink. Then you would use that.
Daisy chain is when you have multiple switches connected to eachother. So it would be router to port 1 computers on ports 2-15, port 16 would connect to port 1 on another switch, and so on.
Jul 20, 2008 | SMC EtherEZ Networking Hub
IBM 8224 Ethernet Stackable Hub 73g9764 8224-002 16 Port Logo
224 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
