Ebac 2200e dehumidifier fan not operating
I have an ebac 2200e, the unit turns on and the compressor runs but the fan does not spin, the compressor gets hot and the unit turns itself off until it cools down and then the compressor starts up again, does anyone know wether it could be the fan thats inoperative or the pcb board and if these parts can be purchased anywhere ?.
SOURCE: dehumidify mode also cools
Some units do cool/dehumidify only im afraid why cant you let the unit dump its hot air into the room then it wont heat or cool the room?
Posted on Feb 15, 2007
chillmaster
  • 104 Answers
SOURCE: compressor wont start
It is probably a failed run capacitor for the compressor. Without the capacitor, the motor can't even try to run, but it will draw extreamly high amperage until it trips the thermal overload (avarage trip time 5-10sec) after it has a few second for the safety to cool off, it will try again. Either that or the compressor truly is seized
Posted on Jun 23, 2008
  • 10 Answers
SOURCE: Outdoor unit does not start. indoor unit fan does run.
by the sound of it the relay in the outdoor section is bad
Posted on May 31, 2009
  • 4 Answers
SOURCE: Blowing hot air, compressor not kicking on, just fan ? ?
are you speaking of the outside fan or inside? compressor should be a little warm but not boiling hot. the unit could be low on freon. if low it will run a while but the compressor will overheat and shut off leaving the fan running by itself ouside. if nothing outside is running check power. if you have power check the contacted outside to make sure it's pulled in. contacters are bad about going out on goodman untis. Also ants can get under contacts.
Posted on Jun 18, 2009
  • 534 Answers
SOURCE: Amana Cooling Condensing Unit fan won't kick on
be aware that not repairing this asap that you are causing yourself more problems First I would change out the fan capacitor and see if this could be the problem. Secondly if the capacitor isn,t the problem change out the motor . By continuing to allow the system to cycle like this the compressor will take a dive on you costing more . Good Luck
Dave
Posted on Aug 04, 2009
Testimonial: "Yes, it's dual run capacitor problem. I used a stick to spin the fan blades and it starts to slowly spin and up to normal speed, so motor is good."
Where can i get a filter for an Ebac 660 Dehumidifier
perhaps thru EBAC or where you bought it .
May 15, 2016 | Ebac Dehumidifiers
My ebac 2000 is making a noise and not collecting water
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
May 23, 2011 | Ebac Dehumidifiers
Where can I get a Ebac Dehumidifier filter replacements in New Zealand ?
If your 880 model is the NZ 870 model, the fan motor can be got at Carrier Air Conditioning, part # SP-W3035766, for around $105.00.
Noel
noel.bee@xtra.co.nz
Jul 09, 2010 | Ebac HD880 Dehumidifier
I HAVE A EBAC HOMEDRY 880 dehumidifier LOOKING FOR A FAN MOTOR THE MOTOR AT PRESENT IS A MAGNETEK UNIVEARSAL ELECTRI LTD 220/240VOLT 50HZ 0.16A impedance protected
Hi, If you are in new Zealand and your 880 model is the NZ 870 model, the fan motor can be got at Carrier Air Conditioning, part # SP-W3035766, for around $105.00.
Mar 20, 2010 | Ebac HD880 Dehumidifier
Replacement fan motor for ebac homedry 880 dehumidifier. fan motor Mod No aa2c6235
Noel
Feb 27, 2010 | Ebac HD880 Dehumidifier
My ebac 2650e has started shuddering when on the eco auto setting but is fine on fast settings. It also makes a rattling sound. help!!
The fan is mounted on a very poor quality 3 angle mount. The weight of the motor distorts the mount over time so the the fan starts clipping other fittings when spinning. You can turn the mount around so the motor hangs upright again. The latest EBACs are of very poor quality...
Feb 15, 2010 | Ebac Dehumidifiers
I have an ebac dehumidifier i think 6000 model and it appears to work fine. the fan runs ok the compressor seems to kick in ok but the tank will not fill. i had it on in my room for approx 30 mins and...
If the room temperature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defrost over night.
Only specially made dehumidifiers work below a room temp of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensor from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Dec 19, 2009 | Ebac HD880 Dehumidifier
My dehumidifier no longer gets warm whats wrong
The thermosenser on the fan motor may be blown if the fan isn't blowing.
If it is also not extrating motsture then ther may be a coolant/compressor issue - time for a new unit
Dec 05, 2009 | Ebac HD880 Dehumidifier
Ebac xl Dehumidifier not collecting water
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Oct 11, 2009 | Ebac CS60 Dehumidifier Dehumidifier
User instruction
Here is the link for the Owner's Manual off the Ebac website:
http://www.ebacusa.com/technical/Manuals/HD.pdf
Jun 30, 2008 | Ebac HD880 Dehumidifier
Heating & Cooling Logo
120 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
