Question about Sennheiser RS 110 Consumer Headphones
Audio cable snapped -
Trying to fix it, I have stripped the wires back. The tiny red and blue wires (that are inside the red jacket - that's inside the black cable) are they separate signals? To clarify Split black cable Red coated wire Silver wire Split red cable Red and blue wires - don't appear insulated in any way.. Anyway I tried both options of connecting them up but still can't pick up a signal
    Master:
  • 586 Answers
Buy a new cable. I don't know what the application here is, but if you have the capacity, go to either HDMI, digital or optical, rather than straight RCA cables.
Posted on Jul 29, 2017
SOURCE: HAVE NEW SET OF hEAD pHONE CANNOT PULL A SIGNAL IN STATIC THERE BUT FAINT...
Make sure you are connecting to the OUTPUT section and not the input, look in the back of the television it should say output and have its own red and white pluga, if you connect the red and white cables to the input section on the front of the television or on the section on the back that says input you will not get any reception make sure you are connecting to the output
Posted on Dec 31, 2007
  • 1138 Answers
SOURCE: replacing headphone connector
The impedance or resistance of the two different sets of wires might be different. The higher the impedance the less signal. If your cable is long enough you are better off spending the five or so dollars for a new plug. Red is right, green or blue is left and copper is ground.( Usually) Unfortunately not all manufacturers agree. Also what could have happened is a short between the wires that you soldered.Make sure they are physically separated from each other and insulated.
Posted on May 14, 2009
  • 435 Answers
SOURCE: My Sennheiser HD 205 suddenly
The two copper wires on your headphones are independent grounds for each channel. Twist them together and attach them to the ground cable ( black) of the new plug. The colored wires of the headphone correspond to the live wires of each channel, and the plug should have the same colors. Wiring together the grounds will not affect in any way the stereo separation, it is just that each ear needs its own ground. Cheaper headsets just transfer the ground from one ear to the other one through the metal headband.
Posted on Oct 06, 2010
  • 215 Answers
SOURCE: a cat chewed throught the wire do anyone have a
One method is to bare the ends of the individual wires, and lay the cables side by side.
Don't worry about uneven lengths, just as long as you can get the appropriate wires together.
Solder or even twist them together, and tape each connection to prevent them shorting out.
Heatshrink tube is great here if you have any. It males a tidier repair.
Now tape together the paired cables for about an inch, then lay out the cable so it is straight and bend up the join to lay along it and tape it there.
This prevents strain on the joins.
I don't know about a wire wheel, it might not be delicate enough for this application, but thank you, I'll remember it and try it sometime.
Posted on Jan 29, 2011
prez330
  • 82 Answers
SOURCE: Sennheiser HD 205 Headphones. My
Hi, Ian, If you have soldering experience, you might be able to replace it by yourself. If you remove the portion of the wire that is frayed and replace it with new wiring, it might work. If you feel comfortable doing this, I would say go ahead. However, it might be just as cost-effective to take it to a local audio-repair shop and have them do it. I have had multiple sets rewired myself, and it has cost less than $20 each time. Either way, it should be a relatively easy and cheap fix.
Posted on May 18, 2011
NEED WIRING DIAGRAM FOR SONY CDX-GT520U
red - ignition switched 12 volt
yellow - constant power 12 volts
black - ground wire
orange - dimmer wire don't use
speaker wires
drive side front
white +
white/black strip -
passanger front
gray +
gray/black strip -
drivers rear
green +
green/black strip -
passanger rear
purple +
purple/black strip -
blue - remote amp turn on wire
blue/white strip - either power antenna or remote amp turn on also
radiorepair@windowtintingin239.com
Oct 30, 2013 | Car Audio & Video
My brother mfc 440cn had a paper jam & after i removed the paper "unable to print 50" & "unable to print 30" showed on the screen. i went to brother web site & went to the...
You have to open the printer and set it back into the ph carrier.
1) Remove Plastic wire covers from inside printers, and release plastic stay on lower edge, tilt cover to 90 Degrees 2) make a note of where each connector goes 3) release the Ribbon and 3 Multicolor cables, removing grounding screw, then remove scanner module by sliding it off the hinges at 90 degrees. 4) Remove Three Front Panel Screws, carefully leaver front panel upwards releasing front side clips.5) Remove front panel by disconnecting ribbon and wiring on both sides.6) Remove 6 Screws (2 on back, three at front and one middle right7) Carefully remove speaker cable (Red Connector) and lift up plastic casing, leaving printer uncovered.8) Re-Seat Encoder Strip.9) Re-assemble in reverse.
Nov 08, 2011 | Brother MFC-440CN InkJet Printer
Where is the computer located
The Computer is under the dash board behind the glove box, (First) before you do anything.... Disconect the (NEG) battery cable!!!! Then inside the car, You must remove the lower dash plastic shield held on by 10 screws and then 5 screws holding the base of the glove box. Let the glove box drop down out of the way. Look at the upper back foot wall for a SILVER METAL BOX with (3) big wire plugs. The plugs are (RED - WHITE & BLUE) that's the computer unit. It's mounted on a thick hard plastic back board. Use a Blade screw driver to push on the corners of the back board as you push up to release the snaps of the computer. Do this to both corner snaps. Once you have done that You can pull the computer down and out to the car floor.
Now use masking tape, mark each plug wires to match RED/WHITE/BLUE PLUGS!
Now squiz the ends of the plugs and pull hard to remove them. NOW your old computer is OUT... Buy a New / Rebuilt or USED compoter.
IT'S BEST that you Match the (DELCO NUMBER on your old one!)
**** DO NOT BUY ONE AT THE DEALER!!! THEY WILL KILL YOU BANK ACCOUNT!!!! BUY ONE AT JUNK YARD FOR UNDER $125... MAKE SURE IT IS A DELCO UNIT WITH THE SAME PART NUMBER AS YOUR OLD ONE! *** DO-NOT GIVE THE OLD UNIT TO THE JUNK YARD!!! ***
ONCE You have the repacement unit, remove two screws from the top shield of the new one and your old one. Inside you will see a (BLUE) plug in chip. You need to SWAP them from your old one to the new one.
Squiz and lift out and move your old one to the new computer.
DO-NOT Put it back in the dash yet.... After you have swaped the BLUE chip put the 2 screws back and plug in the RED, WHITE & BLUE big plugs back on the new computer. Let it lay on the car floor for now. Now, go under the hood and RECONECT the NEG to the battery.
Start your car and let it run checking for problems fixed!!! If all OK, take it for a short test drive... If all is well go home and put computer back and reasemble in reverce order. GOOD LUCK!!!
Aug 24, 2011 | 1992 Buick LeSabre
How do i wire red white and yellow rca to an xbox 1 av plug. my av plug has blaack white orange and green wires
In the old school standard AV: Red and White are usually audio channels (Red:Right - White:Left), Yellow is video.
Orange can be coax audio, (both L&R channels in one cable). Before digital (optical) came out, some receivers actually had a coax (orange) jack in the back. Radio Shack sells a splitter if necessary.
In higher resolution systems video is separated into three colored cables: RGB or Red, Green, Blue
called 'component' video. The green cable carries Yellow, the blue cable carries (PB) Blue and the red cable carries Red (PR). And with today's tech, the component signal is carried YCBCR as (digital video.) cf. http://en.wikipedia.org/wiki/YPbPr
Component 'wire colors' are there just to remind us. If your TV has "Component" input. Try green to green, white to yellow and black to red. Orange to audio (splitting L&R if necessary)..
Also, here is a PS3 link that might help: http://www.ps3hax.net/showthread.php?t=9238
Good luck !
Apr 23, 2011 | Video Game Consoles & Games
HAVE A P05091506AE STEREO WANT TO CHANGE TO A JVC KD-R900 NEED TO KNOW WHAT THE WIRING ON MY 2005 DODGE RAM 1500 PIN CONNECTOR IS. 22 PIN CONNECTOR. COLORS ARE NOT MATCHING ANYTHING I CAN FIND ON...
This is the wiring codes
2005 Dodge Ram 1500 Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Brown/Red
Car Radio Ground Wire: Black/Dark Green
Car Radio Illumination Wire: Orange/Dark Blue
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: Dark Green/Red
Car Stereo Amplifier Location: Located behind the glove box.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Dec 25, 2010 | JVC Car Audio & Video
03 monte carlo ss power seat wont go down. how to fix?
i have a 2003 monte carlo and the wires came out of the plug under the seat. im trying to put them back in so my seat will be able to work. there are 12 wires that make up 6 connections. i need to know what wires go together. the wires are red with blue strip, red with green strip, red with white strip, yellow with blue strip, yellow with green strip, yellow with white strip, light green, green, peach, blue, light blue, and yellow.
Jun 08, 2010 | 2003 Chevrolet Monte Carlo
I have a 1996 dodge grand caravan with 8 speakers. Im hooking up a kenwood stereo but I can only get 4 speakers to turn on. How do I get the other 4 to turn on?
here is the wire digram hope it helps
Factory in-dash wire harness (this vehicle has a 2 pc harness)
that snaps into the factory radio
Black Plug
Gray Plug
Radio Wire & Color Code Information Page 2 of 2
Typical Dodge/Chrysler Typical New Radio
Pin What It Is In Dash Wire Color Equivalent Wire Color
A Right Rear Spkr (-) Blue w/ White Stripe Purple w/ Black Stripe
B Left Rear Spkr (-) Brown w/ Yellow Stripe Green w/ Black Stripe
C Right Front Spkr (+) Purple Gray
D Left Front Spkr (+) Dark Green White
E Right Rear Spkr (+) Blue w/ Orange Stripe Purple
F Left Rear Spkr (+) Brown w/ Blue Stripe Green
G Power Antenna/Amp White (use for Infinity Radio) Blue
H +12 Volt Battery Wire Pink or Pink w/ White Stripe Yellow
I +12 Volt Ignition Wire Red w/ White Strip Red
J Radio Dimmer Wire Do Not Use
K Headlight Dimmer Wire Do Not Use
L Right Front Spkr (-) Blue w/ Red Stripe Gray w/ Black Stripe
M Left Front Spkr (-) Brown w/ Red Stripe White w/ Black Stripe
N No Wire
Metal Braid Or Plastic Connector Attached To Back Of Radio Is The Ground Wire
Feb 22, 2010 | Kenwood KDC-MP242
I am trying to hook up an ancient Kenwood KAC-801 amplifier. The original input cable has 1 red, 1 black, then another smaller awg white (1) sharing a common with another small awg yellow. Applying power...
Yes, keep in mind that the amps have a constant power (the large red wire) and need a remote signal to tell them when to turn on/off. This wire connect to a switched 12v from the ignition or radio blue wire (if aftermarket)
Nov 01, 2009 | Kenwood KAC-9102D Car Audio Amplifier
From cable box component out to tv component picture is on no aud
You need to also connect the RCA audio out (red/white) from your source to the audio input on the TV. You do not need the yellow wire as that is for composite video. The component cable (red/green/blue) is only for video. Look at the input on the TV where you connected the red/green/blue cable. Right next to it, you should have another red and white connectors for the audio input. Connect that to the audio out on the cable box.
May 01, 2009 | Digimate DGL20 Television
Sennheiser RS 110 Consumer Headphones Logo
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
Rob Beech
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
