Question about Brother MFC-7820N Printer
Why my printer won't print from my desktop but will from my wifi laptop
My printer stopped printing from my desktop. I have turned it off and back on; disconnected the cables and put them back in; stopped and started the printer spooling; and talked nicely to it......still won't work!
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 25 Answers
Since it prints from your laptop and not your desktop, it sounds like it's either printer driver or the Wi-Fi connection. Does your desktop computer see/recognize the printer? If not, then it is something to do with the wireless connection on your desktop computer. If it does recognize it, then it is likely the driver (program software) on your desktop that tells is how to communicate with your printer. In that case, you should go to "device manager" by right-clicking on your computer icon or accessing it through the control panel. There should be an option to update your driver. In this case, something with your computer (such as a OS - Operating System update) may have occurred which caused the desktop software (which tells it how to work) to stop working. I hope that makes sense. Take care and good luck!
Posted on Nov 28, 2012
Basti
  • 1447 Answers
SOURCE: printer offline
Go to control panel and printers and faxes on your laptop and when you see the printer icon for the printer, right click on it and left click on use printer ONLINE. make sure then that the laptop is communicating with the printer.
Posted on Apr 13, 2008
angelus316
  • 41 Answers
SOURCE: brother hl 2025 tn will not stop printing
You have the wrong drivers or corrupt drivers on your system.Disconnect your printer and restart.uninstall your printer and download new drivers and reinstall.all should be fine
Posted on Jun 25, 2009
xptareq2000
  • 1447 Answers
SOURCE: Just bought a new brother HL-2170W, installed the
it is problem your operating system or driver installation
Posted on Sep 07, 2009
  • 1116 Answers
SOURCE: My Brother LC61, bought in
This is common problem with Brother Printers. I am going to assume you are using Non-Brother branded ink cartridges. Brother cartridges have a cleanser in the ink that most generic cartridges don't have. This in turn causes the jets to clog and not allow ink to pass through them. The fix is to go buy a couple of Brother cartridges and do a cleaning with those cartridges. You may spend some money doing this as a cleaning wastes a lot of ink, but it will clean the injection lines and fix the printer. You could also consider buying a new printer. I know this is not the answer you were looking for, but it is the true answer. I just bought a new printer due to this fact.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Posted on Jun 11, 2011
SOURCE: I have to print a
here's a solution i came across when dealing with the same problem. apparently the printer expects all of the cartridges to be full and has a sensor to make sure they are even when only printing black. hope this helps!
http://journal.drfaulken.com/trick-your-brother-inkjet-into-working-when-an-ink-cartridge-runs-dry/
Posted on Jul 13, 2011
Testimonial: "Thank you so so so so much!"
My Canon MG6120, which worked on wifi fine for months, now doesn't. It still works with USB connection, but that's not the point of a wifi printer! How can I fix this?
First check with another device that your wifi is working if it is try resetting up wifi on your printer.
If someone changed your wifi password you will need to enter the new password.
Jan 28, 2013 | Canon PIXMA MG6120 Inkjet Multifunction...
My kodak 7250 printed from the laptop wirelessly before we moved across town. Now says disconnected
If the printer is not connecting to the wireless router, you need to address that problem first. It wasn't clear from your problem description whether or not that is the case. If the printer is getting a successful wifi connection then you may need to delete the printer from your PC and re-add it.
I’m happy to help further over the phone at https://www.6ya.com/expert/matt_7e951e081251ffbc
Jun 30, 2017 | Kodak ESP 7250 All-in-One InkJet Printer
Sipix Pocket Printer won't print.
First check to make sure that you have the correct com port selected.
then set the com port to use these settings.
11520 Bits per second
8 data bits
no parity
2 stop bits
hardware flow control
Jul 15, 2017 | SiPix Pocket Printer Thermal
Hi i have a Canon MP830 and have replaced all the ink cartridgers and they all light up but my printer wont print,fax,copy.It sounds like it is printing but the pagers come out blank.It won't even send...
Some laptops cannot run some printers or scanners. Make sure your laptop can handle running the printer from a usb port. It might help to have your laptop plugged into AC power. Also, make sure you have the most current printer drivers for your particular OS installed. If your laptop can't run your printer from its usb port, you can probably connect the printer to a desktop usb or a printer port, then print from your laptop through a home network.
Jul 26, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Printer won't print. I went to printer and it says there are 9 items to br pringted in queue but they won't print Printer says it is ready
Good Day Nanawhit!
That happens all the times when first print job encounter a problem and stops printing and it was followed by series of print jobs. Some reasons for stop printing could be a printer out of paper and printer not set as default printer.
The best way to fix it is to cancel all pending jobs. When print jobs window is cleared off pending print jobs, restart your PC and your printer. Then go to your printer and make sure it is the default printer.
After that try printing a test page. Once a test page is successful, you can now print as many as you want.
Jun 10, 2011 | Lexmark X2670 All-In-One Printer
Wifi laptop will not print to printer - not a wifi printer
Check if the printer has a wireless option. Actually this issue is complex. First thing first, you can print wirelessly from your laptop within the WIFI range in a case that your printer do have wireless on in. It is impossible to print wirelessly from the wired printer through LAN.
One thing, I guess you don't have a wireless router. You need to have a wireless router like LINKSYS that is easy to setup then try to connect wirelessly to the wired printer. There I am not too sure if your can do a printing option from your laptop wirelessly.
Lastly, check if you have a ROUTER and need to set it up on your laptop and on the network LAN. You may now have a NETWORK printer in this regards. Thank you.
Oct 06, 2009 | HP Compaq Presario V6000T Notebook
On this page
goes to my printers page right click on printer select open in print queue select print job the click on stop printing
Apr 20, 2009 | Computers & Internet
Dell 948 printer printing not finishing print jobs
Your printer loose documents:try to reset it ,unplug for an hour.
Or you might have interferences on your wireless :DECT phone, cell phone, or even an electric device who doesn't work propely, like tv, stove, speakers many things can parasites your connection...
If nothing does your printer as issues, think replacement...
cheers
Dec 19, 2008 | Dell 948 All-In-One InkJet Printer
Brother MFC-7820N Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
