Question about Ball Joint, Tie Rod, Pitman Arm Seperator Set
Replaceing upper and lower ball joints on a 07 4x4 rodeo
Trying to change my upper ball joint. Passager side
For your problem,check out this few help links.
Click the link below to go through its procedure:----Upper Ball Joints inspection and replacement? http://howtobyme.blogspot.in/2012/02/upper-ball-joints-inspection-and.html------- How to Test Upper and Lower Ball Joint? http://repairhelpcenter.blogspot.com/2011/12/how-to-test-lower-ball-joint.html------- How to inspect Upper and Lower Ball joint? http://repairhelpcenter.blogspot.com/2011/12/how-to-inspect-lower-ball-joint.html------ How to Service Ball Joints on Car? http://repairhelpcenter.blogspot.com/2011/12/how-to-service-lower-ball-joints-on-car.html----------- How to Replace Ball joints? http://repairhelpcenter.blogspot.com/2011/12/how-to-replace-lower-ball-joints.html--------- Lower Ball Joints replacing on Mitsubishi car? http://howtobyme.blogspot.in/2012/02/lower-ball-joints-replacing-on.html
-------------These details will help.For more help,keep updated,with car brand,model and year.Thanks.Helpmech.
Oct 05, 2012 | Cars & Trucks
I have a '95 Chevy Silverado 2500 7.4L 2wd, I seem to be going through ball joints rather quickly. I replace them at least once a year. Is this something that is problematic with this model or is
Many other users are noticing problem issue with ball joints.Always replace original parts instead of aftermarket parts.They dont last long.--------Before replacing ball joints ,i suggest to test and inspect the ball joints:----Click the link below for its procedure:----Upper Ball Joints inspection and replacement? http://howtobyme.blogspot.in/2012/02/upper-ball-joints-inspection-and.html How to Test Upper and Lower Ball Joint? http://repairhelpcenter.blogspot.com/2011/12/how-to-test-lower-ball-joint.html How to inspect Upper and Lower Ball joint? http://repairhelpcenter.blogspot.com/2011/12/how-to-inspect-lower-ball-joint.html How to Service Ball Joints on Car? http://repairhelpcenter.blogspot.com/2011/12/how-to-service-lower-ball-joints-on-car.html How to Replace Ball joints? http://repairhelpcenter.blogspot.com/2011/12/how-to-replace-lower-ball-joints.html Lower Ball Joints replacing on Mitsubishi car? http://howtobyme.blogspot.in/2012/02/lower-ball-joints-replacing-on.html
--------This will help.Thanks.
Feb 08, 2012 | 1995 Chevrolet Silverado 2500
How to replace ball joints on a 1998 mercedes benz s420
For ball joints issue.Before replacing it,first inspect and test the ball joints to confirm the problem:----Click the help links below to troubleshoot the problem and replace the ball joints:----Upper Ball Joints inspection and replacement? http://howtobyme.blogspot.in/2012/02/upper-ball-joints-inspection-and.html How to Test Upper and Lower Ball Joint? http://repairhelpcenter.blogspot.com/2011/12/how-to-test-lower-ball-joint.html How to inspect Upper and Lower Ball joint? http://repairhelpcenter.blogspot.com/2011/12/how-to-inspect-lower-ball-joint.html How to Service Ball Joints on Car? http://repairhelpcenter.blogspot.com/2011/12/how-to-service-lower-ball-joints-on-car.html How to Replace Ball joints? http://repairhelpcenter.blogspot.com/2011/12/how-to-replace-lower-ball-joints.html Lower Ball Joints replacing? http://howtobyme.blogspot.in/2012/02/lower-ball-joints-replacing-on.html----------This will help.Thanks.
Jan 31, 2012 | 1991 Mercedes-Benz 420
Clunking?
Retest the fitting and inspect the ball joints again to confirm its not the issue.For that click the help links shown below :----Upper Ball Joints inspection and replacement? http://howtobyme.blogspot.in/2012/02/upper-ball-joints-inspection-and.html How to Test Upper and Lower Ball Joint? http://repairhelpcenter.blogspot.com/2011/12/how-to-test-lower-ball-joint.html How to inspect Upper and Lower Ball joint? http://repairhelpcenter.blogspot.com/2011/12/how-to-inspect-lower-ball-joint.html How to Service Ball Joints on Car? http://repairhelpcenter.blogspot.com/2011/12/how-to-service-lower-ball-joints-on-car.html How to Replace Ball joints? http://repairhelpcenter.blogspot.com/2011/12/how-to-replace-lower-ball-joints.html Lower Ball Joints replacing on car? http://howtobyme.blogspot.in/2012/02/lower-ball-joints-replacing-on.html
Jan 23, 2012 | 2000 GMC Yukon Denali
Have had to replace ball joints 3 times on my 97 lumina, any ideas why
Always use original parts instead of aftermarket products.Original parts cost bit extra,but they are exact fit and last longer.Click this link below to troubleshoot the issue :----Upper Ball Joints inspection and replacement? http://howtobyme.blogspot.in/2012/02/upper-ball-joints-inspection-and.html How to Test Upper and Lower Ball Joint? http://repairhelpcenter.blogspot.com/2011/12/how-to-test-lower-ball-joint.html How to inspect Upper and Lower Ball joint? http://repairhelpcenter.blogspot.com/2011/12/how-to-inspect-lower-ball-joint.html How to Service Ball Joints on Car? http://repairhelpcenter.blogspot.com/2011/12/how-to-service-lower-ball-joints-on-car.html How to Replace Ball joints? http://repairhelpcenter.blogspot.com/2011/12/how-to-replace-lower-ball-joints.html Lower Ball Joints replacing on car? http://howtobyme.blogspot.in/2012/02/lower-ball-joints-replacing-on.html
Jan 17, 2012 | 1997 Chevrolet Lumina
How do you put in a ball joint in a 2001 sebring convertible
It depends on exactly which ball joint of the 3 per side your changing, but here are the details.
COMPRESSION LOWER ARM & LATERAL LOWER ARM ASSEMBLIES
Removal
1. Loosen compression lower arm ball joint nut. Using steering linkage puller, separate ball joint and
knuckle. Remove nut, bolts and compression lower arm assembly. Remove dust cover.
2. Remove stay. Remove shock absorber lower mounting bolt. Loosen lateral lower arm ball
joint and knuckle nut. Using steering linkage puller, separate ball joint and knuckle. Remove nut, bolt and
lateral lower arm assembly. Remove dust cover.
Inspection
Using preload socket, ensure breakaway torque for compression lower arm ball joint is 4-22 INCH lbs. (0.5-2.5
N.m) for 2000 models. On 2001 models, breakaway torque is 22-54 INCH lbs. (2.5-6.1 N.m). Ensure
breakaway torque for compression lateral lower arm ball joint is 13 INCH lbs. (1.5 N.m). Check compression
lower arm, lateral lower arm, dust covers, and bushings for damage and wear.
Installation
To install, reverse removal procedure. Use NEW ball joint nuts. Lubricate lip and inside of dust cover with
multipurpose lubricant. Using installer, install dust cover. Check front wheel alignment.
UPPER ARM ASSEMBLY
Removal
Using steering linkage puller, loosen upper arm ball joint and knuckle nut. Remove self-locking nut. Remove upper arm and upper arm shaft assembly. Remove dust cover.
Inspection
Using preload socket, ensure breakaway torque for upper arm ball joint is 3-13 INCH lbs. (0.3-1.5 N.m).
Replace upper arm assembly when measured value exceeds specification. Check upper arm, dust cover, and
Installation
1. To install, reverse removal procedure. Use NEW self-locking nuts. Lubricate lip and inside of dust cover
with multipurpose lubricant. Using Ball Joint Installer (MB990800), install dust cover.
2. Ensure upper arm shaft assembly is installed at indicated angle. Verify upper arm shaft
assembly installation. Check front wheel alignment.
Once you have the correct arm off and a replacement joint (if available, some are not serviceable and require the arm to be replaced) then you will need a press or a ball joint press to change the joint. Such as
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=38335
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=46389
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=66958
or http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=46967
Mar 17, 2010 | 2002 Chrysler Sebring
What is the estimated cost to replace the ball joints on a 2001 Land Rover Discovery SE (91k mi.)?
HI. Ok, This vehicle is equipped with an upper and lower set of ball joints. The prices are as follows:
Parts price will be $40.00 for the upper set
The labor is set to $195.00 for the upper replacement procedure.
Parts price for the lower ball set will be $40.00.
The labor price for the lower replacement procedure will be $165.00
NOTE_ Land Rover recommends to replace the upper and lower, in this situation. Total cost, if you chose to replace the upper and lower ball sets, will be $80.00 for the parts, and $360.00 on the labor.
Jan 14, 2010 | Land Rover Discovery Cars & Trucks
How do i change upper and lower ball joints on a 2002 explorer sport
the lower ball joints have to be pressed into the lower control arms.The upper ball joints are part of the upper control arm so the upper control arms have to be replaced
Jun 24, 2009 | 2002 Ford Explorer Sport
Are 1994 s10 upper and lower ball joints pressed in
the upper ball joints are rivited or bolted if yhey have been replaced before
the lower ball joints on a 2WD are pressed in
the lower ball joints on a 4X4 are rivited or bolted
Jun 04, 2009 | 1994 Chevrolet S-10 Blazer
Ball Joint, Tie Rod, Pitman Arm Seperator Set Logo
23 people viewed this question
Top Lisle Vehicle Parts & Accessories Experts
Kar Volk
Rigger
charles
Are you a Lisle Vehicle Part and Accessory Expert? Answer questions, earn points and help others
