Question about Frigidaire 30" Self-Cleaning Freestanding Gas Range - Easy Care Stainless-Steel
How to remove bottom drawer on stove
Model Fgf337gcf
My stove drawer is stuck and it won't close or come out , what to do ?
drawer is stuck Anon, Pick up on drawer as far back as possible with some force,shake it up and down, this should allow you to lift drawer from track/slides. Clean and lubricate all wheels, bearings and track/slides and reinstall drawer.
HELP bottom oven drawer stuck on new GE range
How to Open an Oven Drawer That Is Stuck eHow
How to Unstick Oven Drawer
Stove Drawer Stuck or Jams DIY fix
Apr 02, 2016 | Kitchen Ranges
The inside oven is not heating. The top burners are working fine.
If this is an electric oven, most likely the oven bake element has burnt out.
the model and serial number should be behind the bottom drawer,
most elements are held in with (2) 1/4 inch socket hex head screws.
Remember to unplug stove or shut off breaker before servicing.
The element can be slid out usually, then unplugged or remove
the back cover behind stove and unplug it from the wiring harness.
I hope this is useful
Aug 02, 2011 | Tappan Ovens
We turned on our oven last night and it heated up to 345, wanted to get to 400, then my wife saw smoke form the right hand front of the inside of the oven. I wanted to check the element, but can't figure...
I am assuming you are referring to a conventional stove. First shut off power to the stove at the breaker panel. (either a 40 or 50 amp breaker). Check to see if the elements come on before proceeding.
Slide out stove and unplug it. Look on the back. There will be a vertical piece of sheet metal with 1 to 3 screws or a large flat panel with several screws (1/4 Inch socket). Remove this panel to reveal the leads to the bake element.
remove the leads. Then remove the two screws inside the stove (1/4 inch socket) to remove element. The model and serial for the stove should be located by sliding the drawer out at the bottom of the stove on the left side.
You will need this number for the correct element. They run about 20 dollars typically. Hope this helps.
Feb 17, 2011 | Microwave Ovens
Pilot light is out need to relight it but do not know where it is located
The pilot is located in the bottom of the stove, you will have to remove the bottom drawer, and you will see the pilot in the back, you can relight it there, if there is no bottom drawer you will have to remove the bottom cover inside the oven and this is the location where you can relight the pilot.
Jan 07, 2010 | Hotpoint RGB745 Gas Kitchen Range
If i turn on the oven the pilot burns but no gas
This is a bad gas valve. You will need your model number off this unit to order the correct part. If you will look around the front frame of the oven, there is a serial plate with model number on it. If it has a bottom drawer, it may be on the front frame when you open the drawer. Give us a call with your model number and we'll get the right part out to you asap. 972-859-0929 - We look forward to working with you! Hope this helps!
Oct 03, 2009 | Ovens
Levers on side of stove
They are for removing the drawer from the cabinet.
Charlie
Aug 24, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Whirlpool electrice stove storage drawer
There is a screw in the bottom of the two back corners that holds the drawer glide in place. Remove the glide and then you'll be able put it back the way it belongs.
Nov 22, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Can you give me easy install directions?
are yours and hers both freestanding? (do they both have a drawer at the bottom?) if so measure the width to see if hers will fit. if so, turn off the circuit breaker to your stove. remove the drawer of your stove. do you see the plug? unplug it. now just slide it out toward you being careful not to damage the floor. installation opposite of removal.
Hope this helps
Oct 31, 2007 | Frigidaire FGF337EC Stainless Steel Gas...
Open Questions:
See all Frigidaire 30" Self-Cleaning Freestanding Gas Questions
Frigidaire 30" Self-Cleaning Freestanding Gas Range - Easy Care Stainless-Steel Logo
130 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
