Question about Canon CanoScan LiDE 600F Flatbed Scanner
Canon CanoScan LiDE 600F twain driver windows 7 64 bit
Unable to open twain source
  • Derek Nov 29, 2012
    It didn't like the USB connection to a hub, although it's been running there ok for 6 months. I re-plugged the device to a dedicated USB port and it re-installed ok. I already defined the Path (see Jeff Widmer's blog) 6 months ago. Seems ok now - Derek
SOURCE: Error message
Hi toolpusher
Try going to CanoScan Toolbox > Settings and reset the 'defaults' button at bottom... this will restore factory settings and hopefully fix your problem... The other error message you can expect to get is "unable to scan - insufficent memory, check your **** space' (or something similar)... same fix works for both! ...Have had both messages on mine, sounds like a semi-regular conflict on some sort, but seems to be easily fixed. Good luck :-)
Posted on Sep 30, 2008
  • 13433 Answers
SOURCE: Unable to set TWAIN capabilities. When I try to
Unfortunately solving the problem might come down to reinstalling windows to the computer entirely. I think it would be best for you to keep using the program where it works.
I'dd suggest that you back up all your files etc, to a external hard drive, and then use the recovery disc that came with your computer to reinstall it to the state it used to be when purchased. or use a windows installation cd.
Then install the scanner back and it should work fine.
Posted on Dec 07, 2010
  • 111 Answers
SOURCE: Cannot TWAIN CanoScan LiDE 500F
What errors do you recieve? Where are you scanning from...what application?
Posted on May 09, 2008
  • 5 Answers
SOURCE: TWAIN ERROR AND CANOSCAN LIDE 20 SCANNER PROBLEMS
Well I had a code 15 error with mine LIDE 20. Apparently the scanner needs a certain amount of power to run off the USB port. So I changed the USB port and problem fixed
Posted on Jul 16, 2008
Select your operating system and download the driver "TWAIN Driver - LiDE 20 Scanner Driver Ver. 7.0.3.1a_xp" and then download the software "Canoscan toolbox" ...here is the link:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=6624
Posted on Jul 04, 2009
Unable open twain source please
This is an issue with the Driver Installation, Get the drivers Uninstall and reinstalled from the CD.
May 11, 2013 | Canon CanoScan LiDE 25 Flatbed Scanner
When i try to scan i get this message: unable to open TWAIN source Please check connection then re-start Toolbox the connections are tight
Driver mismatch - the driver of the scanner has forgotten the location of the TWAIN driver because another software has been using it lately. Follow this
http://weblogs.asp.net/jeffwids/archive/2009/11/02/canon-scanner-unable-to-open-twain-source.aspx
Feb 20, 2011 | Canon CanoScan LiDE 30 Flatbed Scanner
Needs canoscan drivers
Drivers are specific to the operating system (ie drivers for Windows XP may or may not work with Vista). Click on the link below and you will be navigated to the Canon driver download page. Choose your operating system (OS) from the drop-down menu, your preferred language and you will be ready to download the drivers.
CanoScan LiDE 600F
Oct 05, 2009 | Canon CanoScan LiDE 600F Flatbed Scanner
Canoscan does not work on vista 64-bit
I'm not sure if this will work on the lide 20. I have an lide 35, and there are no 64 bit drivers for it. I downloaded and installed the drivers for the lide 60, told the computer to manually find the lide 60 drivers for my scanner, and installed the canoscan toolbox for vista 64 bit. Works like a champ.
Nov 07, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Aug 04, 2008 | Canon CanoScan LiDE 30 Flatbed Scanner
Your post for CanoScan LiDE 25
Hi there, yes I did everything per your instructions, Toolbox is installed and it still says, "release the lock switch, detach I/F cable and reconnect. Scanner driver will be closed" and then after clicking on that it says "Unable to open TWAIN source. Please check connection then restart toolbox" I have been to the Canon site and downloaded driver sites and it says everything is working. but when I go to scan it comes up with the boxes I said before. Quite lost at the moment? Thanks Maureen. PS I have unstalled and reinstalled
May 22, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Canon scanner
TWAIN is the type of scanner driver that is used for this scanner. It is probably the most common type of scanning driver.
Did you install Toolbox? Not sure? Assuming this is Windows, click Start, All Programs, Canon. Look for open CanoScan Toolbox (4.9 I think). Once this is open, click the 'Settings' button. There should be a drop-down menu for 'Select Scanner'. Make sure this shows the CanoScan LiDE 25. If that scanner is not listed, then the scanner driver is not being seen or may not be installed.
Once it has been verified that the LiDE 25 is selected, click OK. Next, click the 'Save' button. Check the box for 'Display the Scanner Driver'. Now click the 'Scan' button at the bottom.
The next window that pops up should be ScanGear. If this happens, then everything is installed and the scanner is being detected properly. Attempt to scan or preview.
If there was a particular application you were trying to use and you are still having issues with it, please give those details.
May 19, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Canon CanoScan  LiDE 600F Flatbed Scanner Logo
581 people viewed this question
old marine
old marine
