Question about IBM 8224 Ethernet Stackable Hub 73g9764 8224-002 16 Port
How to set up network using IBM 8224 002 Hub
I have a network connection. Where do i plug in the net in cable?
ERROR CODE EA21F7
LOTS TO CHECK
Check if the LAN cable has been correctly connected, if the SMTP server is ready for communication, if the network settings
such as sub-net mask setting are correct, or if the E-mail address of the destination is correct.
LAN cable has not been connected, or failed to communicate with
the SMTP server. You tried to transmit the document to an incorrect destination address.
A LAN cable is not connected. Check that the LAN cable is connected correctly. The network of the network multifunction
machine and the PC with the IP address of the destination mismatch.Confirm whether the network settings of the PC and the network settings of the network multi-function machine pose a
network-type problem.The network settings in the PC have
not been set correctly.Check the TCP/IP settings of the PC.
The network board of the PC with the IP address of the destination has failed. Replace the network board or the PC. Power is not being supplied to the HUB. Supply power to the HUB. A cross-type network cable is not being used for Peer-to-Peer connection.
Use a cross-type cable. The network cable is disconnected. Replace the network cable. Network load in the destination PC is
too high. Check whether a mail with large size data is received in the destination PC, or a large file is downloaded from the Web.
There is too much transmission data. If the scan resolution is set high, scan fewer pages. The access is limited by the firewall
(Windows Firewall) of the network connection in the PC.
Consult with the network administrator, and change the firewall (Windows Firewall) settings of the network connection.
Dec 10, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
Which port to place network in put
If it is a hub then you can plug any device into any port. It doesn't matter which. All a hub does is broadcast data received on anymore out all the other ports at half duplex speeds. I'd recommend getting a switch instead. Same price and they don't suffer from all weaknesses a hub has.
Nov 28, 2012 | IBM 8224 Ethernet Stackable Hub 73g9764...
Got a hub genius GH4080SE and trying to connect computers, pls advise what is the steps?
Hardware Setup
1 Find the WAN or uplink port of the Ethernet hub. Typically, it is located on the rear of the unit, and it is often separate from the LAN ports.
2 Connect an Ethernet cable from the WAN port of the hub to either the Ethernet port of the internet modem or, if expanding a network, to an empty LAN port on the existing network’s router, switch or hub.
3 Plug an Ethernet cable into one of the LAN ports on the Ethernet hub and connect the other end of cable to the computer or device that will be added to the network. Repeat for any other devices that will need to be on the network.
4 Power up the Ethernet hub and the computers or other devices attached to it. On the front of the hub will be a series of LEDs that correspond to each LAN and WAN port on the hub. Every port that has a cable plugged into it should have one or more of the LEDs lit that represent that port. If not, check the connections and swap out the Ethernet cable if necessary.
Software Setup
1 Configure the network settings on each connected computer. If you are expanding a network and the network uses DCHP, or dynamic IP addressing, no configuration will be necessary. On networks using static IP addressing or on a new network setup using the Ethernet hub, each computer or device must be assigned a unique IP address. Local IP addresses must use the allowed “private” address pools that will not interfere with internet addresses. Acceptable addresses include 192.168.x.x, 172.16.x.x to 172.31.x.x, or 10.x.x.x. The “x” represents a number that is chosen by the user, from 0 to 254. All computers on the network should share the first three numbers in the address, with the final number representing the individual computer. In a network with three computers, for example, the first could be 192.168.1.1, the second could be 192.168.1.2 and the third could be 192.168.1.3, though the final number does not need to be sequential.
2 Click the “Start” button in Windows, select “Control Panel" and double-click the icon labeled “Network Connections.”
3 Right-click the icon for the Ethernet adapter and select “Properties.” Click on the check box marked “Internet Protocol (TCP/IP)” and press the “Properties” button.
4 Select the radio button labeled “Use the following IP address.” Enter a unique IP address for the computer and the applicable subnet mask. If a router is used on the network, enter the router’s IP address as the default gateway. Press the “OK” button and reboot if necessary.
5 Enable file and printer sharing from the “Properties” dialog for the Ethernet card if files will be transferred between the networked computers.
6 Click the “Start” button, select “Control Panel” and double-click on the “System” icon. Select the “Computer Name” tab and click on the button labeled “Change” to set the computer’s network name. In the “Computer Name” box, enter a unique name for the computer. In the “Member of” section, choose the radio button marked “Workgroup” and enter the workgroup of the network. If setting up a new network, this name can be change but all computers on the network must share the same workgroup name.
7 Verify that all computers can access the network and the Internet if connected.
Read more: How to Set up an Ethernet Hub | eHow.com http://www.ehow.com/how_4530475_set-up-ethernet-hub.html#ixzz0xnIzsGqa
see also Networking Diagram
Aug 27, 2010 | Genius GH 4080 SE 8-Port Ethernet Hub...
There is no connection to the other pc
3 ethernet cables 1 ADSL modem and 1 hub is needed to network computers together.
1. connect telephone cable to modem and switch it on. 2. one end of an ethernet cable is connected to the modem . consider this master ethernet cable. connect the other end of this to the master hub port. 3.now connect pc and any hub port with another ethernet cable(ec) say ec1 4. likewise ec2 to another pc .
try this out to get net in both pc's
Jan 12, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
Can i connect my xbox to my laptop /w pc usb
Xbox Network Connection using Hub
This is the most common network configuration and is also the easiest to setup.
Step #1: Plug your network cable(RJ-45 cable) that comes from your cable/DSL modem into the uplink port of your hub. (Make sure that your uplink is switched to "on").
Step #2: Take an RJ-45 cable and run it from one of the ports of the hub, directly to the Network Interface Card (NIC) installed in your computer.
Step #3: Take another RJ-45 cable and run it from a different port of your hub directly to your xbox.
**NOTE** A switch may be used in place of a hub with the same basic setup.**
That's it! No other network changes should be needed for this configuration. Your Xbox is now on the same network as your PC.
Xbox Network Connection using Router
This is another common network configuration.
Step #1: Plug your network cable(RJ-45 cable) that comes from your modem into the WAN port of your router.
Step #2: Take an RJ-45 cable and run it from one of the ports of the router, directly to the Network Interface Card (NIC) installed in your computer.
Step #3: Take another RJ-45 cable and run it from a different port of your router directly to your xbox.
**NOTE** In steps #2 and #3, you should not use a port that is directly beside the "uplink" port on your router, if your uplink port is being used to connect to another routing device.** If your router has a built in firewall, you will need to forward ports 8602 both incoming and outgoing to the internal ip address of your pc. Consult your device manaul for port forwarding.
That's it! Your Xbox is now on the same network as your PC
Xbox Network Connection using Crossover Cable
This is the last network configuration. For this setup you need at least one NIC card.
Step #1: Plug your USB cable that comes from your modem into your PC's USB port. This should already be done, if you have a usb modem for your current internet connection.
Step #2: Take an RJ-45 cable and run it from an installed NIC card on your PC, directly to the Xbox.
**NOTE** A crossover cable is only needed if you are connecting the Xbox directly to the second NIC card. If you have a device such as a switch, hub or router in between you should use a standard RJ-45 cable. This type of network setup also requires "Winroute©", a program downloadable from the world wide web. Consult the manual for specific instructions on how to set this up. Also if you have a USB ethernet adapter, you may use any of the setups described herein. USB ethernet adapter basically converts a USB cable into an RJ-45 cable.
That's it! Your Xbox is now on the same network as your PC.
Aug 14, 2009 | Video Game Consoles & Games
Lan cable Setting for Switch & PC to PC LAN Connection.
If you are asking about connecting two computers together with a hub or switch, plug them into the switch/hub with standard patch cables (cat 5e or cat 6).
If you are asking about connecting two computers together directly using a LAN cable, then you will need a "Crossover" cable (cat 5e) wired specially (oranges transposed at one end for the common -B pattern) for direct LAN connection.
Jan 01, 2009 | Computers & Internet
2 ethernet cards can't work together
If in your network you are connecting computers directly to a PC thru multiple nics and not a router or hub leaving one as server and the others as clients and that server is NT 4,0
NT 4,0 can not auto configure the cat5 cable and would need at least 1 cable to be a cross-over and not a patch.
Apr 01, 2008 | IBM NetVista A40 PC Desktop
Connecting campus wide networking to hub
Check the following:
Hardware First: Is Vista confirming LAN connection onn that PC, or is it showing disconnected cable?
Is the connection properties showing at least 100Mbps?
Are the RJ45 terminals okay?
Is the driver for the network card recognized by Vista and loaded?
If that is fine, then check the following in the network properties:
1. The IP address you are using
2. The gateway address: it must be the same as the gateway address in the other PCs accessing internet. Run and check
3. The Subnet mask. Use 255.255.255.0
4. HAve you Setup the Nework using the Setup Wizard, including Access INTERNET THROUGH A HUB THROUGH ANOTHER COMPUTER ON MY NETWORK?
Check those things and let us know. Ask for help from your network administrator about correct IP addresses on that LAN
Feb 26, 2008 | Compex MicroHub TP1008C Networking Hub
Network boot
If you just need file s from the other machine booting from network won't help you - that's just so you can reload the OS over the network.
You should just need to plug the ethernet cable into both machines (make sure you use "crossover" cables to connect them directly or use a router or hub if not connected directly.
-Then just go to the properties for "my computer" and click the Computer Name tab. Write the computer name down. TO access the other computer, go to Start/Run and type:
\\COMPUTERNAME
(not case sensitive)
Make sure you right click on the folder you want to share with the other machine and select "sharing and security" to open it up to the other machine.
Alternatively an external hard drive is a quick way to move a lot of files to another machine.
Dec 09, 2007 | IBM ThinkPad R50e Notebook
IBM 8224 Ethernet Stackable Hub 73g9764 8224-002 16 Port Logo
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
