Question about Lemax Village Collection Carnival Village The Starburst With 9v Adaptor
I have a Lemax Starburst Ferris Wheel, purchases only a few weeks ago. It has starting making grinding noises, as if it needs lubrication. Is it possible to take it apart to do that?
2 Suggested Answers
SOURCE: can curved tracks be purchased separately for Lemax village expre
Yes, I have even seen them on ebay from time to time.
Posted on Jan 03, 2009
Cub cadet rzt 50 making grinding noise when starting after it starts still making noise sounds like coming from fly wheel. any suggestions thanks
The shaft that the solenoid pushes the gear up needs lubrication. If it's been grinding too long, the bearing in the starter is worn letting the armature to rub on the field frame. Might be time for a starter motor.
Oct 02, 2016 | Cub Cadet Garden
Grinding noise when starting '98 Izuzu Rodeo
Upload video please then i might have a better idea
Jul 15, 2013 | Cars & Trucks
Loud grinding noise front end while driving. Hub bearing? Started a few weeks ago but not so extreme and usual only when turning. Now it is a loud metal grinding sound almost constant and seems to get...
Probably so. When making a left hand turn, if the noise gets loader, it is the right side bearing. IE... putting more wieght on that side of the car.
Jun 01, 2013 | 2003 Chevrolet Avalanche
2002 Chevy Cavalier makes Grinding / Vibration noise when steering wheel turns right. Noise goes away when wheel turned to the left. Both Wheel bearings hub assys. Changed 4 mths ago. Noise started 3 mths...
may be you should make a diagnostic and you can do it in a garage or you can do it by yourself if you want to do it by yourself you need some tools and you can find some good ones here: spobd2.com
Feb 02, 2013 | Cars & Trucks
2000 olds alero cranks then makes a metal grinding sound and won't start
You need to have your flywheel: replaced.Your starter motor engages against the fly wheel at the back of the motor. Every time your motor stops it tends to be in the same few positions (just the way things work) so there is more stress on some parts of your fly wheel than others. Because of this the teeth wear out on the fly wheel which means the starter can correctly engage on the fly wheel which is the grinding noise.
Jan 18, 2013 | 2000 Oldsmobile Alero
I have Samsung DLP TV 50 inch HL-P5063W
First thing to look at is the color wheel this model uses--usually it will make a high pitched fan like sound but can make a grinding sound also.
If it slows down from the 12,000 or so RPM speed it will cause color issues.
HAVE GRINDING OR HIGH PITCHED SOUND?
Apr 02, 2012 | Samsung Televison & Video
Wont start locks wont work had transmission cooler/line replaced
check wiring and connectors at battery and fuses look at starter and see and feel if its loose or not sitting right if it is notify shop dealership where work was done possible did not install starter correctly when work on transmission was done grinding, starter not meshing correctly with fly wheel
Nov 25, 2009 | 1998 Chevrolet Cavalier
Squealing Noise from Amana ALG331RAW
these dryers have wheel like drum supports and the bronze bearing inside them will wear out causing noise. once you get the drum out, look at the belt idler pulley also it too has a bearing and either one can cause the noise.
if you can get inside the unit, and the bearings dont look worn/wobbly, then you may be able to just lubricate them and it should work for another year or two. if you can get new rollers and idler that would be best and should only cost about 15-20 bucks each.
Dec 29, 2008 | Amana ALG331RAW Gas Dryer
Front wheel noise
sounds like you need a front wheel bearing...does it change pitch in noise when turning left or right?
Dec 03, 2008 | 2000 Volkswagen Beetle
Lemax Village Collection Carnival Village The Starburst With 9v Adaptor Logo
332 people viewed this question
Top Lemax Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Lemax Toy Expert? Answer questions, earn points and help others
