Basically described it in the video. FM option is gone and nothing on the menu gives me the option to turn it back on.
    Filmmaker:
    Uploaded 5 video answers.
    New Friend:
  • 24 Answers
Disconnect the battery terminals to reset it, and if that doesn\'t work, it\'s defective, and its unlikely there\'s anything you can do
Posted on Nov 29, 2012
How do I change language on pioneer deh4600bt
Section
02
Using this unit
(iPod control)
c
This unit's iPod function is operated from your
iPod.
d
(Bluetooth indicator)
Set up menu
After installation of this unit, turn the
ignition switch to ON.
SET UP appears.
Turn M.C. to switch to YES.
# If you do not use the unit for 30 seconds, the
set up menu will not be displayed.
# If you prefer not to set up at this time, turn
M.C. to switch to NO.
Press M.C. to select.
Follow these steps to set the menu.
To proceed to the next menu option, you need
to confirm your selection.
LANGUAGE (multi-language)
This unit can display the text information from a com-
pressed audio file even for information embedded in
English, Russian or Turkish.
! If the embedded language and the selected lan-
guage setting are not the same, text information
may not display properly.
! Some characters may not be displayed properly.
1 Turn M.C. to select the desired setting.
ENG (English)-??? (Russian)-TUR (Turkish)
2 Press M.C. to confirm the selection.
CLOCK SET (setting the clock)
1 Turn M.C. to adjust hour.
2 Press M.C. to select minute.
3 Turn M.C. to adjust minute.
4 Press M.C. to confirm the selection.
En
FM STEP (FM tuning step)
Use FM STEP to set FM tuning step options (seek
step settings).
1 Turn M.C. to select the FM tuning step.
100 (100 kHz)-50 (50 kHz)
QUIT appears.
! The manual tuning step is fixed at 50 kHz.
! When AF and TA are turned off, the seek step is
fixed at 50 kHz even if set to 100.
5
To finish your settings, turn M.C. to se-
lect YES.
# If you prefer to change your setting again, turn
6
Notes
! You can set up the menu options from the sys-
tem menu and initial menu. For details about
the settings, refer to System menu on page 19
and Initial menu on page 23.
! You can cancel set up menu by pressing SRC/
OFF.
Basic operations
Important
! Handle the front panel with care when remov-
ing or attaching it.
! Avoid subjecting the front panel to excessive
shock.
! Keep the front panel out of direct sunlight and
high temperatures.
! To avoid damaging the device or vehicle inter-
ior, remove any cables and devices attached
to the front panel before detaching i
Feb 08, 2015 | Pioneer Deh-5400bt Car Stereo...
Tip
SERVICE MODE TO BEKO 23WL46G 30WL46G
Service Menu StructureThe service menu has three items: display, calibre and version 2.1 Display Display item has seven options:
a- Panel
Panel option gives information about the current panel resolution. It is a read only option and can not be set.
b- Power on time
Power on time gives information about the last update time of the SW running. It is a read only option and can not be set.
c- Backlight on time
Backlight on time option reserved.
d- Scart prescale
Scart prescale option sets the prescale values for the input sounds entering the scart input of the MSP(Micronas Sound Processor). Changing this value you can adjust the level of the output sound going to loudspeakers for all the sources except the Tuners. The range is between 0 and 100.
e- nicam prescale
Nicam prescale option sets the prescale values for the Nicam standard sounds for tuner inputs. Changing this value you can adjust the level of the output sound going to loudspeakers for Nicam sounds entering the analog sound input of MSP. The range is between 0 and 100.
f- fm/am prescale
fm/am prescale option sets the prescale values for the FM/AM standard sounds for tuner inputs. Changing this value you can adjust the level of the output sound going to loudspeakers for FM/AM sounds entering the analog sound input of MSP.
g- Agc(Automatic Gain Control) adjust
Agc adjust option sets the input voltage going to IF decoder AGC pin. Changing this value you can adjust this voltage for optimum Tuner performance. The range is between 0 and 31.
h- R/G/B Brightness/Contrast:
These are used for color bias adjustment. The range is Between 0 and 255
Calibrate
Calibrate item has nine options:
a- video format
Video format option force the video format to the desired format. Selectable formats are Auto, Pal, NTSC and SECAM.
FOR MORE CHECK THE LINK BELLOW
Electronics Equipment Repair Center
Ajin Gopakumar Google
on Feb 16, 2015 | Beko 17WLB450S 17 in. LCD TV
My vizio 60' flat screen tv audio captioning for the blind will not turn off? A voice comes on during all prime time shows describing visual actions for the blind...help?
Go to your Menu options, and look around for a RESET option. You want to basically do a factory reset on your TV. (I'm assuming you turned off the setting, the system confirmed it, but it never turned off?)
Jan 31, 2013 | Televison & Video
IBOUGHT MY PHILIPS SAA7130 TV TURNER/FM RADIO THE MANUAL STATES THAT I MUST INSERT THE CD KEY FOR THE FIRST TIME WHEN ISTALING BUT I DIDNOT SEE THE OPTION WHEN INSTALLED MY CARD AND IT SAYS FM RADIO...
BOUGHT MY PHILIPS SAA7130 TV TURNER/FM RADIO THE MANUAL STATES THAT I MUST INSERT THE CD KEY FOR THE FIRST TIME WHEN ISTALING BUT I DIDNOT SEE THE OPTION WHEN INSTALLED MY CARD AND IT SAYS FM RADIO OPTIONAL BUT NOTHING IS PLAYING FROM RADIO
Mar 04, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
I have a 4 gb Sansa Clip. How do I switch back
You can go to the main menu on your player and select which one you want to use at a time. Here is a manual that describes everything you need: http://www.sandisk.com/media/175960/clip_um_0608_eng.pdf
Page 6-7 has the menu options/controls that you can use to do that.
Oct 31, 2009 | SanDisk Sansa Clip MP3 Player
Nothing works plese help !!!!
try the menu button , holding the fm/am button basically it is waiting for you to hit the security code correctly
Apr 10, 2009 | Kenwood KDC-519 CD Player
Match frequencies XM to Tuner
You should be able to go to the menu on your unit as long as there is not a plug in the audio out socket, and it should give you the FM Frequency option. If you remove the plug from the audio out, you will want to power the unit off and back on to get the FM option to appear when you push the menu button.
Nov 03, 2008 | Delphi Roady2 SA10085 XM Radio Receiver...
Formatting
If for some reason the Format option is gone, then perhaps some of the firmware or settings have been drastically changed or worst, corrupted.
A couple of things you can try:
a. do a soft reset - press on the Power/Menu for 15 seconds;
b. do a full settings reset - Main Menu/Settings/Reset All;
c. do a Format - Main Menu/Settings/Format but all in the internal memory will be erased;
If the above will not work, you can also try:
1. download and run in your PC Sansa Connect Recovery Tool
2. read the How to use the Sansa Connect Recovery Tool and follow the instructions carefully;
3. doing #1 will erase the corrupted files, unfortunately so with everything else. It will then restore the device software to an uncorrupted state.
Hope this be of help/ Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 07, 2008 | SanDisk Sansa e250 MP3 Player
No FM Frequency option
I had the same problem with all three of my Roady XTs. I posted a video with directions for solving the problem on YouTube:
http://www.youtube.com/watch?v=BGMWf0aUTjw
Basically, you just need to have the antenna unplugged when you power up, and push menu right away, then select. Not sure why, but it worked on all of my Roady XTs. On the oldest one I had to push menu more than once. Good luck!
Sep 24, 2007 | Delphi Roady XT XM Radio Receiver
Roady XT Transmitter problem
Mine is doing the same as well. Been working for 1 year. Now it starts cutting out while listening. I noticed if it is broadcasting the fm frequency menu is there. The minute it cuts out I press Menu and that menu item is gone. It comes back once the radio starts working again. Mine is 1 year old. I got it Christmas of 2006. I do know that if you have it directly connected then this menu item will not appear and that is by design. I think my xm roady xt has gone bad.
Jul 02, 2007 | Delphi Roady XT XM Radio Receiver
19 people viewed this question
 Grubhead
Grubhead
