Question about HP Officejet 5610 All-In-One InkJet Printer
Printed page is good at top but fades as it prints down the page
I have an HP5610 officejet all-in-oen Recently installed new cartridges and has been working fine But just started printing pages strong at top but fades as prints down the page
  • Patricia P Feb 03, 2009
    I have the same problem with my HP Officejet 6300 All-In-One. Sometimes the entire page will be very faded. I have put in new cartridge, cleaned contacts, run test pages all to no avail. Help!
    President:
  • 2,692 Answers
How do I change the ink in hp officejet 5510
Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access doorc00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridgec00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tapec00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridgec00034769.jpg
  5. Close the print-carriage access door.
Back to top Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
  1. When the message displays, press OK . The HP Officejet will print an alignment page.
  2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
Feb 08, 2011 | HP Officejet 5510 All-In-One Thermal...
I have HP Officejet 6310 All-in-One I replaced black ink cartridge No 98 just recently, and since then I have problems to print anything. When I try to print I get this message on printer?s...
hello, some of the time the color ink cartridge can cause the problem, especially if its a refilled ink, but at same time, i do know some of the new inks right out of the box will fail. so try with a new color cartridge first.
Sep 30, 2010 | HP Officejet 6310 All-In-One InkJet...
My hp5610 all in one won't align. printed perfect page. now streaky..won't recognize alignment page...help
one of your cartridge has no ink
check here how you can refill it your self
utube.png You-Tube video "sOriLrbuBao" placeholder (do not delete) utube.png
utube.png You-Tube video "II9gpIXs_lE&feature=related" placeholder (do not delete) utube.png
Apr 14, 2010 | HP Officejet 5610 All-In-One InkJet...
Prints completely black page when copying.
hello! are you usinga brother oen toner and drum cartrdige? that is the first thing to try, you are welcome to post back to me for additional help good luck brother tech
Jan 22, 2009 | Brother IntelliFax-2820 Laser Fax
HP 5610 - printing fades down the page
the printer carriage might be wearing out, it happens on the 5610's, may be time for a new printer. The fading issue sounds like a cartridge issue. Try a oem?
Nov 14, 2008 | HP Officejet 5610 All-In-One InkJet...
Toner not refreshing
I replaced the toner, but it still says toner life ended open front cover and repalce with new one. How do I resolve this
Oct 24, 2008 | Brother MFC-7820N Laser Printer
Magicolor 2400W print fades on right side of page
Have you tried cleaning the leans at the bottom of the printer? Open the cover, pull out the drum. Under it is a long, narrow piece of glass. If it gets dusty or toner accumulates on it, it will cause streaks in the printing. If this is dirty, take a clean, soft cloth and very gently wipe it off.
May 12, 2008 | Konica Minolta magicolor 2400 Laser...
Faded print on one side of page
I have a SCX-4100 Samsung, replaced the tonger cartridge, it was working fine for a few hundred sheets of printing, but after that, the left side of the page was printed very light, faded.
If I run the "Clean Drum", it will print a litter better, but still faded.
What can I do to correct this problem?
Thank you
TT
Nov 24, 2007 | Samsung ML 1710 Laser Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
214 people viewed this question
Ben Johnson
