Question about Fantech Broan-NuTone 6200 Big Heat® Utility Heater
Need new motor for 6200 big heat - Fantech Broan-NuTone 6200 Big Heat® Utility Heater
  • 57 Answers
Type it in and hit search.
Posted on Nov 28, 2012
Need rotary switch for a broan 6200 heater
The rotary switches are only offered to Original Equipment Manufacturers. They are not available for replacement parts or from distributors
http://www.towermfg.com/rswitches.htm
Feb 05, 2013 | Fantech Broan-NuTone 6200 Big Heat®...
Tip
Hi, This used to happen to me all the time. Remove the big plate cover by taking...
This is one of the most common problems with Toshiba laptops we deal with.
Indications of laptop overheating problem:
  1. The keyboard and the bottom of your laptop are very hot when the laptop is working.
  2. The CPU fans are working all the time at maximum rotation speed and operate much louder than before.
  3. The laptop suddenly shuts down by itself without warning. When it just started, the laptop was shutting down after 1-2 hours and how it shuts down after 5-10 minutes of operation.
  4. The laptop works fine when it runs idle, but shuts down as soon as you start using any memory demanding applications (DVD player, image editing software, video editing software, etc.).
Solution:
If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It’s nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes (for example Toshiba Satellite A135) you have to open the laptop case all the way down.
  2. Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
  3. Clean the fan and the heatsink with compressed air.
  4. I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
on Nov 19, 2008 | Toshiba Satellite A135-S2276 Notebook
Splendide dryer goes on & off every 3 minutes rotating the clothes the other way. Takes a long time to dry anything. Is this the way it should operate?
remove blower motor and remove caked on lent and check the over heat safety breakers with an ohm meter. also\, i find it dry faster in high speed spin mode. hope this helps
Feb 23, 2011 | Splendide 6200
The power cord heats up near the heater
From what you described, this can become a dangerous situation. Something is wrong within the heater and could cause a fire.
Stop using it immediately! If the unit is still under warranty (see your Owners Manual or the link below) contact the manufacturer's Customer Service Dept to arrange to return the heater for repair or replacement.
Below is a link to the Warranty information on your heater.
http://www.broan.com/display/router.asp?DocID=404
Hope this helps to solve your problem.
Feb 15, 2011 | Braun Big Heat Portable Heater, Model 6200
After card install, images in window are tiny. Have adj scn res but too big or too small. Help!
I think you need to install the nvidia drivesr for the video card, you can get them from www.nvidia.com its the first link, Download Drivers on the page.
Thanks,
Ekse
Jun 03, 2009 | Evga e-GeForce 6200 GeForce 6200, (256 MB)...
Boat starter motor
If the pinion moves up then the solenoid is fine, but if the starter does not spin then the starter motor is bad. Will need new starter.
Apr 14, 2009 | Briggs & Stratton 6200 Watt Electric Start...
Rowenta 6200 iron will not heat
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Apr 10, 2009 | Rowenta SM 6200 Iron
Touchpad locked
Hi don't know what OS you are using. I have a 6200 and I upgraded (big mistake) to Vista. I have had this problem when running Vista and by pure chance and out of desparation I did the following and it worked. However if the Fn F9 worked then please let me know.
On boot up press Del to enter system setup
I then went across to the Exit screen and selected Load Optimal Defaults
I then saved the changes and re-booted and it works fine. Could be pure chance
Mar 16, 2009 | Averatec 6200 Notebook
New Geforce 6200 on AGP 8x slot has no output
if you can't get a display from the onboard vga the PSU must have killed the mother board. the 6200 gets all of its power from the AGP slot. so if the PSU killed the 6200 it must have gone thru the motherboard. it does not seem likely it took out the 6200 but nothing happened to the board. try taking out the RAM modules. if the computer does not beep then most likely the motherboard is dead.
Jan 31, 2009 | XFX GeForce 6200 Graphic Card
Fantech Broan-NuTone 6200 Big Heat® Utility Heater Logo
61 people viewed this question
Top Fantech Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a Fantech Heating and Cooling Expert? Answer questions, earn points and help others
