Question about IBM 8224 Ethernet Stackable Hub 73g9764 8224-002 16 Port
How to connect IBM 8224 002 Hub
How do I connect my PC's to this hub
  • 2,878 Answers
Connect the ISP modem to main IN uplink port. Then connect pc to any other port. Done!
Posted on Nov 28, 2012
Which port to place network in put
If it is a hub then you can plug any device into any port. It doesn't matter which. All a hub does is broadcast data received on anymore out all the other ports at half duplex speeds. I'd recommend getting a switch instead. Same price and they don't suffer from all weaknesses a hub has.
Nov 28, 2012 | IBM 8224 Ethernet Stackable Hub 73g9764...
I have sahara n1356 laptop which freezes mouse and keyboard when i start it. what could be a problem
Try following tips:
Try to connect your keyboard and mouse directly to your laptop's USB ports (instead of using the USB hub) and see if they still freeze.
OR
It sounds like you're using an unpowered hub, which in my experience tends to cause most common errors with USB peripherals. It's definitely not recommended to connect any USB devices which aren't supplied with a power adapter (for instance some 2.5" external HDs and those small photo printers). These sort of devices should be connected directly to your laptop at all times.
You could also consider buying a powered hub, i.e. an USB hub which draws its power from a separate power adapter (and not your single laptop USB port).
if it doesn't work you can try this..
Click Start, and type device manager in the Start Search box.
Click Device Manager in the Programs list.
If you are prompted for an administrator password or confirmation, type your password or click Continue.
In the Device Manager dialog box, expand Universal Serial Bus controllers.
Right-click USB Root Hub and then click Properties.
In the USB Root Hub Properties dialog box, click the Power Management tab.
Remove the check from the Allow the computer to turn off this device to save power check box. Repeat steps 1 through 4 for each USB Root Hub listed in the Device Manager.
Under Power settings, check the 'USB settings' -> 'USB selective suspend settings' and make sure it is disabled.
Check Thumbnail, highlighted: Open Device manager, Double click on Universal Serial Bus controller at the bottom, Double Click USB Root Hub, Click Power Management on top right, Uncheck Allow Power...
Hope it works for you.
Sep 20, 2011 | Dell Dimension 8300 PC Desktop
Just replaced the friction plates, the clutch spring hub does not seat onto the splines. What did i do wrong?
G'day.
You don't stipulate your bikes model or year which makes this a bit harder.
When you fitted the outer hub(the one the springs sit in)- you've probably miss-aligned it.
Remove the springs again
Remove the hub- & re-fit over next set of posts(turn the outer hub so it dosn't go over the same posts as before) & it should slot all the way in.
If it dosn't-try again
It looks like the outer hub can fit over the spring posts in any position- but it can't.
I hope this works for you.
Regards Andrew Porrelli
May 20, 2011 | kawasaki VN 1500 Vulcan Classic...
Can i connect my ibm 380xd to ethernet?
the system is too old to be upgraded that much. however if there is a spot on the bottom for a wireless card to be install you might be able to do it but i think its too old for it
Jan 26, 2009 | Computers & Internet
I added a 512mb stick to my ibm t30 think pad and one port is bad
You can plug a USB hub into the working USB port on the computer. The USB hub can have several ports so you can plug in several USB devices.
I suggest you get a powered USB hub because if all the devices that you plug into this hub exceeds 500mA then your computer's USB port will stop working because it could not supply enough current.
You will not need to plug in the power adapter into the hub if the device/s do not overload the computer's USB port.
Jan 08, 2009 | IBM ThinkPad T30 2366 Notebook
Usb hub driver with my computer
Press "continue anyway" if the option is available.
It just means that the drivers for your usb have not been tested and confirmed working by Microsoft, this will happen with some 3rd party drivers.
Make sure you have system restore enabled in case the drivers do give you a BSOD as you will need to restore your system to an earlier time
Dec 05, 2008 | IBM ThinkPad T42 Notebook
"Power Surge on Hub Port
That series of laptop has a problem with it's battery which causes malfunction...
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=BATT-LENOVO
Moreover, make sure you have current BIOS and driver updates for you laptop, not all manufactures offer complete firmware updates like Lenovo; take advantage of it.
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-58597
Nov 27, 2008 | IBM ThinkPad T43 Notebook
IBM 8224 Ethernet Stackable Hub 73g9764 8224-002 16 Port Logo
106 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
