Question about SNK Magnavox 32MD357B_37 32 in. LCD HDTV/DVD Combo
Magnavox 32mf369b/f7 sound occasionally decreases by itself, as if someone pressed the button
Sometimes it works OK, then the sound will start to decrease to zero. The sound bar pops up on the screen as if someone were pressing the volume down button.
  • 1 more comment
  • oki_inu
    oki_inu Nov 30, 2012
    I noticed it also acts as if the down volume button is pressed when in the menu. I ordered the "Function, Ir, Junction Circuit Board Assembly" - the board with the buttons, since that is where that signal originates. It seems the most logical place to start because the button feels fine , just like the others, so it is not jammed. Besides it only cost $12 shipped . I will post if it works after I receive it and install it.
  • oki_inu
    oki_inu Dec 04, 2012
    Got the part today, it took about 15 minutes to replace, very easy. The board comes as 1 large piece and is designed to break into 3 smaller pieces to install. I've been running the TV since with no problems, let it run about 5 hours straight, then on and off a few times since. The back of the TV comes off very easy if all the screws (and the stand) are out. There are 2 screws on each board plus one plug to the main board. I bought it at Partstore.com, used Philips instead of Magnovox to find the board. 12 bucks and I'm happy. :)
  • oki_inu
    oki_inu Dec 05, 2012
    Solved
    Problem Solver:
  • 11 Answers
The volume button must be smashed in,dirty,or defective...I would try pressing the volume- several times repeatedly..maybe try cleaning it with a can of air.
Posted on Jan 05, 2013
2 Suggested Answers
SOURCE: Magnavox 42 LCD 42mf438b/f7 turns on/off by itself
I have exactly the same problem with a Magnavox LCD 42", very similar model 42MF437B/37. I don't have a solution. If you unplug the TV and plug it back it starts working, sometimes for hours, sometimes for less than 5 minutes, before it turns off again. Does anyone have any real solution?
Posted on Aug 01, 2009
How do i get back to the initial setup menu on my magnavox MDR535H/F7
Try the following: press Menu and use the Up/Down arrows to navigate to the General Settings. Press OK and then use the same arrows to select Display. Click OK. Again using the Up/Down arrows select Language which should be the item at the top of the list. Make sure that English is highlighted or use the arrows again to select that. Then press OK. Press Menu again to exit the entire menu system. Unfortunately, you will need to navigate through each item from the initial setup individually if any other setting is part of the problem.
Magnavox has the manual for the MDR535H/F7 on their product support page: http://www.m4c.magnavox.com/cgi-bin/cpindex.pl?ctn=MDR535H/F7&hlt=Link_UserManuals&mid=Link_UserManuals&scy=US&slg=AEN . The direct link to the manual is http://download.m4c.magnavox.com/files/m/mdr535h_f7/mdr535h_f7_dfu_aen.pdf . See pages 108 and 109 for the Language setting.
I hope this helps.
Jun 24, 2017 | Magnavox Televison & Video
Power problem
THIS IS NOT A POWER SUPPLY ISSUE PLEASE REPLACE MAIN BOARD THEN YOUR PROBLEM WILL BE SOLVED .
THANKS
Jul 28, 2013 | Magnavox Philips 32MF369B/F7 LCD TV, 32 -...
Magnavox Model 32mf369b/f7 volume stuck on down
If the volume constantly by it self lowers with display on screen of that--the vol down micro switch under the vol down button is doing this--if other let me know.
Dec 10, 2012 | Philips Magnavox 20MS3442 20" TV
I have a Magnavox 32MF369B/F7 TV. When I turn it on, it just scans inputs over and over but never detects anything. I have plugged various items in. Help?
It sounds that the memory IC to your TV is faulty. This is a very samall IC, have ony 8 solder terminals. Even though it is physically a small one, function to it when the TV works is great. It stores all the input and system data. It is a non-volatile type [means, even the power to it is switched Off, the stored memory in it wont lost] It is also called as an EEPROM [Electrically Erasable Programmable Read Only Memory]. This IC can be located very near to the main system control IC on circuit board. Replacing it is a skilled work. If you are not handy, seek tech support to replace it. It is an easy to get part, can be bought from most of the electronic spare pat selling shops at your town. Very cheap to buy too. But replacing it is a skilled work indeed.
Jun 20, 2012 | Magnavox 22MF339B F7 22 in HDTV TV
How do I adjust the screen brightness?
Press and hold fn button on your keyboard, then press F7 to decrease brightness and F8 to increase brightness. That is Fn + F7 or F8.
If F7 or F8 doesn't work try F6 or F9.
Or you can just start from F1 to F9. One of these buttons certainly would work.
Regards.
Apr 19, 2011 | Compaq Presario Notebook
How do i get regular tv channels no cable or direct tv. I have a 32' magnavox model #32MF338B/F7
Hello
I'm not sure about the model number of your TV, as here it is marked as both "27MS343S and 32MF338B/F7". Anyway I gies this solution as for the first denoted.
Insert antena to the antena socket at the back side of your TV marked as 75Ohms antena input.
[1] Press "Menu" button on the remote control handset to display menu on screen.
[2] Press "Vol+ or Vol--" button repetedly to hilight "TUN" [Tuner].
[3] Press "Ch+ or Ch--" button to hilight 'AUTOPROGRAM"
[4] Press "Vol+" to programming tv channels.
Tv will tune and store channels transmitted channels at that time, through entire bands, and will display the first channel receved after tuning process completed. It may take some minutes. You have to wait it to complete. After displaying the first channel, you can select your favourite channel Using CH+ or CH--" buttons. Ok.
Nov 03, 2010 | Philips Magnavox 27MS343S 27" TV
I have a 32 inch MAGNAVOX LCD TV that exactly half of the screen has a gray or white film in front of the picture but the picture can still be seen behind it. The other side of the tv screen is perfectly...
This problem is the cause of the T-CON board is dying.This T-CON board sit at bottom of the LCD screen right in the middle of LCD screen.Change this T-CON should solved ur problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON board for the replacement.
Sep 05, 2010 | SNK Magnavox 32MD357B_37 32 in. LCD...
Magnavox 42 LCD 42mf438b/f7 turns on/off by itself sometimes screen goes blank tv unresponsive to remote
Jul 08, 2009 | SNK Magnavox 42MF438B/27 42 in. LCD TV
Mine was doing the same thing. Update the firmware and it fixes the problem. Updating the firmware is done by downloading the file to a thumb-drive from the phillips product support page then plugging in the drive into the side of your television and turning it on. See your manual for slightly better instructions.
Jul 08, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
SNK Magnavox 32MD357B_37 32 in. LCD HDTV/DVD Combo Logo
221 people viewed this question
Top SNK Televison & Video Experts
matt martin
matt martin
Are you a SNK Televison and Video Expert? Answer questions, earn points and help others
