Question about Kitchen Ranges
My whirlpool stove burner don't work
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 28, 2012
5 Suggested Answers
MNfisherman
  • 11896 Answers
SOURCE: Flame on my Whirlpool gas stove burners are too high on low
either turn down the gas knob or turn knobs to lowest setting without going out. That is about your only options
Posted on Aug 25, 2009
rickead1
  • 1998 Answers
SOURCE: Whirlpool burner doesn't work
yes this is called the receptacle you can order this part directly from marcone appliance parts or allbrands appliance parts and they will ship it directly to your door hope this helps
Posted on Jul 24, 2010
Macmarkus
  • 2605 Answers
SOURCE: Re Kitchenaid KDRP487MSS03 dual Gas range. New.
Hello, welcome to FixYa.
I understand based on your post you have a KitchenAid dual fuel KDRP487 "New" professional range, correct ?
I'll start by saying I don't know what if anything has been suggested to you, but I'd like to ask if when you state the surface burners operate (gas) does this include the ignition system for the surface ?
If that is indeed the scenarion and yet the range is absolutely new...I have a suggestion before you go replacing parts, potentially needlessly. First and formost, insure it has 240volts at the range "correctly". (the surface will function with 120volts so don't let that fool you)
What I mean is, although it should be wired correctly...better to be absolute, 240 from L1 to L2.
If you're certain everything is correct, there is another possible scenario that will prevent any clock or oven operation...
That is the hi-limit safety thermostat may be tripped, that is the component that typically trips/activates during a self clean on many ranges. You shouldn't need to open the front control panel, but access is through the back.
You'll need to slide the range/oven outfrom the cabinet. If you slide the unit away from the wall and unplug it you can replace the hi-limit. It will be a non-reset type hi-limit (based on the model number you posted) so needs to be replaced as I mentioned, doing so will get you back up and cooking in no time.
**Unplug the range from the wall first of course...safety first**
Once you remove the panel you will need to look for a switch/thermostat which looks like this...
You can verify or dismiss this possibility with a simple continuity test (or jumping it out for testing). The replacement is available at "searspartsdirect.com" or "repairclinic.com" to name a couple.
Let me know how you make out. Good luck. I'll watch for your reply and if you need anything further I'll be glad to help in any manner I can.
Regards,
Macmarkus :)
Posted on Sep 25, 2011
  • 2122 Answers
SOURCE: Where my clock was on
F5 - E1 Self clean latch will not lock
2. If door not latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Repeat steps A and B for door switch
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#GE Range / Stove / Oven Fault Codes#ixzz1cwlkkZwU
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#GE Range / Stove / Oven Fault Codes#ixzz1cwlaiwL3
Posted on Nov 06, 2011
My 30 year old Whirlpool electric stove burners are heating inconsistently, especially the right front. If turned on medium for a while, it will turn red hot. It happens even faster when another burner...
Each burner has its own switch. I suspect your switch on that burner is bad or going bad. Conracts probably burring up from the constant arcing associated with closing and opening. Here is how it works:
Mar 02, 2013 | Whirlpool RF365 Electric Kitchen Range
My whirlpool electric stove a burner don't work l
my whirlpool electric stove top two big buner is not working
Nov 28, 2012 | Kitchen Ranges
The back burners on my stove don't work
probably burnt out can get new ones at hardware and appliance store
Jun 15, 2012 | GE Ovens
Own a KitchenAid gas range superba, how do i clean the burner, one of my front burners the gas flow is very low, the stove has the glass/ceramic top with no wells & no way to get to the burners...only...
You'll need certified stove technician to service you kitchen Aid range. You have low gas flow on one of the burner. The manual gas control valve behind the knob needs to removed and cleaned. If you have one cleaned then have technician clear all four of these manual gas valves. While he cleaning the valve have do a complete check up of you Kitchen Aid range. Dangerous for the home owners to do this procedure because flowing natural gas or propane. In a lot the states you'll need to be certified by the state to work with natural gas, gas stove, ovens, gas home heating units, etc. It differentially a no,no here.
It is not the burners, it is gas flow valves for the burners. Most of the burner are made of aluminum and I wouldn't use any harsh cleaners of them. Check with Kitchen Aid and ask them what is recommend for cleaning the burners. Also the top of the range isn't ceramic but porcelain, it glass that has been melt to the top hood of the range. Don't use scratch pads, steel wool or any thing that will mare the Periclean surface of your stove.
If you can get the aluminum burner out to clean them then do so. GB you Allison and I wish you many year cooking on your Kitchen Aid range. stewbison
walk softly up on this earth and she will good to you...
Aug 21, 2011 | KitchenAid Kitchen Ranges
I have a whirlpool stove and one of the burner doesn't work but the light on switch works. What could be the problem and how can I fix. Help pls.
1.TURN THE POWER OFF TO YOUR STOVE! In most houses, the electric stove is on it's own circuit breaker. If you are in an older home, you're probably lucky you even have a stove...just kidding! If you had your kitchen updated, every electrician should have wired your stove to its own circuit breaker. Shut off the circuit breaker.
2.Remove all the burners and catch plates under them. You are going to lift the top of your stove up. Once you've done that, see what kind of receptacle you have. You'll now have to shop around to find the part. The local appliance store charged us way too much. Lowe's or Home Depot might not have your parts, or they might. Amazon might have your part and if they don't, they will direct you to someone that will. We could have saved half the purchase price if we'd gone there in the first place.
*A quick note* The receptacle is wired to the switches at the front of the stove. They complete the entire circuit, so that is the only thing you need to worry about--from the switch to the receptacle.
After the stove top is lifted, you will find another tray under it. If the wires from the receptacles go under the tray to the "on" switches at the front of
your stove, you'll have to lift this tray up as well. Remove the tray and any other panels you need to in order to get to the switches.
3.Follow the wires, which should be color-coded for that stove top burner, until you find the switch it hooks to. If you have not purchased the parts yet, go ahead and disconnect the wire from the switch and pull the receptacle from it's aluminum cradle. You'll want these parts to take with you to find their replacements.
*note* Your new wire receptacle should consist of the housing for the burner to fit snug into, and two wires that extend from the other end. Electricity works in a circle. If the circle is broken, you have a short and that is where the spark comes from- your electrical current was trying to reach the other side and sparked to get there.
If you do have the parts, compare them to the old ones to make sure they are the same. Nothing worse than spending time on a repair with the wrong parts.
If you have the RIGHT parts, find the correct end of your wires and just slide it over the terminal at the switch. They might be the screw types. Whatever you have, connect it. It does not matter which one went where. As long as you are using the empty wire terminals you just uncovered with the old wires, you are completing the circle.
*Note* I have seen some receptacle kits that do not give you enough wire and require you to splice wires together. Not only is that a bad idea, but does not conform to electrical codes requirements and could result in fire. If the new equipment did not come with long enough wire to reach all the way from receptacle to switch, purchase a longer wire at your local hardware store. For a few pennies more you could be saving your family's lives.
4.Once you have hooked the receptacle ends to the switch harness, tie down the wires alongside the wire bundle until you get to the end.
5.Attach your burner receptacle to the aluminum clamp.
6.Attach your aluminum clamp to the stove top.
7.Screw down all the pieces you removed- anything covering the switches and the bottom tray. Put down your stove top and put in place all the shields and burners. Turn the circuit breaker back on for your stove and try it out!8_10_2012_8_42_55_am.jpg
Feb 12, 2011 | Microwave Ovens
I have a Whirlpool electric range RF263LXTQ2- 2 yrs old-it gets so hot that the large burner pans are both charred black. Had it looked at about a year ago and couldn't find any problem-top and front of...
Since you are having problems with multiple elements the problem is probably the circuit board that controls them. This can be ordered and replaced. Be sure to unplug the stove before getting into the circuit board though.
Mar 13, 2017 | Whirlpool RF263LXTQ Range
Whirlpool RJE3100N0 stove burner wire broken
its real simple. there are two wires going to the recepticle. cut them near the recepticle and replace. go to the parts store. tell them you need a whirlpool burner receptticle. done deal. keep it simple.
Feb 01, 2010 | Kitchen Ranges
Center burner igniter does not spark.
I had the same issue and it was because the little ceramic starter "button" wasn't either pulled up, or down (I don't remember). The stove is shipped with the piece in the opposite direction it's supposed to be in when operational.
Apr 24, 2009 | LG LRG30355 Gas Range
Kitchen Ranges Logo
99 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
