Question about Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher
Whirlpool quiet partner i5 dishwasher..I installed a new water line and now water won't fill. The float is down..Any suggestions
  • 4 Answers
Its possible that there is air in pipe..
Also the hight of ur washer is high..
Posted on Nov 28, 2012
  • Mark Nov 28, 2012
    There was air in the line. Had to remove the hose completely (both ends of hose) to get the water flowing. Thank you so much!
I have a whirlpool quiet partner 2. It won't fill with water. I have tried the trick to push heated dry/Sami over and over, but won't fill!! Help please!
Check for a solinoid valve under the machine. This shifts the pump from fill/wash to drain. Sometimes the slug in the coil gets stuck or rusted. Also, a float switch tells the water solinoid to open.
Dec 31, 2014 | Whirlpool Dishwashers
My dishwasher isn't draining. The garbage disposal is hooked up separately.
Is sink drain line clogged?
Disconnect drain line at sink tailpiece and lower down to see if water inside dishwasher drains.
Call serviceman to clear clog in dishwasher hose, or repair dishwasher pump motor.
Oct 13, 2012 | Whirlpool Gold Dishwasher with Quiet...
Whirlpool gu 980scggo quiet partner dishwasher leaking out water feed fitting on left side
probily just needs tightened if that dont work its just the rubber washer in the fill line just turn off water unhook like from the dishwasher side look inside the line [ where the threds are] you should find a rubber washer and take to hardwear store and replace... good luck. i hope this helps
Aug 13, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
My dishes are not clean in my whirlpool gold quite partner III. my model #gu2275xtvy0
Hi
If the water inlet valve is fine and it fills with water then the issue seems to be with the float switch assembly that is bad and should be replaced. Float assembly is found inside the dishwasher's tub, on the bottom. The water that fills the dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with dishwasher's filling and/or draining ability. Use voltmeter to test the switch. Set the device to the ohms setting x 1. Take each probe and touch them to one switch terminal each. This should produce a reading of either zero or infinity. Continue to touch the probes to the terminals, and press down on the switch's button. The reading should change to the opposite extreme. If the switch fails either of these tests, you should replace it. Hope this helps...please post back for further assistance.
Daniel
Aug 05, 2011 | Whirlpool Dishwashers
Have a whirlpool quiet partner gold and it wont fill up with water it has power
Hi
Thanks for using FixYa. To start with check the water inlet valve which is located behind the lower access panel on the left or right side of the Dishwasher. If the water inlet valve is bad you have to replace it, also check the main water line for clogs/obstructions. If still the issue is not resolved then it's a bad float switch and needs to be replaced. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 06, 2010 | Whirlpool Dishwashers
I have a whirlpool Quiet partner II. It will not fill w/water.
ck the float in bottom of tank . it may be stuck n the up pos .. moce it up and down and listen for click of the sw .. very common . also the water valve may have failed and it will need replaceing . mm
Dec 07, 2009 | Washing Machines
Dishwasher is not getting dishes clean. Water is
follow this link:
http://www.fixya.com/support/t2390397-dishwasher_acts_up
that guy gave me some good advice!
Jun 09, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Quiet Partner II not washing or sensing.
I have a whirlpool quiet partner II and for some reason it does not drain the water out any more and I cannot figure out why....people say that it is the filter but that is unbelievably hard to get to and I cannot find any instructions online or paper work that tells how to break it down. If anyone has any insight please let me know
Nov 16, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher Logo
243 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
