Question about Xerox Phaser 6350DP Laser Printer
Phaser 6360 network diagnostics link down (ND2)
In network problems I am getting a message network problem detected, Link Down (ND2)
  • 49 Answers
SOURCE: Phaser 6360 laser failure code 07
Yeah I had a look at the website there too, try powering down again and plugging it out for a longer period of time. You need to get the whole machine to reset and loose all saved info in the bios. Also cleaning it out of all loose toner on any contacts might help!
Niallbt
Posted on Mar 30, 2009
  • 3 Answers
SOURCE: the black print jobs have a shadow about 3 inches down the page
I had replaced the fuser - no improvement. I removed the fuser, imaging unit & transfer roller. CAREFULLY using a vacuum cleaner I cleaned all units and the internals of the printer, rotating the roller on the imaging unit to clean all parts. (Warning Place Imaging unit on paper as toner escapes) After a few test prints the page cleared and duplicate ghosting cleared.
Posted on May 08, 2010
shafykp750
  • 1070 Answers
SOURCE: phaser 6360 - ghosting image - i tried replacing
Welcome to FixYa
Dear User
There are faint, ghostly images appearing on the page. The images may be either from a previous page or from the page currently printed. The printer displays no error code. This type of artifact can be related to the percent coverage called out in the file being printed.
Verify the correct media type is set at the Control Panel Make sure the customer is using color correction (limiting color to max 240%). Other graphic applications can exceed 240%.
Note:For Phaser 6350 and 6360 configurations printing color at 36 ppm and above limits color coverage to a maximum of 200%. Try printing with fresh media from a recently opened ****
Avoid long runs of the same image.
Set the paper type to the next heaviest type.
Replace the Fuser
Hope you got it..Thanks for Connecting Fixya
Posted on Aug 21, 2010
lawdog81
SOURCE: xerox phaser 6360 is ghosting.
Most common cause of this is the use of 3rd party toner. This isnt true for all printers but some of the newer Xerox are notorious for it as the 3rd party toners are not produced to the exact specs as xerox. If your not using genuin Xerox toner you have your cause.
If your mechanicaly savy you can completely dissasemble most of the printer in order to clean out the toner. Then start over with new Xerox toner cartridges. I have had to service 2 of these printers in this way, and both were like new when done.
Posted on Feb 11, 2011
StevenC82
  • 160 Answers
SOURCE: Xerox phaser 6360 laser failure
The most likely cause here is the laser unit, check all connections to the laser unit and cycle the power (turn the machine off and on) if error continues replace the laser unit. You can buy a replacement for $350 new or $225 refurb. Part# 062K17233. Installation isn't very simple, so if you aren't a technician you may want to bring it to one. Good luck
Posted on May 03, 2011
Xerox phaser 6360 smearing magenta toner only
that's the developer assembly that has gone bad. If you're using 3rd party toner it wears down a lot quicker. You'll need to replace the magenta developer unit, part number is 848K03850.
http://www.iteminconline.com/848k03850_848k03850-xerox-6360-developer-assembly-magenta-oem-new-genuine.htm
Feb 09, 2016 | Xerox Office Equipment & Supplies
The screen on my Phaser 6360DN is to light to read, is there a way to adjust thee contrast?
On control panel press DOWN button to highlight "PRINTER SETUP". press OK. Press DOWN button to highlight "CONTROL PANEL SETUP" press OK. Press DOWN button to highlight "CONTROL PANEL CONTRAST" press OK then press UP or DOWN button to adjust. Repeat for "CONTROL PANEL BRIGHTNESS" if required. Press RETURN several times to go back to HOME screen
Apr 20, 2010 | Xerox Phaser 6360 Laser Printer
The black print jobs have a shadow about 3 inches down the page
Apr 07, 2010 | Xerox Phaser 6360 Laser Printer
Trying to install a new mpt (shootout) assembly for the xerox phaser 6350. Is there a manual/diagram somewhere that I can refer to? Thanks!
Here is a link to the complete service manual for the xerox phaser 6350 it has full diagrams and step by step detailed instructions for every part of the printer
http://www.scribd.com/doc/42787465/XEROX-Phaser-6300-6350-6360-Parts-List-Service-Manual
Hope this helps
Mar 23, 2010 | Xerox Phaser 6350DP Laser Printer
Priter prints garbage after a few pages
well your printer is a piece throw it out and get a new one
Mar 09, 2010 | Xerox Phaser 6360 Laser Printer
Cannot install Xerox Phaser 6360 Laser Printer" on vista
http://www.support.xerox.com/go/results.asp?Xlang=en_US&XCntry=USA&prodID=6360&ripId=&Xtype=download
open the above link.it takes you to the download page
Nov 03, 2009 | Xerox Phaser 6360 Laser Printer
Xerox 6360 control panel blank
If your Xerox Phaser 6360 has either garbled characters, inverted or upside down display, or no display, the control panel is most likely bad and must be replaced. Here's a video on how to do it and where to get it. Hope it helps!
Mar 30, 2009 | Xerox Phaser 6360 Laser Printer
Xerox Phaser 6360N ghosting images on each page
Is it a ghost of the image or just a repeating defect? In the menu, there is a repeating defect information page that you can print out. Depending on the spacing of the defect, you can determine which component it is.
Mar 10, 2009 | Xerox Phaser 6360/N Printer
Niallbt
Feb 25, 2009 | Xerox Phaser 6360 Laser Printer
Xerox Phaser 6350DP Laser Printer Logo
83 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
