Question about Ionic Zone Air Purifiers
How do i take my ionic pro apart to clean - Ionic Zone Air Purifiers
SOURCE: Ionic Pro CA-500B Power On Instant Clean Light
If the plates are clean, there is nothing wrong with them. They are just 3 strips of metal... they don't even connect to each other unless they are in the unit. NO NEED TO REPLACE THEM.
Posted on Jul 28, 2008
rdanner3
  • 3 Answers
SOURCE: ionic pro won't turn on
Solution, perhaps...
All electrical contacts can get a film on them. Try cleaning the contacts (at the bottom of the blade unit; you should see the three with the blades out) with an alcohol swab (make sure the contacts are dry before reassembly in this case) or a pencil eraser (vacuum the debris out before attempting to start it again).
If those contacts don't make up properly, the unit will think it needs cleaning, even though it doesn't.
Posted on Feb 23, 2009
SOURCE: Repair an Ionic Pro
Here is the PDF manual. http://www.ionicpro.com/pics/ip_manual.pdf
Posted on May 24, 2009
jepito
  • 216 Answers
SOURCE: Ionic air cleaner
take out the insert and clean it real good ... there is a leaver on back of the machine move it up and down about 10 times to clean the strands ...... make sure you clean the 3 steel thin metal strips good let it dry before you put it back in to the machine ..... + i have that same machine - i have 2 cats - it gets dirty quick
pss the poping sound is the machine is telling you it is dirty ... static electric charge
Posted on Sep 03, 2009
  • 3 Answers
SOURCE: Ionic Pro makes weird buzzing noise
I found that the buzzing can be removed by blowing out the unit, cleaning the blades and taking a long cotton swab and alcohol to thoroughly clean the corona wire - carefully - don't break it. The wire should be clean enough that the slider/wiper runs smoothly up and down the wire after cleaning. If it drags or is rough to slide, you will still have noise no matter how many times you clean the blades. The wire gets a "crust" on it.
Posted on Sep 16, 2009
Why does my ionic pro turn off for 2 seconds and demand to be cleaned even though it's been cleaned and dried and reset correctly?
I work for the Ionic Pro company. Please call customer service at 800-875-8577 and they will do some troubleshooting with you. Thank you, Mary
Dec 27, 2010 | Ionic Pro TURBO Air Purifier
How do you take the unit apart?
I work for the Ionic Pro Company. Please call customer service at 800-875-8577 and they will walk you through the steps. Thank you, Mary
Dec 19, 2010 | Ionic Pro 901P2RIP04 Air Purifier
My ionic pro turbo air purifier keeps buzzing even after I clean it
Hi lsalazar113
I work for the Ionic Pro company. Make sure you are cleaning the ionizing wire too. If that does not help, please call customer service at 800-875-8577 and they will be happy to assist you. Thank you, Mary
Dec 19, 2010 | Ionic Pro TURBO Air Purifier
How do you get it apart? really dirty insideand i don't want to snap it in to.
Un-plug the unit,pull the top piece of plastic off and lay it on its back.While its on its back a little peice of plastic drops and allows you to slide the ionic parts back inside..Try cleaning with regular shop and water and cotton towel..
May 27, 2010 | Ionic Pro CA500 Air Purifier
I have cleaned my ionic pro several times works for a few minutes and then says clean again what can I do?
Please call customer service for Ionic Pro at 800-875-8577. They will provide troubleshooting instructions and if they do not correct the issue, they will give you instructions on how to get your unit replaced. Thank you.
Feb 08, 2010 | Ionic Pro TURBO Air Purifier
Ionice breeze quadra Model # S1637
had the same problem with ionic pro ca500. i took the unit apart and found a fuse that was blown and it works now. sorry but i don't know if there is any repair shops.
Aug 02, 2008 | Sharper Image Ionic Breeze 3.0 Air...
Ionic pro compact and ionic pro turbo
The clean light stays on and purifier doesn't work but unit is clean.
Jun 09, 2008 | Ionic Pro Air Purifiers
Ionic Pro Turbo
When you turn on it goes to clean but unit has been cleaned.
Dec 25, 2007 | Ionic Pro TURBO Air Purifier
My Ionic Pro doesn't turn on
i have taken the unit apart and found that if there is a broken wire you have to be a magician to fix it even if you had spare wires.
also found a small fuse in the bottom of the unit but it is soldered in. i am currently in the process of replacing and will post results asap.
Dec 12, 2007 | Ionic Pro 901P2RIP04 Air Purifier
Can't clean Ionic Pro CA-500 inside?
This unit is a pain in the @$$ to disassemble but it CAN be done. The way I always look at it: Someone ASSEMBLED it.
Remove the four screws on the bottom stand followed by two screws on the bottom side of the unit. Then remove the tiny little screws up each side that hold the grill together (you will need a precision screwdriver).
Carefully pull apart- don't force it.
One half comes off (clean that half) in bathtub. The other half does not come off-vacuum that half out and use q-tips.
When re-assembling, watch for two things: First the wire cleaner (that slides) runs on a track on each half- pull it out a little to best allow for fitting. Second, there are little tabs at the top that fit under the control panel-watch for those.
email me at originalpairadice@yahoo.com if any problems.
Oct 19, 2007 | Ionic Pro 901P2RIP04 Air Purifier
Air Purifiers Logo
100 people viewed this question
Top Ionic Zone Air Purifiers Experts
Are you an Ionic Zone Air Purifier Expert? Answer questions, earn points and help others
