Question about Xerox Phaser 6350DP Laser Printer
Phaser 6360 network diagnostics link down (ND2)
Link down (ND2)
  • 49 Answers
SOURCE: Phaser 6360 laser failure code 07
Yeah I had a look at the website there too, try powering down again and plugging it out for a longer period of time. You need to get the whole machine to reset and loose all saved info in the bios. Also cleaning it out of all loose toner on any contacts might help!
Niallbt
Posted on Mar 30, 2009
  • 3 Answers
SOURCE: Priter prints garbage after a few pages
well your printer is a piece throw it out and get a new one
Posted on Mar 09, 2010
  • 3 Answers
SOURCE: the black print jobs have a shadow about 3 inches down the page
I had replaced the fuser - no improvement. I removed the fuser, imaging unit & transfer roller. CAREFULLY using a vacuum cleaner I cleaned all units and the internals of the printer, rotating the roller on the imaging unit to clean all parts. (Warning Place Imaging unit on paper as toner escapes) After a few test prints the page cleared and duplicate ghosting cleared.
Posted on May 08, 2010
shafykp750
  • 1070 Answers
SOURCE: phaser 6360 - ghosting image - i tried replacing
Welcome to FixYa
Dear User
There are faint, ghostly images appearing on the page. The images may be either from a previous page or from the page currently printed. The printer displays no error code. This type of artifact can be related to the percent coverage called out in the file being printed.
Verify the correct media type is set at the Control Panel Make sure the customer is using color correction (limiting color to max 240%). Other graphic applications can exceed 240%.
Note:For Phaser 6350 and 6360 configurations printing color at 36 ppm and above limits color coverage to a maximum of 200%. Try printing with fresh media from a recently opened ****
Avoid long runs of the same image.
Set the paper type to the next heaviest type.
Replace the Fuser
Hope you got it..Thanks for Connecting Fixya
Posted on Aug 21, 2010
lawdog81
SOURCE: xerox phaser 6360 is ghosting.
Most common cause of this is the use of 3rd party toner. This isnt true for all printers but some of the newer Xerox are notorious for it as the 3rd party toners are not produced to the exact specs as xerox. If your not using genuin Xerox toner you have your cause.
If your mechanicaly savy you can completely dissasemble most of the printer in order to clean out the toner. Then start over with new Xerox toner cartridges. I have had to service 2 of these printers in this way, and both were like new when done.
Posted on Feb 11, 2011
Xerox phaser 6360 smearing magenta toner only
that's the developer assembly that has gone bad. If you're using 3rd party toner it wears down a lot quicker. You'll need to replace the magenta developer unit, part number is 848K03850.
http://www.iteminconline.com/848k03850_848k03850-xerox-6360-developer-assembly-magenta-oem-new-genuine.htm
Feb 09, 2016 | Xerox Office Equipment & Supplies
Xerox phaser 6360 imaging unit stuck
The lid lifts a lever on the right side of the printer that moves a set of gears that releases the imaging unit. If the lever is broken or disconnected, it will not release. You may have to remove the right side panel to resolve it. You have to release the top, by removing 4 screws, and then the panel will release.
May 18, 2012 | Xerox Phaser 6360 Laser Printer
Phaser 6360 printer as a error code 07
Unplug the printer from power for at least half an hour. Overnight would be better.
Jul 07, 2011 | Xerox Phaser 6360 Laser Printer
The black print jobs have a shadow about 3 inches down the page
Apr 07, 2010 | Xerox Phaser 6360 Laser Printer
Mar 09, 2010 | Xerox Phaser 6360 Laser Printer
Are LD products safe to use?
Safe , most likely, recommended? I don't recommend using generic supplies in anything but ink ket printers. By that I mean the liquid inks. The toner is a phaser is pretty unique, and the OEM toner is by far the best way to go.
Jan 20, 2010 | Xerox Phaserâ„¢ 6360/DT Printer
Cannot install Xerox Phaser 6360 Laser Printer" on vista
http://www.support.xerox.com/go/results.asp?Xlang=en_US&XCntry=USA&prodID=6360&ripId=&Xtype=download
open the above link.it takes you to the download page
Nov 03, 2009 | Xerox Phaser 6360 Laser Printer
Xerox 6360 control panel blank
If your Xerox Phaser 6360 has either garbled characters, inverted or upside down display, or no display, the control panel is most likely bad and must be replaced. Here's a video on how to do it and where to get it. Hope it helps!
Mar 30, 2009 | Xerox Phaser 6360 Laser Printer
Niallbt
Feb 25, 2009 | Xerox Phaser 6360 Laser Printer
Market projection and price of of this product Xerox phaser 6360
50,000 pages a month and depending on features, $1400 to 3000.
Feb 02, 2008 | Xerox Phaser 6360 Laser Printer
Xerox Phaser 6350DP Laser Printer Logo
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
