Question about Yard Machines Red Edger
Where does gas go?
I inherited a tecumsch big red (? ) yard trimmer, I see where the gas goes but I cannot tell where the oil goes. there is a yellow cap on the lower right of the machine I suspect that is where it goes but want to be sure and what kind of oil?
  • birdysnest66 Jan 29, 2009
    Thank you LOTS!!!!!!!
  • Mark Tripp
    Mark Tripp May 11, 2010
    What is your model # and serial # from your machine so that I can look it up?
4 Suggested Answers
rwvanlue
  • 486 Answers
SOURCE: yard machine ym26ss straight shaft trimmer. New gas,
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Posted on Nov 12, 2009
  • 5 Answers
SOURCE: does the yard machine 3.5 hp gas take a oil/gas
no it takes regular unleaded gass. you put oil in the oil resevoir from the top that says oil.
Posted on Sep 22, 2010
bustech17
  • 38 Answers
SOURCE: how to feed trimmer line on y25 yard trimmer gas
Depending on what type of string head you have. If it's a "tap and go" style head, just rev it up full throttle and tap it on the ground. It should feed the string out and the blade on the shield will cut off the string to the correct length.
Posted on Sep 23, 2012
Please tell me exactly how I mix the gas and oil for my 22 in gas hedge trimmer Ryobi Model RY39500A HT 26. What type of gas, what type of oil. Also can I buy this premixed?
If you go to your local home center in the lawn care section they will have these little plastic bottle of two cycle engine oil they treat a gallon of gas if this is your only machine that mixes gas and oil you probably will not use a whole gallon in a season and you should not keep the mixture for to long it will not last. So doing some simple math and looking at back of container try to mix the ratio down if a whole gallon is not needed. Good Luck...
Sep 05, 2011 | Ryobi 26CC, 22 In. Hedge Trimmer
What is the gas oil mixture for homelite sx135 trimmer
Use 32:1 with good quality 2-cycle oil. I have Used Stihl, Homelite, Poulan and Several Other 2 Cycle Trimmers in the Yard Maintenance Service and Have Found the 32 to 1 Mixture to Extend the Life of the Engine. Always Remember to Drain the Tank and Run the Engine Until the Carbuetor is Empty for Off Season Storage.
Sep 27, 2010 | Homelite Mighty Lite Lawn Trimmer
Does the yard machine 3.5 hp gas take a oil/gas mix Model#25a580a062
Aug 28, 2010 | Yard Machines Red Edger
How long should trimmer run on a charge.
How large is your yard? On a small yard (like a townhouse front & back yard) the trimmer should last long enough to do the yard a couple of times before needing to be recharged, but it depends on the individual yard, how many weeds you have, and whether you keep it running a long time.
If the trimmer charges at all but not for a very long time, it's either the charger or the battery. Check the charger when it's charging to make sure the red light stays on -- if it goes off or blinks, you need a new charger. If the charger light stays on but the battery doesn't hold a charge, you need a new battery.
Hope that helps!
Jul 16, 2010 | Black & Decker Cst2000 12 - Volt Cordless...
Yard machine ym26ss straight shaft trimmer. New gas,
1) spark plug
Chain Saws:
Remove Carburetor
Nov 12, 2009 | Yard Machines Garden
I need to know the gas to oil ratio on a Homelite Versatool I inherited.
heres a link for homelite service manual
http://www.odref.com/homelite/string-trimmers/service%20guide.PDF
pg 4 states that fuel/oil mix is 50;1
2.5 oz per gallon
Thanks.
Jun 28, 2009 | Homelite Garden
I inherited a Weed Eater 1500 gas yard timmer. In
well there should be the prime bubble well screw it if you can call me i can help. 706-354-3867 my name is callie
Apr 28, 2009 | Garden
Oil dipstick and red twist knob on top of the two pressure gauges
the big red knob adjusts working pressure to hose- refer to book or dowload online
Dec 08, 2008 | Clarke Power Products AC2002A 2 Hp Air...
Yard Machines Red Edger Logo
76 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
