Question about Refrigerators
Kenmore Elite SBS ice maker will make ice, but it won't dispense it.
I have a Kenmore Elite side-by-side refrigerator/freezer. The ice maker makes ice, but the dispenser won't dispense it. When I press the button to dispense ice, I can clearly hear the motor working, but it is not spinning the ice auger in the bin. If I take the ice bin off, the auger moves freely if I try and move it manually. But I notice that the couplings which attach to the ice bin don't move (I shut the door and press the ice dispenser button and then re-open the door to see if the coupling changed position). I suspect that something may be frozen preventing the coupling from moving, but I don't know how to get to it. I took the front panel off the refrigerator, and there is still more to get through. Anyone know how I can get to the coupling shaft and motor area?
4 Suggested Answers
KOakaKO
  • 135 Answers
SOURCE: Ice maker won't dispense ice
The next step would be to use an "Ohm-meter" to check the switch on the door that is supposed to activate the auger circuit. If the switch is good, then you need to check the wires leading up to the switch for available voltage. (Keeping in mind that you may not get voltage on that line unless the "door closed" switch is closed.) If you have good voltage there, then you need to check the wires leading to the auger motor to see if the voltage gets to the motor. If the connection is good, and you get voltage to the motor, then the motor is faulty.
Posted on Aug 04, 2007
outdoorsman5
  • 631 Answers
SOURCE: Kenmore side by side fridge - ice dispenser stopped working
You might check out this site and ask a question. They have drawings on many of the fridges and I have bought many parts from them.
http://www.appliancepartspros.com/partsearch/
Posted on Jul 28, 2009
TheMobilian
  • 8220 Answers
SOURCE: I have a GE side
That could be a sign of a drippy water valve. When water valves get a little age on em they drip like an old faucet. Also if the ice maker itself overfills or is not level then a tad of water gets into the bin. This makes the ice stick together. An unusually long dwell in the auto defrost cycle can also cause the cues to melt and stick together. The only way to fix it is to do some diagnostics.
Posted on Jul 26, 2011
MY ICEMAKER STOPED MAKING ICE ,I GE WATER BUT NO ICE..HEKP.
The ice maker not working: ---
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
Oct 18, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite ice maker stopped making ice,
There are many things that can go wrong with a Kenmore refrigerator ice maker. Your ice maker may be leaking. It may not make any ice at all, or the ice that comes out smells or has an odd appearance. The problem may have an easy solution, or it may require a technician's expertise. The troubleshooting tips in this article will minimally make you aware of what is likely the source of the problem. You may be able to fix the problem yourself and save a bundle.
When it Won't Make Ice
1 Get a thermometer and see how cold it is in there. If your freezer is fewer than 17 degrees F, it won't make ice. The freezer temperature setting may be too high or the thermometer is broken and not calibrated correctly. If adjusting the temperature fails to work, call a Kenmore technician.
2 Determine if your water fill spout in the freezer is plugged with ice. If so, no new ice can be made. Try clearing it out or melting the ice by running a hair dryer on it for a few minutes.
3 Turn your refrigerator around to look at the back side to see if water is getting to the water inlet valve behind the fridge. If the water is not properly connected, there's no water to make ice.
4 Use an ohm meter to test for coil continuity. If the ohm meter shows there is no continuity, then you will need to replace the water inlet valve.
Hope thiswould help you
Have a good day : )
Jan 01, 2011 | Kenmore Refrigerators
My kenmore elite side by side is making a buzzing
The buzzing noise is likely coming from the main power board and will need to be replaced.
Nov 08, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite side-by-side ice maker creaking!
Look behind the freezer rear trim panel for frosted/iced evap. coils and thaw if necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 29, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Refrigerator Ice Maker
ck condensor fan motor that cools compressor under unit. yoder loop runs through center divider and causes gaskets to get hot
Aug 26, 2009 | Kenmore Freezers
Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
Jul 24, 2009 | Refrigerators
Water dispenser inside fridge and ice maker in freezer part in bottom both quit working.
There can be many reasons for no water supply. Line feeding the refrigerator is clogged or blocked. The water control valve that turns water to ice maker and dispenser is defective or the water filter located inside your refrigerator is in need of change. I will be here to help you go through the steps. Let me know when you are ready, Thanks, Sea Breeze
Apr 28, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite refrigerator 795.775.62600
make sure the ice maker is turned on, push and hold the little round button on the front for 15 seconda and see if it starts up an cycles. Also check to make sure the fill tube isn't clogged to the ice maker and another thing to check is the water valve.
Sep 04, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
