Question about Nintendo Wii Console
The cursor jumps around the screen
When I point the wii remote directly at the sensor the cursor doesn't appear. I have to hold it at an angle and then it still jumps around the screen. The senor is plugged in correctly and is clean.
  • 64 Answers
Reposition your Wii so when you play you aren't pointing the controller toward a bright light (like a window or lamp). Bright lights freak out the controller. I have a huge window in the room with the Wii, and I have to wait until mid morning on sunny days or it's almost impossible to control.
Posted on Jan 17, 2009
Cant get the cursor to show on screen
Make sure that your Sensor Bar is connected properly and that there is no damage to the wire connect it to the Wii.
You may have to place the Sensor Bar else where and reconfigure it to work again.
Ref: http://www.nintendo.com/consumer/systems/wii/en_na/ht_system.jsp
-Connect the Sensor Bar under Wii Console in the left menu.
Dec 19, 2012 | Nintendo Wii Console
My wii point icons jumps around
have you tried changing the sensitivity undersettings on the wii itself.
take a look at the link it will tell you how
http://www.nintendo.com/consumer/systems/wii/en_na/systemSettings.jsp
also if you are to far away from the sensor it will jump.
Jan 06, 2010 | Nintendo Wii Console
Yesterday i was playing on my wii at my friends house and whe i bring it back to my house cursor do not appear i can press a button and + - buttons but i do not see any cursor... my wii is 2 days old...
Make sure to the little blue light on the wii remote is on on the far left. You may have to sync it. Take the battery out of the wii remote and there is red sync button. There is another red sync button under the little flippy door on the front of the wii where the SD card slot is. press both buttons and wait for the wii remote to stop blinking. Then point it directly at the sensor.
Dec 02, 2009 | Nintendo Wii Console
Cant get past language screen
Here are instructions from Nintendo on how to fix this issue. It's most likely related to the sensor bar. Good Luck!
If your screen appears frozen at the Language select screen, we have found that to be related to the Sensor Bar. Please try the following:
Ensure that the Sensor Bar cord is plugged snugly to the back of the console, and is placed properly at the center of your TV screen. For detailed directions on setting up the Sensor Bar, please click here.
Check to be sure the Wii Remote is synced to the console, by using the Power button on the Wii Remote to turn the console on. (The power button is the small white button with the red symbol in the top-left corner, just above the Control Pad). If this doesn't work, try to sync the Wii Remote. Once synced, try to turn the power on the console on and check for proper response.
Make sure that the Wii Remote is being used between 3' and 10' directly in front of the TV and that there are no bright light sources affecting the Wii Remote's operation (review Game Play Guidelines for more information), and that the Sensor Bar is placed properly (see Sensor Bar setup). Avoid sources of infrared light in the gameplay area such as electric, propane or kerosene heaters, flames from fireplaces or candles, and stoves or other sources of heat.
If you are still experiencing problems after trying the steps above, there could be a problem with your Sensor Bar. Please read the following:
The Sensor Bar has five infrared lights on each side of the bar that the Wii Remote uses to determine its position. If these lights aren't working, then the Wii Remote cursor will not display on the screen, and you won't be able to navigate the setup screens.
To see these lights, you will need a digital camera or cell phone camera with an LCD display . After making sure the Sensor Bar is plugged in and the power to the console turned on, direct the camera at the Sensor Bar so that it is displayed in the LCD of the camera. If the five infrared lights can be seen on both sides of the Sensor Bar, the Sensor Bar is working. While the position/angle of the camera may need to be adjusted slightly, the lights are fairly easy to see in the LCD display.
Nov 20, 2009 | Nintendo Wii Console
How do you navigate the main screen
Maybe I am not understanding the question, but you normally would use one of the remotes, make sure the receiver bar is either at the top of bottom of the screen and use the remote pointed at the screen to move the cursor around, click on the desired object using the A button on the front of the remote.
Remote has to be pointed at the screen for the cursor to move around and any movement you make will move the cursor.
Sep 08, 2009 | Nintendo Wii Console
Wii remotes want to point at a wall light
well if u keep them on the charger for to long u need to get new ones cuz it will shorten the batteries on and on so buy new ones k!
Mar 25, 2009 | Nintendo Wii Remote Controller
We moved our Wii to another location and a new TV and now the remotes point and click is inaccurate and we cannot easily aim at all. I thought it was the bar sensitivity but I think that's fine. Any ideas?
Cursor is off-center, jerky, erratic, disappears, etc.
  • Verify that the Wii Remote's pointer lens is free of obstructions and contamination (stickers, heavy smudges, etc.). The pointer lens is the tinted rectangle at the end of the Wii Remote. If the Wii Remote Jacket is being used, verify that it's securely in place on the Wii Remote. If the Wii Remote Jacket is askew, it might be partially blocking the infra-red sensor on the front of the Wii Remote.
  • Try a new set of batteries. Occasionally weak batteries can cause this type of behavior.
  • Reset the Wii Remote:
    1. Take the batteries out of the Wii Remote, wait for one (1) minute, and then re-insert them. (How to)
    2. Wait a few seconds before pressing any buttons to wake up the Wii Remote.
    3. Re-sync the Wii Remote by using the steps listed above in the white box titled "Try these steps!".
  • Check the Directional Sensor Functionality by holding the Wii Remote with the button side down. Without using much force, tap the button side of the remote against the palm of your other hand. Doing this does not take a lot of force, so be sure not to tap the Wii Remote very hard.
  • Verify Sensitivity Setting dots:
    Go to the Sensor Bar's sensitivity setting in the Wii menu (click here for directions on accessing this feature).
    • If only one or no dots appear on the sensitivity screen, there is likely a problem with the Sensor Bar. Please click here for repair information.
    • If there are more than two dots, then it appears there is an additional light or infrared heat source being picked up by the Wii Remote. Avoid sources of infrared light in the gameplay area such as electric, propane or kerosene heaters, flames from fireplaces or candles, and stoves or other sources of heat.
    • If both dots appear and the erratic behavior continues even when you move closer to the TV, there is likely a problem with the Wii Remote and it will need to be repaired. Please call 1-800-255-3700 so that we may assist you further
Nov 27, 2008 | Nintendo Wii Console
Cursor does not appear
exchange it
    Cursor not appearing
    Please note that our experience shows that this troubleshooting is best performed using only one (1) Wii Remote at a time.
  • Some games do not use the cursor feature of the Wii Remote; Make sure the game you are attempting to play uses the cursor by reading the game's instruction manual. You can also exit out of the game to return to the Channel Menu and use the Wii Remote to see the cursor. If the cursor still does not appear, continue with the steps below.
  • Trying to use multiple Wii Remotes in the Mii Channel or Photo Channel? These Channels only allow the Wii Remote designated as "Player 1" to function.
  • Check the battery power level by turning off the Wii console, then opening the battery cover of the Wii Remote. Press and release the red "SYNC" button to check battery strength. The number of lights flashing indicates the Wii Remote's battery strength. Four flashing lights indicates full strength. Our experience has shown that as your battery strength decreases to one (1) or less lights flashing, the cursor may not appear. For troubleshooting, if possible, try using fresh batteries so that all four lights illuminate. For guidelines on using batteries, please click here. If after inserting brand new batteries, you are still seeing less than all four LEDs flash, then your Wii Remote will need to be repaired. Please click here for repair information.
  • Is the Wii Remote properly synced?
    Press the POWER button on the Wii Remote to see if the Wii console powers on.
    • If it does, the Wii Remote is synced with the system. Please skip to the next section.
    • If the power doesn't come on, power on the system manually and try syncing the Wii Remote.
      • If the Wii Remote will not sync, there is likely a problem with the Wii Remote. Please click here for repair information.
      • If the Wii Remote will sync and the cursor still does not appear, try another Wii Remote if possible.
        • If at least one Wii Remote is working, there is likely a problem with the first Wii Remote and it will need to be repaired. Please click here for repair information.
        • If you have only one Wii Remote, or none that are working, please continue troubleshooting.
  • Make sure that the Wii Remote is being used between 3' and 10' directly in front of the TV and that there are no bright light sources affecting the Wii Remote's operation (review Game Play Guidelines for more information), and that the Sensor Bar is placed properly (see Sensor Bar setup).
  • Check the cord on the Sensor Bar for any frayed wires or kinks, and verify that the Sensor Bar is free of obstructions.
  • Check the button functionality, and that the Sensor Bar is operating correctly, by accessing the Wii Main Menu. Use the "+" and "-" buttons to scroll side-to-side through the Wii Channel screens.
    • If you are able to scroll with the "+" and "-" buttons, but the cursor is not appearing, then there is likely a problem with the Sensor Bar. Please click here for additional Sensor Bar information.
    • If there is no response, there is likely a problem with the Wii Remote. Please click here for repair information.
Dec 11, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
740 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
