Question about Makita 2012NB Electric Planers
Makita 2012NB slipping
My Makita 2012NB seems to be slipping, as boards are fed through, it seems to stop feeding momentarily, every second or two, i.e. it "skips." The primary drive belt seems fine, as do the roller drive gears and chain, including the very simple, effective chain tensioner. I have been planing redwood lately. I HAVE cleaned the rollers with EtOH, rollers which looked clean enough already, a cleaning which made no apparent difference, and I DID replace my blades not long ago, but I think they're dull (getting more dust than shavings). I was having this problem then, and don't think new blades made much difference. I think I'll go rotate them. My planer might have 50-100 hours on it. Any OTHER ideas? Do I need new rollers?
  • Richard Savary Nov 28, 2012
    I had the same problem, the slipping or "skipping" (every so often to continuously) as some call it. It was getting progressively worse. I checked the primary drive belt, and the secondary drive gears and chain, and they all look perfect. With the sides off, I could see that all parts were functioning perfectly, but the rollers still slipped. They looked clean, but I cleaned them anyway, with EtOH... to no effect. So then, having read that the rollers might be glazed, I cleaned them again, this time with EtOH and steel wool (about 00). I also heard that waxing the platen with paste wax might help a lot, so I did that, too. The upshot is that it worked! I've planed several 12' boards today, 6-8 passes each, and it didn't skip or slip once, in fact, it's suddenly working almost like new. I think that drag from the platten, which has a certain amount of wear, may have contributed to the problem, but I think the rollers were the main culprets, that glaze causing them to slip, and my steel wool removing some of the glaze. I'm not sure if steel wool is the ideal treatment, but it seems to barely make a dent in them, and it does the job. I think that a new blade (I replaced it fairly recently, but have planed a lot of dirty, rough-cut lumber, and my chips have turned to dust), which I will install as soon as one rolls in, would also help to tune 'er up. Considering how reliable this planer has been, I don't feel any need to complain. This fix was free. Hope it works for you.
  • Richard Savary Nov 29, 2012
    The planer was, BTW, a Makita 2012NB...
My makita2012NB was also slip too. I tried to fix it out then I found if I screwed the screw under the rollers tighter it could reduce this problem.
Posted on Jan 21, 2013
4 Suggested Answers
  • 165 Answers
SOURCE: Makita Model 2012nb Planning 3 &4 ft. red
Stripped gear in the feed mechanism? Use another, thinner board to help feed the wood evenly as a stopgap measure.
Posted on Feb 28, 2010
rowdy45176
  • 2176 Answers
SOURCE: My 2012NB has served me well for about 10 years,
I just read the owners manual online at Makitausa.com and I don't see the reference to the feed rollers and pressure.. I would look at the condition of the planer blades to ensure they are sharp and not pitted. Then I would look at the feed rollers for being out of round. Let me know, it has been a couple years since I worked on one of them.
Posted on Jul 01, 2010
SOURCE: My Makita 2012 planer 'skips' making a 'machine
Have you cleaned your rollers? I must admit, I'm having this problem with my 2012NB, I HAVE cleaned the rollers (with ethanol), and have taken the side covers off, and the drive chain and gears look just fine, as does the primary drive belt. I ran the planer with the covers off, and although the gears and belt seem fine, the planer still skips (or slips). I think probably your blade is dull, creating drag (I replaced mine not long ago, but have been planing a lot of rough lumber). I still haven't gotten to the bottom of it, but I think the rollers are slipping, I just don't know why yet.
Posted on Nov 28, 2012
Makita planer 2012NB belt replacement
Use dish washing liquid to lubricate the roller and belt on both rollers and place the belt equally on each roller and move in on both rollers evenly
Feb 15, 2013 | Makita 2012NB Electric Planers
Makita 2012nb replacement motor
I have a service center for Makita tools and the only way to fix or replace the motor is to buy the parts you need, in this case the armature (PN 516811-8) and field assembly (PN 526101-1). You can go to a site like www.ereplacementparts.com or any other aftermarket site to get them or try finding a local Makita repair center and find out how much it would cost to get the parts through them.
Aug 27, 2012 | Makita 2012NB Electric Planers
Makita 2012nb planer. The drive (top) sprocket keeps stripping out the flats on its arbor hole and the allen bolt loosens and backs out. Not sure which happens first. I've tried high strength loctite...
I think your screw is broken you should change the screw which attach the rollers and the blade. If you start a machine, screw turn out and let the roller stop rolling that means your screw and the ring are broken, you have to change them.
May 08, 2011 | Makita 2012NB Electric Planers
My Makita 2012 planer 'skips' making a 'machine gun' sound and the wood won't feed through. I think it's the 'plane bearings', but I'm not sure. Does this sound right?
Feb 02, 2011 | Makita 2012NB Electric Planers
Bought it at auction. Runs fine, blades sharp, feeds fine. But doesn't seem to cut. Like the head isn't contacting the wood. What do I do?
The blades may not be positioned correctly in the cutting head. Check and adjust as necessary. The Makita Website may provide the information you need for this.
Sep 17, 2010 | Makita Tools 12" Planer - 2012NB
I have a brother copier model dcp 7025 and am experiencing a vertical line on copies where the original is fed through the top feeder tray but the copies are fine when the original is placed directly onto...
Depends which way is vertical but I think the feed rollers on the upper tray are slipping perhaps dirty. (The paper momentarily stops feeding past the scan sensor)
Jul 14, 2008 | Brother Office Equipment & Supplies
Makita 2012NB Electric Planers Logo
476 people viewed this question
Top Makita Tools & Hardware - Others Experts
Jim Thurston
John Porter
Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
