Question about Pool & Spa
I have an older jucuzzi spa. Model number z140. I had one of the primary wires burn through some time ago. I repaired this and the spa ran fine until yesterday. It quit running, heating, just plain quit. I checked it today and found one of the smaller wires that connected to a lug on a part that is on the PC board was burned but not burned through. There was enough wire there that I could cut the bad part out and put a new connector on it. This did not make the spa operative. The gfi breaker has not tripped through all of this. There are two fuses on the PC board. I checked them out and they are ok. Any suggestions as to why the wiring keeps overheating and now the spa doesn't run.
  • farmer96 Jan 28, 2009
    Thanks for the information. You are right on base. While waiting for this answer I contacted a very helpful man by the name of Bruce at Clear Creek Spa in Commerce City, Co. who gave me the same advise that you gave me. I did replace the PC board and am soaking again.
    By the way, maybe I can help you or someone you know. I have what is called "Restless Leg Syndrome". My legs occasionally move involuntarily. Not fatal but very annoying. Soaking in the hot tub, or even a hot bath I presume, helps me eliminate this and allows me to get back to sleep at night. If you know anybody with this same thing pass this information along. I think they will thank you as I am for your information.
    Problem Solver:
  • 7 Answers
I have found that most wires that overheat were caused by a loose connection. Wheather is was at the terminal screw or a bad solder joint on the circuit board. When there is enough heat to "bake" a wire, it most likely damaged the board as well. Check the traces on the back of the circuit board.
When you have a connection that is loose and "making & breaking" you are most likely to find carbon build up on the wire/ connector itself and it needs to be cleaned if not replaced.
Or keep it simple & replace the circuit board. Good luck
Posted on Jan 27, 2009
My new flo-master xp2 spa pump will not engage the low speed. The hi speed (jets) works fine but the low speed doesn't engage. I just hear a clicking and nothing comes on.
if you had ice in it and it was powererd up.. you may have burned out the start capacitor or even the start windings..why was it iced up while working on should have been freewheeled by hand before startup..I just got a tub in here.. had to wait 6 days for it to thaw out..(sign of good insulation) we just ran it for the first time some seals to replace and some switches to repair..
Jan 08, 2014 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
I have a Jacuzzi circa 1998 model Z140 spa. The 50 amp gfi breaker is continually trippinhg. The electronic control box is a Balboa instruments MODEL, DU-H276-DCAH. A relay on the circuit board chatters...
Hello - sounds like you will need to replace the relay itself if possible, if not you most likely need to replace the circuit board considering its age.You can check by diconnecting the power to the board.
If you are not an electrition and you dont work with electrical STOP NOW!! and call electrition.
Following steps would be 1. Turn off breaker. 2.Disconnect wiring to the board. 3.Wire nutt off electrical to the board.
4. Turn breaker back on. If breaker does not trip , board will need repaired or replaced.
May 18, 2011 | Home
How do you get the pump out of the housing on a jucuzzi magnum force pump
If yours is the model with the big round ring around motor, it is a large retaining nut. Remove this nut and the motor should come from the pump housing. Don't be too rough, plastic breaks.
Jun 27, 2010 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Sensor issue
seem like you have a module problem check all your model under the dash area that is link with e c u
Jul 01, 2009 | 2002 Chevrolet Tahoe
Pool heater works, but smokes and bangs when pool is turned off.
Yes! It is dangerous. The pressure switch is malfunctioning and allowing the heater to remain on when the pump shuts off. You should not use the unit until a qualified repair tech can look at the unit. There is only one other set of limit switches that are turning your burners off before the boiling water bursts the tube bundle so if they fail to react in time, you'll burst the heater, cause expensive damage and risk injury.
Jun 12, 2009 | Pool & Spa
Carrier Infiniti system, system maufunction on primary display
Call a Carrier service comapny and have them investigate further, when system malfunction comes up on the user interface usually there is a substantial problem.
Either that or the User Interface has gone bad and needs to be replaced
May 14, 2009 | Carrier Heating & Cooling
Heater won't go on my jucuzzi model 315
upper spa side control should have a heat lite, if on then heater is recieving voltage. Sometimes pump can have an air bubble in line.
Make sure water is flowing from jet. Spa will not lite heater without water flow. If no water try loosing union after pump to pull air through, so pump can fill with water, and no longer cavitate. Kirk
Feb 15, 2009 | Jacuzzi Pool & Spa
Pool & Spa Logo
178 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
