HP d220 mt won't boot from a windows 7 install DVD....Will boot an XP install CD
I tried using an external USB DVD drive...I've tried using an local DVD CD drive. Windows XP installation CD(s) work okay. Once Windows XP has started...the DVD drive works okay. It gets an error # 5 when I try to boot from the Win 7 install DVD. I tried to update the Bios but it still won't read my "install DVD". Need any help you can offer.
  • 27,725 Answers
If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
or click start type in event viewer press ENTER
you might be able work your way through the problem
Hope it helps.
Posted on Nov 28, 2012
5 Suggested Answers
SOURCE: FATAL ERROR MESSAGE/DELL OPTIPLEX GX150 DESKTOP/WINDOWS XP PRO
Optiplex 150 I get a message error loading operating system
can somebody help out there?
Posted on Jan 06, 2009
gcrcomputers
  • 170 Answers
SOURCE: an you boot from usb drive using HP Compaq d220
Check the BIOS for boot options, if it has USB listed you should be able to, you will need to make the USB bootable as well, theer are instructions here: http://www.bootdisk.com/pendrive.htm
Hope this helps, if so please rate my solution accordingly. Thanks, David
Posted on Mar 18, 2009
venexcsd
  • 1185 Answers
SOURCE: Bios update failed *flash*
You are in deep trouble
A problem with refreshing the Bios is that you can corrupt the old one and then the new one does not load leaving you stuck in limbo land
I would contact Acer support and hope that they offer a pre-programmed Bios chip to replace your corrupt one.
Posted on Jul 04, 2009
technical114
  • 1851 Answers
SOURCE: trying to boot and change bios start up for compaq d530 sff
Unplug the case from the power, open the cover and try to locate on the motherboard a small round battery (a little bigger that the one at the electronic watches) TAKE CARE THAT THE TOWER IS UNPLUGGED FROM THE MAINS. Very carefully remove the batery and wait 1-2 minutes. After that insert the battery back, close the case, plug the tower and start the pc. It will boot at the default bios settings, without passwords but you have to make the settings again (date, boot order e.t.c.)
In case of a problem post back.
Stelios.
Posted on Feb 23, 2010
Cannot boot from cd rom
check out cd/dvd-writer.if any dust partikels clean with caned air.
Apr 22, 2013 | HP Compaq Evo D310 PC Desktop
Asus n50vc won't install windows 7 from USB device
Try bringing up the boot menu (it will say what key to press on the splash screen) and choosing the usb. if that does not work try moving ports.
Jan 16, 2013 | ASUS N50Vc-B3WM PC Notebook
Iomega floppy usb-powered external floppy drive on windows 8
Hi, Sounds like driver related problem to me. Try use this tool to update the drivers: Driver Update Software for XP Vista 7 8. Wish you best of luck.
Nov 30, 2012 | Iomega Floppy USB-Powered External Floppy...
HP nc6230 freezes shen loading Windows XP Pro
Try booting from your Optical Drive. First insert your Windows XP Pro CD into the drive. Do not re-install the operqating system or you will lose all your files and programs! When prompted press 'R' to use the Recovery Console. You should be able to write a new boot sector to your hard drive.
If this doesn't solve the problem, you might need to re-install the operating system. If you can find a way to save all your files from your drive (perhaps by putting your drive in an external USB caddy and viewing its contents on a different computer).
If all else fails get a new hard drive and start again with your WIndows XP Pro CD. Use an external 2.5" USB caddy afterwards to get your documents and files back off your old disk. You will need to re-install your programs, though. If your disk is Service Pack 3 you should be able to get straight back on the internet via a wireless connection to update all your drivers from hp's website.
Oct 27, 2011 | HP Compaq nc6320 Notebook
Toshiba portege m100. lost windows xp. how do I clean install windows. no cd drive only usb ports. will not boot pxe.tried windows on formated flash drive, still no result.
Making a bootable flash drive involves a few tricks. I have had much better success using a utility to do the setup on those. Doing it manually works but not all the time.
I'd beg borrow or buy a usb dvd drive and boot off the install cd if nothing else. These have really dropped in price and are handy to have around.
I'm assuming you have set the bios to boot from the flash drive before it hits the hard drive? You would also have to set it to hit the usb dvd drive prior to the hd as well if you go that way.
When you get it booted it will ask if you want to format the drive before installing. You can also just pick a new directory to put windows in as well.
Don't forget to download all the drivers from Toshiba. You will need system info, video, and a network at the very least to get running and able to download the rest. These are very handy on a flash drive to plug in when you get xp started.
Sep 02, 2011 | Toshiba Portege M100 Notebook
I can't change the first booting device as CD drive on my Hp dx220 system, eventhough i have changed in the BIOS it won't boot from CD, automatically it starts from the HDD since the Operating...
You can boot up your laptop with Tenorshare Data Recovery WinPE to recover your files.It allows users to burn ISO file to CD/DVD/USB Flash Drive and boot up Operating System from bootable CD/DVD/USB Flash Drive directly.You can use it to retrieve data under any boot up problem.Get it from http://www.any-data-recovery.com/product/datarecoverywinpe.htm Then perform a system restore to fix your operating system.
Aug 03, 2011 | HP Compaq Business Desktop D220
Is it possible to fix a notebook that has a message with load needed dlls for kernel. It's for a notebook. I've looked it up and it tells me to put the cd in and restore it. I have a notebook and...
Hi.
Yes it is possible to fix the netbook. All you need to do is reinstall the operating system. You will have to get hold of an external DVD/CD drive or install Windows through a USB drive.
With a DVD/CD drive all you need is the XP installation CD. Connect the drive to the power outlet and then plug the USB lead to the computer. turn the netbook on and hit the F12 key or the key it tells you for "Boot Options". Select the "USB CD-ROM" device and follow the on-screen instructions to reinstall the operating system.
If you haven't got an XP installation CD then you'll have to purchase one.
You can also install XP from a USB flash drive. Click on the link I have provided below for an in-depth explanation for how to install Windows XP from a USB flash drive>>>
http://komku.blogspot.com/2008/11/install-windows-xp-using-usb-flash-disk.html
If you decide to install using the USB flash drive then to get the system to boot from the USB flash drive just follow the same instructions for the DVD/CD drive.
Hope this helps and please post back if there is anything else.
Regards.
May 23, 2011 | Computers & Internet
Hi, I'm installing widows xp in HP Compaq nc6220, but after setup loading files the mesaage (bottom of setup screen) "Setup is starting windows", then it did'nt contiue the installation,...
1 many times the the CD cant load as the files in the CD are corrupt or the CD is not read by the drive corectly...so get a new WinXP CD
2 try an external CD drive if your BIOS alows to boot from USB drive....(connect the external CD drive to the USB and make necessary changes to the BIOS boot seq in the BIOS screen...
BIOS screen can be enabled by pressing the F1, or F2 or the Del key as on as you start the PC
3 once in BIOS screen look for boot seq and change the boot drive to the foll
1st boot device - USB CD / DVD rom drive
2nd boot device - internal CD rom drive
and so on
if you can do the above then try the WinXP installation using the external CD rom drive....
else there is a little complicated method of using a pen drive thru USB (will discuss that later) provided your BIOS alows booting from USB
for more PC related issues visit my website
reg
kris
suresh_krishnan1961@yahoo.com
www.sureshayyar.110mb.com
May 18, 2011 | HP Compaq nc6220 Notebook
Computers & Internet Logo
784 people viewed this question
David Payne
David Payne
